import os
import sys
import pygame
import curses
#pygame.init()
loop = 0
esc = 0
os.system('clear')
# music files (ogg) must be in a folder, 'music', in same folder as program
os.system('ls -1pR music > files.out')
# open list of files
f = open('files.out', 'r')
# create a list C[ ]
C = ['this','is','a','list']
# empty c
C[:] = []
# read first line of files.out
A = f.readline()
# reads all lines of files.out, places full path to each file in C[ ]
while esc == 0:
if A[-2:-1] == ":":
while loop == 0:
B = f.readline()
if B[-2:-1] == ":":
A = B
if B[-5:-1] == ".ogg":
C[len(C)+1:] = [A[:-2] + '/' + B[:-1]]
if B == "":
esc = 1
loop = 1
else:
A = f.readline()
#init the curses screen
stdscr = curses.initscr()
#use cbreak to not require a return key press
curses.cbreak()
track = 0
breaker = 0
# set up the mixer
freq = 44100 # audio CD quality
bitsize = -16 # unsigned 16 bit
channels = 2 # 1 is mono, 2 is stereo
buffer = 2048 # number of samples (experiment to get right sound)
pygame.mixer.init(freq, bitsize, channels, buffer)
# optional volume 0 to 1.0
pygame.mixer.music.set_volume(1.0)
# starts pygame clock
clock = pygame.time.Clock()
while breaker == 0:
pygame.mixer.music.load(C[track])
pygame.mixer.music.play()
pz = 1
# check if playback has finished
while pygame.mixer.music.get_busy():
clock.tick(30)
# python curses to 'get' keyboard input
k = stdscr.getch()
# press b to pause/play track
if curses.keyname(k)=="b":
if pz == 1:
pygame.mixer.music.pause()
pz = 2
else:
pz = 1
# press n to move to next track
if curses.keyname(k)=="n":
pygame.mixer.music.stop()
# press v to go back a track
if curses.keyname(k)=="v":
track = track -2
# press q to quit
if curses.keyname(k)=="q":
pygame.mixer.quit()
breaker = 1
curses.endwin()
track = track + 1
# check track number isn't less than first track
if track < 0:
track = len(C) + track
# check track number isn't more than last track
if track > len(C) - 1:
track = 0
Any improvements to the current script greatly appreciated. Requires pygame.
Aim of the program is a command line jukebox with keystroke detection for moving through tracks.
Matthew
