dimap
capacity of h.264 hardware encoder
Fri Jul 14, 2017 12:39 pm
Where a can find information about capacity of h.264 hardware encoder ? I'm using Raspberry PI 3 model B.
I try online decode-encode h.264 stream from IP cameras with FullHD resolution (1920x1080) for text timestamp apply.
Decode-encode process using ffmpeg (ffmpeg version N-86293-g781f88b Copyright (c) 2000-2017 the FFmpeg developers
built with gcc 4.9.2 (Raspbian 4.9.2-10)
configuration: --enable-mmal --enable-omx --enable-omx-rpi --enable-decoder=h264_mmal --enable-encoder=h264_omx --enable-nonfree --enable-libfreetype
When I start decode-encode process of second stream I get error:
[h264_omx @ 0x1eb20d0] Using OMX.broadcom.video_encode
[h264_omx @ 0x1eb20d0] OMX error 80001000
[h264_omx @ 0x1eb20d0] err 80001000 (-2147479552) on line 561
Error initializing output stream 0:0 -- Error while opening encoder for output stream #0:0 - maybe incorrect parameters such as bit_rate, rate, width or height
The error is not sensitive to the settings of the FPS and bitrate
One process FullHD decode-encode working fine.
Using lower resolution (1280x720) for two processes working fine.
Dmitry
6by9
Re: capacity of h.264 hardware encoder
Fri Jul 14, 2017 2:57 pm
Referencing error 0x80001000 back against the IL headers gives you OMX_ErrorInsufficientResources.
What have you set gpu_mem to in /boot/config.txt? 64MB is unlikely to be enough. 128MB should be sufficient.
To answer the question on spec, the codec block (common for both encode and decode) is specified for level 4.1 for encode or decode. It'll manage to decode some level 5.0 streams as long as the resolution isn't greater than 1920x1080, and likewise you can push the encode performance towards level 4.2 (1080P60) if you overclock things.
Doing both encode and decode simultaneously you'll have to scale back your expectations.
6by9
Fri Jul 14, 2017 3:00 pm
And having found the FFMPEG source code, failing an AllocateBuffer with OMX_ErrorInsufficientResources is almost certainly gpu_mem.
dimap
Sun Jul 16, 2017 3:43 pm
Thank you for you support !
