tktbjp
Accessing Internet from Pi using USB Tethering of Android
Mon Nov 03, 2014 9:51 am
I post this since it saved me a cost of buying a wifi-adapter and provided useful insight of pi-configuration.
I wanted to access internet from PI. There were 2-3 options.
1. Use Ethernet port.
Since I use wifi all the time, I do not have mechanism to connect my wifi router to LAN port. Although I guess it would have worked simply since I have LAN connector on router as well as on PI. But I had to buy another dataplan since router was dsl. But
2. Buy wifi-adapter and connect same to pi as mentioned in various articles.
Costly affair..
3. Use USB-tethering option of my smartphone.
I have Xperia-U and I use USB tethering option to connect my laptop to internet sometimes. This option I wanted to explore for connecting to internet. Then I could use same data plan everywhere.
So let me explain 3rd option.
On PI-B+ (which I purchased recently) have 4 USB ports. 2 are taken by keyboard and mouse already. One of the remaining can be used to connect to phone.
The default config file used by networking is /etc/network/interfaces works with wifi (wlan0) or eth(eth0) type of interfaces. It does not have entry for tethered device which android provides.
So we need to edit this file on Pi and add entries to it for usb (usb0).
#cat /etc/network/interfaces
auto lo
iface lo inet loopback
iface eth0 inet dhcp
allow-hotplug wlan0
iface wlan0 inet manual
wpa-roam /etc/wpa_supplicant/wpa_supplicant.conf
iface default inet dhcp
The edit the file to provide hotplugging feature for usb0 type of interface which gets created when u start usb-tethering from android phone.
Add below entries at the end of /etc/network/interfaces file.
allow-hotplug usb0
iface usb0 inet dhcp
and then save the file.
You need to restart the board or networking using #sudo /etc/init.d/networking restart
Once this is done connect the phone to Pi using usb cable.
Enable data on android and wait till it activates and then enable USB tethering.
To see if the device is tethered, open a LXterminal session on pi and type #ifconfig
You should see interface usb0 is up and running with a valid IP assigned to it.
The open web-browser and it should be working fine.. :geek:
So you can use your android smartphones usb-tethring for connecting Pi to internet.. :geek:
Dijital
Re: Accessing Internet from Pi using USB Tethering of Androi
Fri Nov 28, 2014 12:45 pm
You young man have just saved me about a four days worth of waiting :)
THANKS!
Monica3712
Fri Feb 27, 2015 4:15 pm
Hi.I have interfaced the raspi(B+) to my laptop and followed your method .It is not working .Can you please let me know if I have to do some modifications or no.Thanks in advance.
tktbjp
Mon Mar 09, 2015 9:31 am
tktbjp
Mon Mar 09, 2015 9:32 am
Monica3712 wrote:Hi.I have interfaced the raspi(B+) to my laptop and followed your method .It is not working .Can you please let me know if I have to do some modifications or no.Thanks in advance.
The method I suggested was to interface usb-device to raspberry-pi B+.
I did not get when you say "Interfacsing with PC"? Can you please elaborate?
rt93
Mon Mar 16, 2015 6:42 am
Will this work on the laptop too??
sumo
Sat Apr 18, 2015 1:19 pm
I have followed each step carefully as instructed.While pinging pi is sending the packets but it isn't receiving any.USB0 has been configured but I couldn't access any site. can anyone please help
Lark
Sun Jun 28, 2015 11:32 am
I have tried to adjust the file interfaces/etc/network a few times (to apply tethering through my phone & tablet) but every time I try to save the file it returns an error message 'can't open file to write', what am I to do?
thanks in advance, NM
(just to clarify I am a complete newbie to all of this)
drgeoff
Sun Jun 28, 2015 12:15 pm
@Lark
Try
sudo nano /etc/network/interfaces
If that works then Google sudo.
Lark
Wed Jul 01, 2015 12:28 pm
@drgeoff thanks that's sort of worked, I now have three new (interfaces.save/1/2) files but I still can't edit them as all permission is set to root
still reading into sudo
Lark
centurion555
Thu Apr 28, 2016 8:45 am
Thanks, the above instructions work for me. But every time, I connect an android phone, I have to restart otherweise there is no internet. My problem is I am using pi for some automated jobs and it is running without monitor and keyboard so I can't restart it or restart networking every time I connect the smartphone for internet. Is it possible to make it fully automated.... I just connect my phone and turns on usb thethering on the phone and it works without any furthur steps..... Thanks in advance
Redryno
Thu Jul 07, 2016 1:45 pm
I had an issue setting this up and have spent the last few days trying to figure it out. There is a lot of information on several forums but i couldn't find a solution to this problem.
Problem: when i set the tablet to tether i ran "dmesg" in the console and it would come back "can't set config #1, error -110". When i ran "ifconfig" usb0 wouldn't show up at all.
Solution: on the tablet under "Developer tools" (how to unlock tools http://bit.ly/29kTttE) i turned on "usb debug". Steps to connect are: plug in usb, turn on usb debugging then turn on usb tether. Reverse to disconnect.
I'm using x11vnc on Rpi port 0 (so i see the desktop), Real VNC on the Android tablet. In the /etc/network/interfaces i used static (so i know the ip address when connecting)
iface usb0 inet static
    address 192.168.42.42
    netmask 255.255.255.0
P.S. if i am using just the tablet as my screen i can't see a usb mouse that is plugged into the Rpi move on the VNC viewer, but i can see anything typed on a usb keyboard (not a fan of the Android software keyboard, drag and tap mouse is okay).
NuclearFusion
Tue Jul 19, 2016 6:46 am
Hello. Was just wondering if it would be possible to do the exact opposite, as in using the pi to give wifi access to my android phone via usb tethering. If it is possible how would I do it? Thanks for any info.
Tue Jul 19, 2016 7:21 am
NuclearFusion wrote:Hello. Was just wondering if it would be possible to do the exact opposite, as in using the pi to give wifi access to my android phone via usb tethering. If it is possible how would I do it? Thanks for any info.
It is "USB Reverse Tethering" though most Android Devices require Root Access, but there is an App which I personally have not tried:
https://play.google.com/store/apps/deta ... ering.free
Lots of hits on Google as well..
Retired disgracefully.....
clem--22
Sun Nov 06, 2016 1:35 pm
Thank you tktbjp for your topic. I would like to use your methode to replace my "poor cable home connection" ^^. However, I've a problem (I've run traceroute to diagnose the problem) :
- My phone in Tethering connection is good detected by the Rpi but I can't go on Internet from Rpi
- It's work when I use my Wifi connection from phone to my cable home connection.
- From my phone, I can go on Web with 4G
So the problem come from the 4G interface of my phone. Someone have an idea how to fix that ?
Thanks in advance :)
nahueltaibo
Tue Mar 28, 2017 7:48 pm
This worked perfectly on my RPi 2.
Nevertheless, I tried to make it work on my Rpi Zero W without success, I think it might be because I'm using an OTG cable to be able to connect both micro USB connectors in the RpiZeroW and in the Android phone.
The Android phone does not recognize the RpiZero as connected, hence, the USB tethering is grayed out.
Any idea on how can I solve this?
I tried with the USB OTG cable on both ends (Rpi and Android) without success on either case
TimJSamuels
Fri May 19, 2017 1:37 pm
Just a simple comment, I typed it out in nano as it was blank than saved it after deleting the "ect/network/" part ctlO then ctlR.
I'm a newbie but thorough it might help.
donde123
Fri May 26, 2017 2:31 am
Type this:
It will bring up the file you need to edit.
Add what you want to the bottom of file.
Then save file this way:
Hold Ctrl key down and hit o not zero
Release Ctrl key and hit Enter
Hold Ctrl key down and hit x
The file is now saved with the added info.
sathishdorai
Re: Accessing Internet from Pi using USB Tethering of Android
Sun Apr 08, 2018 4:56 pm
Hi tktbjp
Could you make one same detailed description for hooking on a USB modem to RPi...?
dipen
Fri Oct 26, 2018 2:46 pm
Namaste tktbjp,
This post of yours helped me in achieving USB Tethering on RPi 3 Model B+ using a mobile phone. I could browse thorough the internet via USB Tethering.
Many thanks for this post of yours!
Thanks | Regards,
Dipen
MRT9710
Fri Jan 03, 2020 3:38 pm
Follow the instructions on Raspberry Pi:
Take into consideration that we imagined the phone virtual interface of the Raspberry Pi is `usb0 `.
1. Set a static IP address to the `eth0` which would be the router's clients' default gateway. To do it, there is plenty of procedure:
sudo nano /etc/dhcpcd.conf
Put lines below to this file:
    interface eth0
    static ip_address=192.168.100.254/24
2. Install the DHCP server package:
    sudo apt-get -y install dnsmasq
3. Configure the DHCP server. At first, create a backup of the config file:
    sudo mv /etc/dnsmasq.conf /etc/dnsmasq.conf.bak
    sudo nano /etc/dnsmasq.conf
    interface=eth0
    listen-address=192.168.100.254
    bind-interfaces
    server=8.8.8.8
    domain-needed
    bogus-priv
    dhcp-range=192.168.100.10,192.168.100.100,24h
4. Enable IP Forwarding to forward router's clients packets:
    nano /etc/sysctl.conf
Uncomment this line:
    net.ipv4.ip_forward=1
5. Follow these commands for the firewall to allow forwarding between interfaces:
    sudo iptables -t nat -A POSTROUTING -o eth0 -j MASQUERADE
    sudo iptables -A FORWARD -i eth0 -o usb0 -m state --state RELATED,ESTABLISHED -j ACCEPT
    sudo iptables -A FORWARD -i usb0 -o eth0 -j ACCEPT
    sh -c "iptables-save > /etc/iptables.ipv4.nat"
6. Open `rc.local` to add the command for restoring firewall configuration on each RPi startup:
sudo nano /etc/rc.local
Add this line before Exit 0:
    iptables-restore < /etc/iptables.ipv4.nat
7. Make sure that `usb0` is on DHCP mode to get ip address from the phone.
Now, you have configured Raspberry Pi as a bridge for the router to the phone.
Router configuration:
In this step, you must disable any static routes and disable the DHCP server of the router because the DHCP requests of the clients must forward to the RPi interface.
Return to “Advanced users”
