I know that I am new to this forum but I have come seeking knowledge so that I may resolve a technical issue that I have been trying to solve on my own for quite some time now, at this point I think I need to escalate my questions to this community, lets get straight to the point shall we?
I've been having issues setting up a Static IP address, I believe the changes that I made have pushed successfully my only issue is that I am unable to ping google's DNS of 8.8.8.8. once my static IP has been set. I may be overlooking a step in the process listed below but I was hoping a fresh brain could point me towards the right direction.
There seems to be a lot of miscommunication when it comes to configuring Static IP addresses for our Pi's, I believe that I am on the right track when I am reviewing the stack exchange tut that i've mentioned below.
https://raspberrypi.stackexchange.com/q ... ip-addressSetup a Static IP Address
Questions about setting Static IP Address are among the most common on this site. There are very many tutorials (many wrong, obsolete or incomplete).
Disclaimer
Before proceeding I feel obliged to state that setting up a static address is NOT recommended. Telecommunications Engineers do not do this. Static IP Addresses can be the bane of a Network Administrator's life. There are situations where Static IP Addresses are necessary e.g. if you are running a DHCP server, or running on an isolated network with no DHCP server.
If you are determined to proceed anyway you should make sure you get it right. Adapted from Foundation Network Tutorial
Find the Settings of your local Network
This is most easily done with the Pi itself, using DHCP, but can be done on any computer on your network, although the commands may differ on other systems.
Run either of the following (depending on whether you are using Ethernet or WiFi):
ip -4 addr show dev eth0 | grep inet
ip -4 addr show dev wlan0 | grep inet
On Stretch (which may not use wlan0 or eth0) run the following
ip -4 addr show | grep inet
which should give an output like:
inet 10.1.1.30/24 brd 10.1.1.255 scope global eth0
inet 10.1.1.31/24 brd 10.1.1.255 scope global wlan0
(ignore any lo entry)
The first address is the IP address of your Pi on the network, and the part after the slash is the network size. It is highly likely that yours will be a /24.
The second address is the brd (broadcast) address of the network.
Find the address of your router (or gateway)
ip route | grep default | awk '{print $3}'
10.1.1.1
Finally note down the address of your DNS server, which is often the same as your gateway.
cat /etc/resolv.conf
# Generated by resolvconf
nameserver 10.1.1.1
Then follow ONE of the following options. (There are other methods not documented here. These are the most common on Raspbian.) (In either method, and in the discovery above, substitute the appropriate network interface name for eth0 or wlan0.)
dhcpcd method
Leave /etc/network/interfaces at its default (as above).
Edit /etc/dhcpcd.conf as follows:-
Here is an example which configures a static address, routes and dns.
interface eth0
static ip_address=10.1.1.30/24
static routers=10.1.1.1
static domain_name_servers=10.1.1.1
interface wlan0
static ip_address=10.1.1.31/24
ip_address is the address and size from the command above (or another unused address on the same network),
routers is the address of your router (or gateway).
domain_name_servers is the DNS address(es) from /etc/resolv.conf.
(see man dhcpcd.conf)
Then disable the DHCP client daemon and switch to standard Debian networking:
sudo systemctl disable dhcpcd
sudo systemctl enable networking
Reboot for the changes to take effect:
sudo reboot
Side Note- I will be placing the output for all the command that are listed above under this line.
This is the output from sudo cat /etc/os-relase to ensure that I have provided all the pertinent info regarding my pi
[PRETTY_NAME="Raspbian GNU/Linux 8 (jessie)"
VERSION_ID="8"
VERSION="8 (jessie)"
ID=raspbian
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
ip-4 addr show | grep inet
After I obtained all the nesscary networking information for my static IP I made changes to my "/etc/dhcpcd.conf file and placed them at the bottem of the last line.
#A hook scripct is provided to lookup the hostname if not set by the DHCP
# server, but it should not be run by default.
nohook lookup-hostname
interface wlan0
static ip_address=99.177.130.170/22
static routers=99.177.128.1
static domain_name_servers=192.168.1.254
I appreciate you all for taking the time to read through my issue, I hope this issue can be solved until then enjoy your Pi's!
