PiFan_123
Re: Screenly OSE -- Digital Signage for the Raspberry Pi
Sat May 20, 2017 10:14 am
I have some trouble with the duration settings for ech asset in Screenly OSE. The configured duration for each asset does not match the real display duration on the screen.
Even if I set the duration to 5 or 10 seconds the asset (e.g. image) will show up for at least 25 or 30 seconds. Reducing the duration for the assets in steps of 5 seconds also reduces the display time of these assets in steps of 5 seconds. Configuring the asset to show up for 1 second leads to the asset showing up on the screen for about 21 seconds. Is there anything I could do to fix this problem? Is there another "timeout" of 20 seconds that I can disable in Screenly OSE?
Thank you
vpetersson
Tue Jun 06, 2017 3:34 pm
Hey guys,
I just wanted to let you know that we've released a new companion tool to Screenly, namely a WordPress plugin that makes WordPress content more friendly for big screens. It's Open Source and available in the WordPress Plugin directory today.
You can read more about it here:
https://news.screenly.io/introducing-sc ... 7ff26667b7
Creator of Screenly (Screenly.io), the leading digital signage solution for the Raspberry Pi. Now hacking on WoTT (github.com/WoTTsecurity/agent),
Twitter: @vpetersson | vpetersson.com
hen3bosch
Trouble starting LSB screenly_net_mgr
Wed Jun 14, 2017 10:30 pm
I'm having problems starting screenly up with the same issue as https://github.com/Screenly/screenly-ose/issues/454 "screenly_net_mgr.service is broken #454" on github.
I do have networking connected after startup. It only just starts in the CLI.
I'm only having this problem when on wifi. When the cable is connected it starts just normal.
I'm using a raspberry pi B (the first one).
Any help how to solve this problem?
Kind regards,
Hendrie
vpetersson
Re: Trouble starting LSB screenly_net_mgr
Tue Jul 04, 2017 10:03 pm
hen3bosch wrote:Hello,
Kind regards,
Hendrie
I'd suggest you try upgrading to the latest release. We've made some improvement since. I'd also remove /boot/network.ini if you're not using the network manager in Screenly.
paulalexpax
Tue Aug 08, 2017 8:00 pm
pHeoz wrote:
Tue Jul 15, 2014 4:50 pm
I have successfully set up remote control management of the Raspberries from a distant network thanks to your tips, vpetersson.
I've also created an interface to manage these raspberries and know which one is online / offline, but I'd like to add some more functionalities to my dashboard.
In order to do so, I'd like to read the content of the Screenly OSE management page (the one we see when going to 192.168.0.1:8080 for instance). Does anyone know where this page is located on the Raspberry ? I can't seem to find it.
Thanks for your help
Could you please tell me how you got the remote management from a distant network. I have been checking to find some way to do it. Thanks
mkraley
Thu Aug 17, 2017 9:40 pm
Is there any way to get back to a Terminal session in a system that is running Screenly? I can boot back into NOOBS, but the edit config files option is disabled. Ctrl-Alt-F1/F2 don't seem to do anything. Is there some other trick?
...Mike
vpetersson
Thu Aug 17, 2017 10:31 pm
...Mike
You should be able to use ctrl+alt+F3 or F1.
I don't recall by heart what we for X11, but I think it's F1, so every other should work.
mkraley
Fri Aug 18, 2017 12:15 am
...Mike
I tried all the ctrl-alt-F<everything> no go.
If I reboot and get to the Screenly splash screen, then press ctrl-alt-F2, the screen then goes blank for several seconds, then the Screenly splash screen comes up.. It's like all the alternative consoles are redirected to the same thing.
If I wait until my content is displayed, I see no visible effect for any of the ctrl-alt-Fx keystrokes.
mkraley
Mon Aug 21, 2017 3:14 pm
How does Screenly handle caching of web page content? Although I have set no-cache headers on my web page, it appears as if Screenly only does a HEAD call each time it needs to display that asset, and does not fetch the content. Is this something I can control somehow?
A possibly related question is what happens if there is only one asset in the asset list? Will Screenly still attempt to redisplay the asset when the duration is up?
...Mike
mkraley
Mon Aug 21, 2017 3:16 pm
...Mike
In case anyone else has this problem, I tried again with flashing the complete screenly image, and ctrl-alt-F1 now works fine. (Previously I had used the update method from the RPi itself.)
alstrud
Thu Sep 21, 2017 4:39 pm
Hello. I ran a search for my question and found the same one from 4 years ago, so I will post it again, in hopes that there has been a resolution...
I have an asset webpage that requires a login prior to displaying its content. When the page loads there is a username/password login box. A keyboard plugged into screenly does not allow any input for me to type in the credentials. Is there a way to make this work?
Thank you in advance.
vpetersson
Fri Sep 22, 2017 8:04 am
If you plug in a keyboard, you should be able to use it. That said, the mouse is disabled. Try tabbing yourself to the desired field, which in theory should work.
chrimorg
Wed Sep 27, 2017 7:40 pm
I cannot get the wireless settings to work correctly. During setup, WiFi works so I know that the Pi isn't bad. If I install from NOOBs or Jessie, then the first boot of Screenly OSE will have the WiFi working fine. However, a reboot will result in no connection. The /boot/network.ini file is there, using the config from the wizard. I see the wifi settings populated in /etc/network/interfaces, too. If I run iwconfig, though, it shows wlan0 as not associated. This persists on the current build, too. Any help?
ShinobiX9X
Thu Sep 28, 2017 7:07 am
I did an update yesterday. now today i can reach the screenly webpage, but it shows empty with an errormessage:
"The operation failed. Please reload the page and try again."
Has anyone else encountered this error, and is there a solution?
thank you.
terenceang
Mon Oct 09, 2017 6:10 pm
Same here.. "The operation failed. Please reload the page and try again." after update.
vpetersson
Tue Oct 10, 2017 8:12 am
Could you try the development version to see if the issue still remains?
madsrh
Thu Oct 12, 2017 9:54 pm
How do I make sure that I'm on the latest release?
On the download page (https://github.com/screenly/screenly-ose/releases) I can download Screenly OSE, but the latest ISO release is v0.10 (Night Train - Sprint 2). Only small ZIP files are available for the later releases. How does the ZIP file work? Do I just overwrite the files from 0.12 on the 0.10 ISO, or can I install the ISO and then apt-get upgrade? :?:
vpetersson
Fri Oct 13, 2017 1:10 pm
You can find the upgrade instructions here:
https://www.screenly.io/ose/
tl;dr: run
bash <(curl -sL https://www.screenly.io/install-ose.sh)
YuppSirup
Sat Oct 28, 2017 9:33 pm
Hi all,
hope I am not hijacking a thread here but can anyone help me with my problem? I am a total noob to Raspberry Pi. I bought a Pi Zero W and installed Screenly on it. Edited the init file to connet to my wifi. On startup it gets an ip address form dhcp server but the Pi zero w is not connected when I try to reach it in a browser..
How can I solve this... please help
https://www.youtube.com/watch?v=0hnojzaY-3k
vpetersson
Sun Oct 29, 2017 2:32 pm
My best guess would be that it dropped the wifi connection. It appears as it was able to retrieve an IP from the DHCP server, so it was able to communicate with the router briefly at least.
I'd recommend that you power cycle it. If the same thing happens, try moving it closer to the router (the antenna is very small in the Pi). Also, try running "iwconfig" to see what it reports.
Hi all,
YuppSirup
Sun Oct 29, 2017 5:32 pm
Thanx for replying Petersson,
I have 2 questions:
1 what is power cycling? How do I do that? (off and on?... I did that already a few times... problem remains)
2 How do I use iwconfig? The Screenly image goes straight to the screenly application
YuppSirup
Mon Oct 30, 2017 10:14 am
If I place the RP Zero on top of the router the problem remains: not connected
What can cause this problem????
vpetersson
Mon Oct 30, 2017 10:44 am
Definitely something funky with the networking.
Regarding iwconfig, check the manpages: https://linux.die.net/man/8/iwconfig
Also, check system logs for clues.
vpetersson
Re: CGI MJPEG stream not loading
Sun Nov 12, 2017 12:00 am
ckambiselis wrote:
Sat Nov 11, 2017 4:08 pm
So I got Screenly installed a few days ago and have been playing around with it to make an info screen, I got most of the things I want working but the main thing I can't find a way and the original idea of my project is to get two IP cameras (D-Link DCS-5000L) shown, after searching around to find how to get only the video stream without any UI, the stream is an mjpeg.cgi link which works fine in Chrome, but when I add it as an asset and turn it on I only get a white screen the rest of the content shuffles just fine.
Also is there a way to make a URL loaded image to show fullscreen even if it's resolution is smaller?
Oscar
Hi Oscar,
This one is a bit tricky. The tl;dr is that we added support for RTSP feeds in ticket #90 (https://github.com/Screenly/screenly-ose/issues/90). I'm not sure if this is supported by this particular camera. If it is, then we should be able to support it.
ckambiselis
Sun Nov 12, 2017 9:29 am
Hi Oscar,
In the beginning I was searching for an RTSP URL but couldn't find anything in the camera settings or on Google, the only thing I found working through the browser and VLC is http://camera_ip/video/mjpg.cgi , I was trying to find a way to read the CGI script, in case there was a different URL in it, but can't find a way yet.
Oscar
