1dot0
how to assign hotkeys to programs or bash scripts (desktop)?
Thu Mar 16, 2017 3:27 pm
hi,
how is it possible to assign hotkeys to programs or bash scripts in order to start them, which I have put on my desktop ?
e.g., ctrl+alt+F8, ctrl+alt+F10, alt+z, a.s.o. ?
TracyLBaker
Re: how to assign hotkeys to programs or bash scripts (deskt
Thu Mar 16, 2017 4:14 pm
I've not done this, but it look likes it is explained well here:
http://www.epiguru.com/2012/06/how-to-c ... and-xvkbd/
and another explanation here:
http://unix.stackexchange.com/questions ... sh-scripts
apt-cache search xbindkeys
and
apt-cache search xbindkeys-config
both show the packages are available for the Pi.
Red Hat Academy Professor - Estrella Mountain Community College
5 Pi 3 Model B+s: 1 headless media/NFS/SMB server - Raspbian Jessie, 1 Kali Linux w/fruitywifi, 1 headless CentOS 7 webserver (Apache, SELinux, firewalld, autofs, etc...), 2 in waiting
1dot0
Fri Mar 17, 2017 11:35 am
thank you, I actually was hoping one could make an entry in kind of file properties as it works for Windows, renouncing the launch of extra programs running then in the background.
KLL
Fri Mar 17, 2017 12:21 pm
i changed only the [print] screen..and added the [Alt][print]
nano .config/openbox/lxde-pi-rc.xml
    <keybind key="A-Print">
      <action name="Execute">
        <command>scrot -u Desktop/share/%Y-%m-%d_%H-%M-%S_snap.png</command>
      </action>
    </keybind>
    <keybind key="Print">
        <command>scrot Desktop/share/%Y-%m-%d_%H-%M-%S_snap.png</command>
      </action>
    </keybind>
to start scrot and make pictures of screen or active window in my samba shared /Desktop/share/ dir.
i think this is the right place as there you will find what key is used already??
1dot0
Sat Mar 18, 2017 8:24 am
thank you, I will also consider that, although I must admit that this openbox solution is also far more complicated than I expected a solution to be. Just an entry in the file properties itself would be the most convenient solution, but I see that this not available for Jessie.
scruss
Sat Mar 18, 2017 2:17 pm
Yes, OpenBox/LXDE are pretty lightweight systems, so editing files it has to be.
Return to “Beginners”
