Venturer
Openning Serial Ports
Thu Aug 02, 2012 5:54 pm
I have been going round in ever decreasing circles for the past few days trying to connect to the serial port on the GPIO.
I have installed PySerial and I have tryed to add the pi user to the dialout group with:
sudo usermod -a -G dialout pi
which returns without error.
When I try to connect to '/dev/ttyS0' i get file or directory not found.
I have tried '/dev/ttyAMA0' and get permission denied
1) which is the correct device name to use?
2) How do I get permission to open it?
Thanks,
Steve
timhoffman
Re: Openning Serial Ports
Fri Aug 03, 2012 1:18 am
Hi
You need to use /dev/ttyAMA0
But this requires you do a few things.
1.Make sure your userid (default is pi) is a member of the dialout group. (which your usermod command did)
2. You need to stop the getty running on the GPIO serial console.
To do this you need
- remove references to /dev/ttyAMA0 from /boot/cmdline.txt - which sets up the serial console on boot.
In my case old contents
dwc_otg.lpm_enable=0 console=ttyAMA0,115200 kgdboc=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 rootwait
and new contents
dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 rootwait
Also you need to disable the getty on that serial port in /etc/inittab
Comment out the following line
#2:23:respawn:/sbin/getty -L ttyAMA0 115200 vt100
Oh and reboot ;-)
Cheers
Tim
Venturer
Fri Aug 03, 2012 6:51 pm
Tim,
Thank you for that information. I have done the changes and I can now open ttyAMA0 and (apparently) write to it.
The contents of my two files were slightly different. When I have confirmed I am actually send the data (I have to do a bit of hardware first!) I shall post the complete sequence I have done in case it helps someone else.
Steve
rmashrmash
Sat Mar 08, 2014 7:33 pm
Thanks very much. This worked nicely for me.
AndrewS
Mon Jun 23, 2014 8:40 pm
I wrote a little script to make it easier to disable (and re-enable) the getty https://github.com/lurch/rpi-serial-console
tribesh
Fri Jan 27, 2017 8:50 pm
I did as AndrewS advised. But it lead to "no directory found"; instead from "permission denied".
I'm using Pi model B rev1 Raspbian Pixel
EmmanuelCaster
Wed Apr 19, 2017 6:23 pm
Please any update on this issue for Raspbian Jessie Pixel Since /etc/inittab is no longer? plus I already checked this link posting.php?mode=reply&f=66&t=123081&si ... be0bf8126c and I couldn't coin a solution out of it
klintkrossa
Fri Apr 21, 2017 4:08 pm
I have noticed that raspi-config the serial port is not enabled. ???? :|
This is not like any other bulletin boards that I have been on. Been flamed on other BB's so bad I was afraid to ask.
All my Raspberry Pi's are like the Hessian artilleryman of Sleepy Hollow.
nathan.t.holder
Tue Aug 29, 2017 2:48 pm
Hi
To do this you need
and new contents
Oh and reboot ;-)
Cheers
Tim
Does not exist on my raspbian machine!
/etc/inittab
Tue Aug 29, 2017 10:32 pm
/etc/inittab hasn't existed since Jessie arrived with systemd - two years ago.
The console getty is started with a systemd service file.
Return to “Python”
