Flmmmm
Re: MyPi - New iOS App for Home Automation projects
Mon Mar 27, 2017 9:20 pm
I have this lovely thing running on a Raspberry pi 1 B. I have installed Jessie in order to run Python 3.4 which is needed. Moded the pin numbers, that is not the Gpio numbers, to match the old pi.
Thanks to KobiSnir :D
Flmmmm
Wed Mar 29, 2017 9:37 am
Woorking more than perfect, i could very much wish a timer function.
Out 1 momentary on at 9:00 and on at 12:00 and so on.
Evt. as paid version.
Rgds Flemming
ziggy27
Mon Apr 03, 2017 12:17 pm
Why relay 1 is not working on my iphone. When I press the button it is not changing its state and also no output on GPIO pin 7. But on the server is changing out either 1 or 0 state
Appreciate if you can help me.
sadboy
Thu Aug 03, 2017 10:35 am
hey guys
I want to make this auto run on the PI when turned on, so i can use it without manual activation, have i missed a step in setting it up? or is there a way to do this?
TIA
KFL
Sat Oct 21, 2017 4:48 am
Thanks for the great app, hope to get it working
Anyone have a working script for Pi 3 - newbie and still struggling with vi ;-)
Hcgrant
Wed Feb 07, 2018 8:33 pm
Does this work with python 3.5.3 ?
When i run ..
python3 mypi_server.pyc
... I get ....
RuntimeError: Bad magic number in .pyc file
When i get it working its going to be just what I need
bob808
Fri Mar 09, 2018 1:50 am
This is broken. Please fix it or remove it from the app stores. You're making us loose our time. Thanks.
p.s. RuntimeError: Bad magic number in .pyc file on both RaspberryPi 1 and 2.
abhishektyagi
Fri Apr 06, 2018 1:41 pm
sir, i want to modify the ui of the app for my college project....please help
Flmmmm
Tue May 15, 2018 2:09 pm
About "RuntimeError: Bad magic number in .pyc file on both RaspberryPi 1 and 2."
I had to use the right Python version :-)
In the newest app there is download for Python 3.4.2 and 3.5.x
