cleverca22
Re: voicecommand
Thu Mar 20, 2014 3:46 am
sudo apt-get install libboost-regex1.49.0
syde0004
Re: voicecommand
Wed Dec 09, 2015 10:25 pm
Has anybody figured anything out with this? I'm running into the same issue and feel like I'm beating my head against a wall.
G3N13
Re: voicecommand
Wed Jan 13, 2016 9:55 am
I too am having this same exact issue. If any of you have figured it out by now, please let me know! Much appreciated, Thanks
pilou100
Re: voicecommand
Sun Apr 17, 2016 11:08 am
Same one here... too bad :( :( :(
Re: voicecommand
Sun Apr 17, 2016 3:18 pm
sudo apt-get install libboost libboost-regex libboost-dev libboost-regex-dev
pbecks1963
Re: voicecommand
Fri Apr 29, 2016 2:20 pm
@DougieLawson
i get the error:
e: unable to locate package libboost libboost-regex libboost-regex-dev
Re: voicecommand
Fri Apr 29, 2016 8:26 pm
Sorry I have no idea how to solve that because my crystal ball went off line a few years ago. You've not given enough detail.
What OS? Are you connected to the internet? Are your apt-get files up to date?
pbecks1963
Re: voicecommand
Tue May 03, 2016 10:55 am
Sorry Dougie... (nevermind)
meanwhile i have changed a lot (changed to raspbian jessie and "jasper"). Things are still not working properly but i am not giving up...
androidvoir
Re: voicecommand
Fri May 06, 2016 12:55 pm
I have been trying to get voicecommand to work on Jessie and this is what worked for me:
git clone git://github.com/StevenHickson/PiAUISuite.git
cd PiAUISuite/Install/
./InstallAUISuite.sh
cd PiAUISuite/VoiceCommand
make clean
g++ -mcpu=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -D'BUILDTS="160506 05:20:31 -0700"' -O3 -lcurl -lboost_regex -o voicecommand voicecommand.cpp
cp voicecommand /usr/bin
voicecommand -s
make by itself kept trying to use g++-4.8 ... I have tried a bunch of other projects out there including pocketsphinx (some success) and Jasper building manually because I don't want to start from a fresh image (no success)
theseamusjames
Re: voicecommand
Sun May 08, 2016 6:10 pm
Trying your shell commands, I run into an error on
make clean
And looking at the file, I find that "make clean" only removes some files (*.o)
Further inspection suggests that running
make voicecommand
should work, but I run into the following error
In file included from voicecommand.cpp:1:0:
voicecommand.h:8:27: fatal error: boost/regex.hpp: No such file or directory
 #include <boost/regex.hpp>
compilation terminated.
Makefile:34: recipe for target 'voicecommand' failed
make: *** [voicecommand] Error 1
I've installed some of the libboost libraries using the following command:
sudo apt-get install libboost-dev libboost-thread-dev libboost-system-dev libboost-atomic-dev libboost-regex-dev
No luck. Has anyone else successfully compiled on the pi?
Nki1989
Re: voicecommand
Mon May 16, 2016 2:44 pm
Has anyone figured what to do after the voice command prompt doesn't work?? When downloading the voice command section of it it simply says voicecommand: error while loading shared libraries: libboost_regex.so.1.49.0: cannot open shared object file: No such file or directory.
I am doing this on a raspberry pi with raspbian Jesse and I have to have this sorted out today as it's the last part of a project I'm working on
Thank you so much for any help
DataManX
Re: voicecommand
Sun May 22, 2016 7:16 am
This command resolved a similar problem I was having with libboost not found that others report above.
I ran this "sudo apt-get install libboost-regex1.49.0" after I installed Voice Command following instructions here
http://stevenhickson.blogspot.com/2013/ ... e-and.html
Works like a charm.
Low84000
Re: voicecommand
Thu Jul 21, 2016 8:41 pm
For those who cannot have the older version of libboost-regex 1.49.0.
If you are in version 1.55.0
Just execute this command :
ln -s /usr/lib/arm-linux-gnueabihf/libboost_regex.so.1.55.0 /usr/lib/arm-linux-gnueabihf/libboost_regex.so.1.49.0
Hope it helps :p
Source : https://github.com/StevenHickson/PiAUISuite/issues/58
meatgrinder
Re: voicecommand
Tue Sep 19, 2017 11:24 pm
or create a link from whatever libboost regex version that you have
rottieGO
Re: voicecommand
Wed Oct 25, 2017 3:39 am
Did anyone figure out how to run PiAUISuite on Raspberian Stretch on Pi 3B with following versions
axel is already the newest version (2.12-1).
curl is already the newest version (7.52.1-5+deb9u1).
flac is already the newest version (1.3.2-1).
libboost-dev is already the newest version (1.62.0.1+b4).
libboost-regex-dev is already the newest version (1.62.0.1+b4).
libcurl4-gnutls-dev is already the newest version (7.52.1-5+deb9u1).
mpg123 is already the newest version (1.23.8-1).
sox is already the newest version (14.4.1-5).
xterm is already the newest version (327-2).
youtube-dl is already the newest version (2017.05.18.1-1).
host 9.10.3-P4-Raspbian
Installation fails at:
Would you like voicecommand to try to set itself up? y/n
maikodocty25
Re: voicecommand
Fri Oct 27, 2017 4:04 am
I tried to run all this version but still, voice command failed
I even execute this command:
make clean
voicecommand -s
https://www.abestmeter.com/ultrasonic-f ... el-sensor/
arda85835
Re: voicecommand
Sun Feb 18, 2018 6:14 pm
****SOLUTION****
You are getting this error:
ls /usr/lib/arm-linux-gnueabihf/ | grep 'libboost_regex'
Your output will be something like:
libboost_regex.a
libboost_regex.so
libboost_regex.so.1.62.0 (This number may be different, in that case update the following code)
sudo ln -s /usr/lib/arm-linux-gnueabihf/libboost_regex.so.1.62.0 /usr/lib/arm-linux-gnueabihf/libboost_regex.so.1.49.0
Return to “Off topic discussion”
