HypnoToad
Has anyone managed to use 'avconv' to encode 4k video?
Mon May 01, 2017 1:07 am
on Jessie?
I'm trying to encode some still frames taken from the camera and would like to view them on a 4k display, but I'm getting 'malloc' errors.
I've encoded videos in the past at lower resolutions without issue.
Here's the command line I'm using:
avconv -i %04d.jpg -c:v libx264 -crf 20 -preset slow -vf scale=2880:2160 c:a copy ../4k_test.mp4
and here is the error message I get:
x264 [error]: malloc of size 19779248 failedme=10000000000.00 bitrate=   0.0kbits/s
Video encoding failed
Killed
Is there a way of getting this to work?
Re: Has anyone managed to use 'avconv' to encode 4k video?
Tue May 02, 2017 8:52 am
Hmm , a 19MB allocation doesn't seem too bad, but it depends what has already been allocated. Some sort of swap space would help, but it would be quite slow.
“I own the world’s worst thesaurus. Not only is it awful, it’s awful."
HypnoToad
Wed May 10, 2017 12:15 am
Thanks, I'll try setting up a swap file and see if I still get the same problem.
Return to “Raspbian”
