No, AUII, the upgrade to PHPBB means the old stuff doesn't work anymore.
But if you have specific reasons why RPI is not your cup of tea, let ups know, and we will try to make it more Darjeeling.
EDIT: No reason that UPS want to know, just tell us!!
It's #555, so a pretty dark grey. Does the image below represent what you're seeing?
Wonderful, Evernote. Try this: https://www.evernote.com/shard/s153/sh/ ... 2fadaf473b
why not using the attachement option of the forum, to post screenshots?
[I only give negative feedback]
beta-tester wrote: ↑Thu Jul 27, 2017 5:32 pmi just realized,that a part of my signatur below my posts is missing (not shown up anymore) event it is still there in my profile.
the following part in the signature is missing:it also will not appear, when i put it in a quote block:Code: Select all
edit: when you edit my post, you can see, the text is still there. but not shown up, when the post is normally displayed.
all skins RPI and ProSilver are affected. it was correctly shown up earlier, before the new skins came up.
Click on your NAME at top of FORUM then choose USER CONTROL PANEL from drop down menu, then Board Preferences............
Oh hey, found the quote button. Yay.fruitoftheloom wrote: ↑Thu Jul 27, 2017 10:00 pmClick on your NAME at top of FORUM then choose USER CONTROL PANEL from drop down menu, then Board Preferences............
Ah, I found it I think. Thanks, the "menu bar" tip helped.davidcoton wrote: ↑Thu Jul 27, 2017 10:43 pmUser Control Panel as above
Board Preferences from the menu bar
Edit Global Settings
My board style
(That's on RPI. The other are very similar, albeit different visually)
phpBB was in serious need of updating, this was quite a big change, the RPF just took the opportunity to offer skins...............Imperf3kt wrote: ↑Thu Jul 27, 2017 11:28 pmAh, I found it I think. Thanks, the "menu bar" tip helped.davidcoton wrote: ↑Thu Jul 27, 2017 10:43 pmUser Control Panel as above
My board style
I never would have guessed this was a button:
http://imagizer.imageshack.com/img923/2065/5DC5L8.jpg
If the forum isn't broken, upgrade it until it is. Makes sense.
It was broken. We were well behind in security upgrades. So that's what we have done, upgrade to fix the security issues.
Er, what? I've been using the RPI skin, and can browse the forums fine. What EXACTLY is the problem, or is it simply "I cannot be bothered to learn something slightly different"?jlowe wrote: ↑Thu Jul 27, 2017 11:40 pmI used to browse the forums.. with this change, I'll just use google search site:www.raspberrypi.org and find what I am looking for.. I know I might miss new news. But it isn't worth the time to look for it.. BTW.. you asked for specifics about what is wrong.. never did I see specifics on the gonna be change before you made it!![]()
ciao .. jay
See here: viewtopic.php?f=63&t=189117&p=1191273#p1191273
