As some of you know, I'm a newbie to this stuff but I've been having an interesting read of:
http://www.raspberrypi.org/phpBB3/viewt ... 0&p=104473
I was wondering if its beneficial to have an on/off switch because its going to get tedious to keep pulling out the plug
Is there something like this that could act as an on/off switch:
this (1)
If the above example (which is the only one i can find) was used, you'd also need: (2)
this (2)
Then you'd plug the switch (1) into the Pi and plug the convertor (2) into the switch, then plug the power cable into the converter... Then just use the switch to cut off the power instead of the wall socket/plug. (mines in a awkward place behind my desk).
The question is, does that on/off switch act as on/off power or on/off syncing for phones???
I can't help but think if there was an answer to this, someone would already have found it
Thoughts?
