kelster101757
Raspberry PI Sense HAT increase acceleration to 100 readings
Fri Mar 24, 2017 11:49 am
I have a Raspberry PI sense hat. It only records 10 entries a second for the acceleration. Is there anyway this can be increased to 100?
ShiftPlusOne
Re: Raspberry PI Sense HAT increase acceleration to 100 read
Fri Mar 24, 2017 12:24 pm
In the RTIMULib.ini file, looks for the LSM9DS1 settings. You can set the sample rate and filter parameters in there.
kelster101757
Fri Mar 24, 2017 1:57 pm
ShiftPlusOne wrote:In the RTIMULib.ini file, looks for the LSM9DS1 settings. You can set the sample rate and filter parameters in there.
OK brill, I'll be programming the solution in NodeRed. Will that work on that platform too?
ShiftPlusOne
Fri Mar 24, 2017 2:02 pm
Depends on what it does. If it's calling rtimulib functions, yes.
kelster101757
Fri Mar 24, 2017 2:40 pm
ok, ill test it out and post back so other people know.
kelster101757
Fri Mar 24, 2017 9:20 pm
I found the file in "/etc" and opened it in leafpad, changed the ini but it says "cant open file to write". Any ideas why?
Fri Mar 24, 2017 9:39 pm
Use sudo leafpad in an LXTerminal window.
Note:Having anything remotely humorous in your signature is completely banned on this forum.
EGotfred
Re: Raspberry PI Sense HAT increase acceleration to 100 readings
Fri Oct 13, 2017 4:15 pm
question to kelster101757: did you find out if node-red uses the RTIMULib.ini file ?
other question: i expect it to be the Hz that should be changed ti increase the readings to 100 pr. sec.
I am not at all into electronics, so:
- how can it be that it is different for all movement-sensors?
- And what should be the new values
Return to “Astro Pi”
