lucaspeed
Natural scrolling with Jessie
Thu Feb 16, 2017 1:33 pm
Hi, I tried almost everything to solve this problem.
I can't enable natural scrolling.
I tried using Xmodmap, I tried modifying /usr/share/X11/xorg.conf.d/10-evdev.conf, tried even dconf editor to no avail.
Anyone can help me?
ktb
Re: Natural scrolling with Jessie
Thu Feb 16, 2017 2:31 pm
You probably need to configure it using libinput -- https://wiki.archlinux.org/index.php/Li ... on_options
nu-bo
Sat Apr 01, 2017 4:24 pm
I have this same question. Have you solved it? Could you please explain how to "configure it using libinput"?
nu-bo
Sat Apr 01, 2017 5:49 pm
lucaspeed wrote:Hi, I tried almost everything to solve this problem.
Anyone can help me?
I had this same question. Thankfully other people have solved this! There are a couple of ways to enable natural scrolling:
1) Via a Terminal command - described here: http://www.cheesed-off.com/137_reverse-scrolling/
This is easy but has to be run after every reboot.
2) By changing the file /usr/share/X11/xorg.conf.d/10-evdev.conf https://jamesmcdonald.com/2011/07/inver ... in-debian/
Remember to go into the root directory (with cd /..) and use sudo nano /usr/share/X11/xorg.conf.d/10-evdev.conf to open the file editor. Add the line of code as described and press <ctrl>O to save changes before exiting.
Hope that helps! Works for me on RPi 3B running Debian Jessie.
Return to “Beginners”
