rpi25
How to install Java 8 on Raspbian?
Tue Feb 24, 2015 5:31 am
How would I go about doing this? I don't see a good package when I do apt-cache search jre, they are all java 6 and 7.
I am wanting to install filebot, but to do so I apparently need to install Java 8.
Can anyone point me in the right direction? A search of the forum disregarded install and 8, and just searched for java, which returned over 6000 posts and the first few pages of results were not helpful, lol
Re: How to install Java 8 on Raspbian?
Tue Feb 24, 2015 9:25 am
sudo apt-get install oracle-java8-jdk
Although on a stock Raspbian (or NOOBS) 2015-02-16 install it's already there.
Note: Having anything remotely humorous in your signature is completely banned on this forum. Wear a tinfoil hat and you'll get a ban.
This is a doctor free zone.
rpi25
Tue Feb 24, 2015 8:12 pm
Very cool, I see you are correct it was already installed, as when I tried to add it via apt-get it said it was already the most up to date version.
However, something seems to be not right.
When I try to execute the filebot.sh script from the most recent filebot portable (http://sourceforge.net/projects/filebot/), I get the following errors
Exception in thread "main" java.lang.UnsupportedClassVersionError: net/filebot/Main : Unsupported major.minor version 52.0
	at java.lang.ClassLoader.defineClass1(Native Method)
	at java.lang.ClassLoader.defineClass(ClassLoader.java:643)
	at java.security.SecureClassLoader.defineClass(SecureClassLoader.java:142)
	at java.net.URLClassLoader.defineClass(URLClassLoader.java:277)
	at java.net.URLClassLoader.access$000(URLClassLoader.java:73)
	at java.net.URLClassLoader$1.run(URLClassLoader.java:212)
	at java.security.AccessController.doPrivileged(Native Method)
	at java.net.URLClassLoader.findClass(URLClassLoader.java:205)
	at java.lang.ClassLoader.loadClass(ClassLoader.java:323)
	at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:294)
	at java.lang.ClassLoader.loadClass(ClassLoader.java:268)
Could not find the main class: net.filebot.Main. Program will exit.
Which is confusing, as the java 8 package you mention is clearly installed. Any idea what is wrong here?
Tue Feb 24, 2015 8:14 pm
Your code has thrown an exception. You'll need to read the source code to understand why it has done that.
rpi25
Tue Feb 24, 2015 9:25 pm
OK, here's what I did to fix this, total linux noob but essentially I had to just change the default auto choice of java and javac for the raspberry pi (one of them was still set to the jdk6).
I did so following this guide http://www.rpiblog.com/2014/03/installi ... ry-pi.html
With these commands
$ sudo update-alternatives --config javac
asandford
Tue Feb 24, 2015 9:46 pm
rpi25 wrote:OK, here's what I did to fix this, total linux noob but essentially I had to just change the default auto choice of java and javac for the raspberry pi (one of them was still set to the jdk6).
With these commands
A more 'portable' way is to set the JAVA_HOME env variable to point to the appropiate version for your project.
rpi25
Tue Feb 24, 2015 11:05 pm
So in this instance, where would I find the home variable to redirect? Is that in the filebot.sh script, or elsewhere?
asandford
Tue Feb 24, 2015 11:36 pm
rpi25 wrote:So in this instance, where would I find the home variable to redirect? Is that in the filebot.sh script, or elsewhere?
You can set it from the CLI: export JAVA_HOME=/path/to/java/version/you/want
simonx314
Sat Oct 22, 2016 7:26 pm
With these commands
Thanks rpi25, running these two commands was what I needed to do to fix my javac java version mismatch.
henryburkhard
Thu Feb 16, 2017 1:12 am
After downloading the latest version from oracle you can run a script to set the alternatives.
JAVA_DIR=/usr/lib/jvm/jdk1.8.0_121
JAVA_BIN_DIR=$JAVA_DIR/bin
JAVA_JRE_LIB_DIR=$JAVA_DIR/jre/lib
JAVA_JRE_BIN_DIR=$JAVA_DIR/jre/bin
DEST_DIR=/usr/bin
ALT_LEVEL=100
for x in $JAVA_JRE_BIN_DIR $JAVA_JRE_LIB_DIR $JAVA_BIN_DIR
do
for f in `find $x -maxdepth 1 -type f -executable`
do
NAME=`basename $f`
update-alternatives --install $DEST_DIR/$NAME $NAME $x/$NAME $ALT_LEVEL
done
done
palswim
Tue Aug 22, 2017 2:52 pm
My Raspbian repository does not appear to contain this package. Am I missing a source or did Raspbian remove this package from the repository?
DirkS
Tue Aug 22, 2017 4:18 pm
It's in the RPF repo, not Raspbian
[email protected]:~$ apt-cache policy oracle-java8-jdk
oracle-java8-jdk:
  Installed: (none)
  Candidate: 8u65
  Version table:
     8u65 0
        500 http://archive.raspberrypi.org/debian/ jessie/main armhf Packages
HawaiianPi
Mon Oct 09, 2017 3:29 pm
Yea, it's in the RPF Stretch repo as well.
[email protected]:~ $ apt-cache policy oracle-java8-jdk
oracle-java8-jdk:
Note that it is quite an old version. The current version from Oracle is 8u144. If you want to update to the latest version you can install it manually, but an easier way is to use the webupd8team PPA, which will install and update Java like other packages. Also, if the above shows you have the old version installed, you'll want to remove it after we get you updated to the latest version (but don't try to remove it now).
Open a terminal and do the following:
sudo su
echo "deb http://ppa.launchpad.net/webupd8team/java/ubuntu xenial main" | tee /etc/apt/sources.list.d/webupd8team-java.list
apt-key adv --keyserver hkp://keyserver.ubuntu.com:80 --recv-keys EEA14886
The current version of Stretch will generate an errort about no dirmngr when trying to get the key. To fix that just install it (apt-get install dirmngr) then repeat the key command and continue.
apt-get update
apt-get install oracle-java8-installer
This will take a little while, and you'll have to agree to the Oracle terms, so pay attention.
When that is finished you'll want to remove the old Java version. If you had the default oracle-java8-jdk installed, remove it with apt-get remove oracle-java8-jdk, then you can exit the root terminal with exit[enter].
Enter java -version to check your installed version (it should be the latest).
[email protected]:~ $ java -version
java version "1.8.0_144"
Java(TM) SE Runtime Environment (build 1.8.0_144-b01)
Java HotSpot(TM) Client VM (build 25.144-b01, mixed mode)
Congrats, you now have the latest Java.
bhamail
Fri Mar 23, 2018 1:58 am
@HawaiianPi Thanks. Your post worked great for me.
dazz100
Sat Apr 07, 2018 9:58 am
Hi
I have just done a fresh install of the latest version of Raspian Stretch and Java wasn't installed.
I had to install it manually.
HawaiianPi
Sun Apr 08, 2018 7:57 pm
Hi
Only the Desktop version has it pre-installed. The Lite version would need you to install it. And the version in the repos is still super old.
~ $ java -version
java version "1.8.0_65"
Java(TM) SE Runtime Environment (build 1.8.0_65-b17)
Java HotSpot(TM) Client VM (build 25.65-b01, mixed mode)
Latest Java 8 from Oracle is now 8u161
~ $ java -version
java version "1.8.0_161"
Java(TM) SE Runtime Environment (build 1.8.0_161-b12)
Java HotSpot(TM) Client VM (build 25.161-b12, mixed mode)
Teapot
Mon Apr 09, 2018 2:39 pm
You can also give a try to OpenJDK 10 or 9.
E.g. certified Liberica one https://www.bell-sw.com/java-for-raspberry-pi.html
There are .tar.gz and .deb download options.
danieldixon
Fri May 04, 2018 10:46 am
Installation
First install dirmngr:
sudo apt-get install dirmngr
Second add deb repositories and key:
echo "deb http://ppa.launchpad.net/webupd8team/java/ubuntu trusty main" | sudo tee /etc/apt/sources.list.d/webupd8team-java.list
echo "deb-src http://ppa.launchpad.net/webupd8team/java/ubuntu trusty main" | sudo tee -a /etc/apt/sources.list.d/webupd8team-java.list
sudo apt-key adv --keyserver hkp://keyserver.ubuntu.com:80 --recv-keys EEA14886
Warning! If you add xentail repositories (as many RPi forums and other pages state) you’ll end up with old 1.8.0_65 version, you must be using trusty repositories in order to install latest Java version.
Update repositories:
sudo apt-get update
Install Java installer:
1
Verify Java version
To be 100% sure I have proper version of Java I use basic command:
java -version
Remove old Java
In case you have old Java 8 JDK
sudo apt-get remove --purge oracle-java8-jdk
Hope that Helps! 8-)
Regards,
Techtiq Solutions,
HawaiianPi
Sun May 06, 2018 9:02 am
Installation
You just posted what I posted last year, only with incorrect information.
Nope, that is completely false. 8u65 is what's in the Raspbian repositories. Installed the way I outlined above you get the latest version.
~ $ java -version
java version "1.8.0_171"
Java(TM) SE Runtime Environment (build 1.8.0_171-b11)
Java HotSpot(TM) Client VM (build 25.171-b11, mixed mode)
augustinas
Mon Sep 17, 2018 1:15 am
@HawaiianPi, Thank you! Worked wonderfully first time!
I read many pages and was never satisfied, until reading your post here.
Thanks again.
Return to “Java”
