Hello again,
I observed now something strange. I set the system time and date manually close to the real time (given by German PTB atom clock:
https://uhr.ptb.de). You can check the deviation of your local system clock to the PTB reference clock by clicking on "Abweichung".
However, I discovered, that after each reboot the difference between my clock and the PTB clock was about 7 seconds smaller (my clock went ahead). During several reboots I came as close as 0.5 seconds...and I thought, now the ntp client would finally work...but it didn't. Continous rebooting result in the situation that the clock goes behind now (again about additional 7 seconds after each rebooting).
Greetings!
Oliver
edit: the about 7 seconds difference is the delay during rebooting. It's simply that the clock stops at the time I shut down. I made the test with a normal shutdown, waited 2 minutes and booted again...the clock is now about 2 minutes behind.
