JMK8
bash programming using sed
Wed May 17, 2017 12:12 pm
I have a relatively straight-forward task to do in a bash script using sed. I'm not familiar with bash scripting and even less so with sed. I have a text file like this:
 random text PARTUUID=a5d5af73-01 random text
Obviously I have no control over the hex number. What I want to do is substitute PARTUUID=a5d5af73-01 with /dev/mmcblk0p1 I have gone around in circles trying to do this with sed but no joy -maybe I'm too thick to get my head around it :?
Can anyone help or give me an alternative method?
-JohnK
B.Goode
Re: bash programming using sed
Wed May 17, 2017 12:27 pm
Maybe awk or perl would provide an alternative way of doing the substitution?
Paeryn
Wed May 17, 2017 1:36 pm
JMK8 wrote:I have a relatively straight-forward task to do in a bash script using sed. I'm not familiar with bash scripting and even less so with sed. I have a text file like this:
-JohnK
This should change PARTUUID=... (including all characters from the = up to the first space) into /dev/mmcblk0p1 in the file filename, and backs up the original to filename.bak If you don't want the original file backing up don't pass a string to --in-place. And if you don't want to actually alter the file don't pass --in-place, then the output is sent to stdout rather than rewriting the file.
sed --in-place=".bak" "s,PARTUUID=[^ ]*,/dev/mmcblk0p1," filename
Edit: Just in case there are tabs as well as spaces in there you might want to add \t between the square brackets, and if the PARTUUID= string appears more than once on a line add a g to the end of the search/replace string (otherwise it only alters the first occurrence on a line).
sed --in-place=".bak" "s,PARTUUID=[^ \t]*,/dev/mmcblk0p1,g" filename
She who travels light — forgot something.
JMK8
Fri May 19, 2017 5:26 pm
Thanks guys, I will try this when I get home next week.
-JohnK
Sun May 21, 2017 1:53 pm
JMK8 wrote:. What I want to do is substitute PARTUUID=a5d5af73-01 with /dev/mmcblk0p1 I have gone around in circles trying to do this with sed but no joy -maybe I'm too thick to get my head around it :?
Why? PARTUUID works and is agnostic to the device you're booting. That's why it's in Raspbian Jessie so that the same image works on an SDCard or a bootable USB device (on RPi3).
Microprocessor, Raspberry Pi & Arduino Hacker
Mainframe database troubleshooter
MQTT Evangelist
Twitter: @DougieLawson
2012-18: 1B*5, 2B*2, B+, A+, Z, ZW, 3Bs*3, 3B+
JMK8
Mon May 22, 2017 8:22 am
Dougie - OK here's the long story.
About two years ago I wrote a bash script to clone the Raspberry Pi SD card on a running system. As I said previously I am not much of bash scripter but my script does what I want it to. Except -- when I try to boot the cloned SD card I found it would hang. I found that if edit /boot/cmdline.txt and /etc/fstab on the cloned SD card to replace PARTUUID=a5d.....entries with /dev/mmcblk0pX as appropriate everything works fine when booting the cloned SD card. This is a minor inconvenience since I clone SD cards quite infrequently.
I never bothered to try and fix this until a few days ago when I had an hour or two to spare and I decided to go for the blunt instrument fix of automating the editing of the two files. Hence the request in this forum :)
-JohnK
Mon May 22, 2017 8:57 pm
Use blkid to get the PARTUUID and run with them, it will be 10,000,000 times easier in future.
You can stick PARTUUIDs in /boot/cmdline.txt and /etc/fstab and they "just work".
MQTT Evangelist
Who is online
Users browsing this forum: No registered users and 3 guests
