dominikk
TL-WN722N v2 - monitor mode + mfruba kernel problem
Mon Oct 09, 2017 7:03 pm
I bought TL-WN722N v2. I want to use it in monitore mode.
I heard there is a many problems, but also found a solution.
https://github.com/mfruba/kernel
When I try to compile it, after make I've got a problem like that.
[email protected]:~/Downloads/kernel-master/drivers/TL-WN722N_v2.0-Ralink/rtl8188EUS_linux_v4.3.0.8_13968.20150417 $ make
"NO SKRC,we will use default KSRC"
make ARCH=armv7l CROSS_COMPILE= -C /lib/modules/4.9.35-v7+/build M=/home/pi/Downloads/kernel-master/drivers/TL-WN722N_v2.0-Ralink/rtl8188EUS_linux_v4.3.0.8_13968.20150417  modules
make[1]: *** /lib/modules/4.9.35-v7+/build: No such file or directory.  Stop.
Makefile:1368: recipe for target 'modules' failed
make: *** [modules] Error 2
What should I do?
My kernel:
uname -a
Linux raspberrypi 4.9.35-v7+ #1014 SMP Fri Jun 30 14:47:43 BST 2017 armv7l GNU/Linux
[email protected]
MrEngman
Re: TL-WN722N v2 - monitor mode + mfruba kernel problem
Tue Oct 10, 2017 6:51 am
What should I do?
My kernel:
uname -a
[email protected]
build is a symlink to the Linux kernel source.
Make it using
sudo ln -s /home/pi/src/linux /lib/modules/$(uname -r)/build
Change directory /home/pi/src/linux to the directory where your Linux source/headers is.
dominikk
Tue Oct 10, 2017 2:52 pm
What should I do?
My kernel:
uname -a
[email protected]
Make it using
[email protected]:/usr/local $ sudo ln -s /usr/include/linux/ /lib/modules/4.9.35-v7+/build
make[1]: Entering directory '/usr/include/linux'
make[1]: *** No rule to make target 'modules'.  Stop.
make[1]: Leaving directory '/usr/include/linux'
Any idea where should I link this build?
MrEngman
Tue Oct 10, 2017 5:05 pm
That is not the kernel source.
To compile a module for Linux you need to get the Linux source or headers and prepare it for compiling the module before then compiling the module.
There is a script that can do it although I have never used it. Take a look here
https://www.raspberrypi.org/forums/viewtopic.php?t=76261
The post is old but I'm fairly certain it is still being used as I've seen it mentioned in various posts quite recently.
As far as I'm aware this script installs the kernel source for the current kernel you are using and then configures it for compiling the module you want to compile.
dominikk
Sat Oct 14, 2017 11:58 am
Thanks for helping.
I install sources manualy.... and now even change the distro for Kali and I have still this problem.
ux_v4.3.0.8_13968.20150417# make
make ARCH=armv7l CROSS_COMPILE= -C /lib/modules/4.4.50-v7+/build M=/root/Downloads/kernel-master/drivers/TL-WN722N_v2.0-Ralink/rtl8188EUS_linux_v4.3.0.8_13968.20150417  modules
make[1]: Entering directory '/usr/src/kernel'
Makefile:617: arch/armv7l/Makefile: No such file or directory
make[1]: *** No rule to make target 'arch/armv7l/Makefile'.  Stop.
make[1]: Leaving directory '/usr/src/kernel'
[email protected]:~/Downloads/kernel-master/drivers/TL-WN722N_v2.0-Ralink/rtl8188EUS_linux_v4.3.0.8_13968.20150417#
should I link /user/src/kernel/arch/arm with /armv7l ?
MrEngman
Sat Oct 14, 2017 12:42 pm
Thanks for helping.
Yes, that would need command
sudo ln -s /user/src/kernel/arch/arm /user/src/kernel/arch/armv7l
dominikk
Sat Oct 14, 2017 12:53 pm
[email protected]:~/Downloads/kernel-master/drivers/TL-WN722N_v2.0-Ralink/rtl8188EUS_linux_v4.3.0.8_13968.20150417# ln -s /usr/src/kernel/arch/arm /usr/src/kernel/arch/armv7l
[email protected]:~/Downloads/kernel-master/drivers/TL-WN722N_v2.0-Ralink/rtl8188EUS_linux_v4.3.0.8_13968.20150417# make
  CC [M]  /root/Downloads/kernel-master/drivers/TL-WN722N_v2.0-Ralink/rtl8188EUS_linux_v4.3.0.8_13968.20150417/core/rtw_cmd.o
/bin/sh: 1: ./scripts/recordmcount: Exec format error
scripts/Makefile.build:258: recipe for target '/root/Downloads/kernel-master/drivers/TL-WN722N_v2.0-Ralink/rtl8188EUS_linux_v4.3.0.8_13968.20150417/core/rtw_cmd.o' failed
make[2]: *** [/root/Downloads/kernel-master/drivers/TL-WN722N_v2.0-Ralink/rtl8188EUS_linux_v4.3.0.8_13968.20150417/core/rtw_cmd.o] Error 2
Makefile:1402: recipe for target '_module_/root/Downloads/kernel-master/drivers/TL-WN722N_v2.0-Ralink/rtl8188EUS_linux_v4.3.0.8_13968.20150417' failed
make[1]: *** [_module_/root/Downloads/kernel-master/drivers/TL-WN722N_v2.0-Ralink/rtl8188EUS_linux_v4.3.0.8_13968.20150417] Error 2
I have no idea how to run WN722N v2 on monitor mode :(
MrEngman
Sat Oct 14, 2017 1:26 pm
I've never used monitor mode so can't help there. However, you need a working driver first. No idea what is giving the errors now you have the symlinks fixed.
You might find the following some help. I have a script which will automatically determine the driver you need for the Raspbian kernel version and wifi you are using and download and install it.
Download and install the script with commands
sudo wget http://www.fars-robotics.net/install-wifi -O /usr/bin/install-wifi
sudo chmod +x /usr/bin/install-wifi
The command
sudo install-wifi -h
will show details on using it.
To install the driver on your current kernel you should just need to run command
sudo install-wifi
This will select the driver you need and automatically download and install it.
This script handles drivers for 8188eu, 8192eu, 8812au/8821au and mt7610 wifi modules.
Ronaldlees
Thu Nov 23, 2017 3:18 pm
I think the OP meant the driver was the reason he can't run monitor mode. But once he gets an appropriate driver built, running monitor mode is easy, assuming it's legal in his country. AFAIK, it's always legal if used only with the user's own packets. IIRC correctly, something like this is needed:
sudo apt-get install iw
iw list
    --> should display a list of supported modes:
           IBSS, managed, AP, AP/VLAN, monitor, mesh, etc
If "monitor" mode is in the list, then one or the other ways should work:
  • ip link set wlan0 down
    iw dev wlan0 set type monitor
    ip link set wlan0 up
    iwconfig wlan0 down
    iwconfig wlan0 mode monitor
    iwconfig wlan0 up
    ifconfig wlan0 192.168.1.40
Tcpdump can be used to capture WiFi/RF packets:
tcpdump -I -i wlan0 -w rfpackets.log -XX -n
    ("-I" means "use the RFCOMM mode", -i specifies the monitor interface, -w is for the log file, -XX is for full packet, -n for no resolution)
Then, wireshark can be used to display the logged packets in a nice format. It takes two adapters. One adapter cannot do both a connection and monitor it at the same time. The OP should be sure to unplug the monitor adapter's antenna, and he should take any other precautions needed to be sure he gets only his own packets for inspection. Regulations vary.
I am the Umbrella man
Who is online
Users browsing this forum: No registered users and 19 guests
