SvenHz
Re: TinyTOSLINK (digital audio output) now for B+, too
Mon Jan 23, 2017 2:32 pm
Hi, if your TinyTOSLINK works on a Raspberry Pi 2 model B, I am very interested, please let me know, my location is The Netherlands.
BenjaminKe
Tue Jan 24, 2017 8:27 am
Hi doctom, SvenHz,
yes the board works for a Raspberry Pi 2 Model B ;)
Both of you got a PM.
Best Regards
Benjamin
Fischman
Sun Feb 12, 2017 12:52 pm
BenjaminKe wrote:Update: new transmitters from Aixin
I now also have DLT2153 transmitters - all new boards will be shipped with these which are better compatible for 192kHz/24Bit and also a little bit smaller than the PLT133.
You can also contact me if you only need such a transmitter (and not a full board).
Receivers (DLR2153) are also available.
Best Regards
Benjamin
Hallo Benjamin,
Ich hätte Bedarf an einen DLT2153 und einen DLR2153, kann dir aber keine PN senden, warum, keine Ahnung?
Eventuell, weil frisch angemeldet.
Beste Grüße Fischman
Sun Feb 12, 2017 2:29 pm
Fischman wrote:
Hallo Benjamin,
Hello Benjamin,
I would need a DLT2153 and a DLR2153, but you can not send PM, why, no idea?
Possibly because I'm freshly registered.
Best regards Fischman
Please write in English on the main part of the forum. Use Google Translate if English isn't your first language.
Bitte schreibe in englischer Sprache auf dem Hauptteil des Forums. Verwenden Sie Google Translate, wenn Englisch nicht Ihre erste Sprache ist.
New users can send private messages as soon as their first post is approved.
Neue Benutzer können private Nachrichten senden, sobald ihr erster Beitrag genehmigt ist.
Microprocessor, Raspberry Pi & Arduino Hacker
Mainframe database troubleshooter
MQTT Evangelist
Twitter: @DougieLawson
2012-18: 1B*5, 2B*2, B+, A+, Z, ZW, 3Bs*3, 3B+
Midask
Sun Feb 19, 2017 12:13 am
Hi Benjamin,
I'm thinking about upgrading my Rpi2 to Rpi3 and I don't know if it's a good idea to remove the TinyTOSLINK from Rpi2 to put it on Rpi3. I've seen that I don't need to buy an other box because it's the same board.
However, it seems so fragile that I don't want to risk to break it. Do you think it's a good idea ?
Thanks for your answer and your awesome board :)
BenjaminKe
Sun Feb 19, 2017 9:31 am
Hi Midask
I tested all tinyToslink boards on one of my Pi2 and never broke anything so it should be no problem to remove it ;)
The only thing yoh need to take care of is that you dont bend the Pi too much.
Just move the tinyToslink board back and forth and pull it down softly.
I always lay the Pi on the desk take the tinyToslink board in both hand, move it back and forth and pull it down softly while pressing the Pi on the desk with 2 fingers.
Its a little bit hard to describe here :)
Just be careful then it should be no problem ;)
Best Regards
Benjamin
Midask
Sun Feb 19, 2017 10:11 am
Hi Benjamin,
Indeed, it should not be a problem, I haven't thinking that you test all tiny toslinks on the same Pi :)
Thanks for your answer !
cilard
Sat Mar 11, 2017 4:16 pm
Hi Benjamin
I am considering one for my RPi B+. But I might upgrade to RPi3 soon, so is it compatible with both? How can I get one, I'm located in Slovakia.
Tomas
BenjaminKe
Mon Mar 13, 2017 8:21 am
Hi Tomas,
yes it's compatible for both (for all Pi's with 4 USB Ports).
I'll write you a PM.
Best Regards
Benjamin
robvk
Tue Mar 28, 2017 6:01 pm
I have some questions. I hope someone can answer those!
Is it possible to use the GPIO for other purposes after installing this board (on a Pi 3)? I want to install an IR-receiver and a 433MHZ sender/receiver as well.
And what is the difference between the TinyToslink and for example https://goo.gl/FFXRSm this? Size only or more differences?
BenjaminKe
Tue Mar 28, 2017 8:01 pm
Hi
Basically the hardware is almost the same - the audio processor is the same and for the optical transmitter and crystal I'm not sure what they use - I'm using a really good transmitter from aixin for my board and a very accurate crystal and it works flawless all up to 192kHz/24Bit audio.
The biggest advantage is for sure that my board is really small and you have some IO ports left in the middle where you can plug something else - for example your receivers/transmitters (I have connected a LED Stripe with 200 LEDs to the SPI port for Ambilight) - so yes you can use these pins for something else ;) - and it will fit in almost any case (for the big PiFy board you need a special case).
Best Regards
Benjamin
rpitime
Mon Apr 03, 2017 6:52 pm
Hi Benjamin,
thanks for good work. I believe you have solved my problems.
I am very interested on a TinyTOSLINK for my Raspberry Pi 3.
Best Regards
Jens
robvk
Sun Apr 16, 2017 7:38 am
I have just received my TinyToslink, thanks for the great service Benjamin! Nice little device.
I am about to install it and I have some questions. I would like the GPIO for other things beside the TT. I could use the pins in the middle that are not covered by the TT but I was wondering what about the rest. Looking at the schema on p.6 of this threat I concluded that the pins that I marked with yellow are used by the TT. Is that correct? For the moment I won't need anything besides 5v - but theoratically - could I use all the other pins?
For now I just need 5v for an IR-sensor. Any best practice advise on how to do this? Solder it to the bottom of the RPI, or to the bottom of the TT maybe? Cut away part of the pin-cover from the TT so I can reach the pins on the RPI and solder it there?
Edit: I'll just use 3v from the pins in the middle, which also seems to work for the IR-receiver. So problem solved. Although I'm still curious about the other options.
BenjaminKe
Sun Apr 16, 2017 7:20 pm
yes you could also use the other pins - not all are used by the tinyToslink.
If you send me your email address I can send you the details of the pin usage.
Best Regards
Benjamin
nixer
Sun May 28, 2017 11:06 am
Hi Benjamin
Could one for my Pi3 be shipped to Denmark?
Best regards
BenjaminKe
Mon May 29, 2017 9:49 am
yes sure.
I sent you a PM.
Best Regards
Benjamin
Abnorm
Fri Jun 16, 2017 4:21 pm
Hi Benjamin,
is it still possible to order one for my rpi3 ?
I'm located in Norway
thanks !
BenjaminKe
Mon Jun 19, 2017 5:43 pm
Hi
sure :)
you got a PM ;)
Best Regards
Benjamin
Blondefreak
Fri Jul 28, 2017 8:24 pm
Hello Benjamin,
after investigating to get a good audio output for my Raspi i found your great solution.
First of all thanks to Jörg, you and all others who were involved in the development.
Now i'm having some questions:
-Which raspi is compatible with the tinytoslink board?(Zero?, 1B+, 2B, 3B) I would think? My suggestion is from the official wikipedia site as a result of the GPIO Pins from the technical data.
https://en.wikipedia.org/wiki/Raspberry ... ifications
-Is it possible to get some of these to Germany?
Please PM me.
Thanks for all.
Best Regards
Sebastian
BenjaminKe
Sat Jul 29, 2017 5:38 pm
Hi Sebastian,
basically it's compatible to all PIs with the 40 pin header (Zero,1A+,1B+,2B,3B).
The other ones could be connected with a cable (1A,1B), but it doesn't fit directly.
Yes sure shipping to Germany is possible (I'm from Austria) - I'll send you a PM :)
Best Regards
Benjamin
Loomis
Thu Aug 24, 2017 8:27 am
Hi, can you send me a PM concerning the PIN usage and the price (I live in Germany). I do not know how to send you a PM, unfortunately.
timbo89
Tue Sep 05, 2017 12:03 am
Are these still available?
If so, what is the cost, and are you able to ship to Australia?
BenjaminKe
Tue Sep 05, 2017 9:11 am
Hi
Yes sure :)
20€ for the board + 10€ for shipping to Australia.
Can you pay via bank transfer? Or paypal?
Best Regards
Benjamin
