FM81
Merge two 'asound.conf' into one?
Sat Mar 11, 2017 4:16 pm
Hi at all!
Using a raspberry zero together with the "Adafruit Stereo Bonnet 3W". By default is following '/etc/asound.conf' recommended (variant 1):
pcm.!default {
 type hw card 0
ctl.!default {
 type hw card 0
Works, but gives an annoying "PLOP" during start and/or stop.
Can be avoided by using this (variant 2):
pcm.hifiberry {
type hw card 0
pcm.!default {
type plug
slave.pcm "dmixer"
pcm.dmixer {
type dmix
ipc_key 1024
slave {
pcm "hifiberry"
channels 2
ctl.dmixer {
type hw
card 0
OK, but there is no volume-regulation ... By hardware it isn't in general, and in software it can be enabled in this way (variant 3):
pcm.softvol {
 type softvol
 slave {
   pcm "plughw"
  control {
   name "SoftMaster"
   card 0
pcm.!default {
 type plug
 slave.pcm "softvol"
But the "PLOP" is back! :(
Long text, short question: How can I combine variant 2 and variant 3, to get no "PLOP" and software-volume-regulation?
Simply copying (2) and (3) in a big merged one didn't work, already tested.
And I'm using the file in '/etc/' because it should become a system-wide setting, not only for one user.
Thank you, FM_81
PS: No, this is not question about Pulse-Audio!
A: What does the command 'cat /dev/urandom', can you tell me please?
B: Yeah, that's very simple: It feeds your cat with radioactive material!
linux_author
Re: Merge two 'asound.conf' into one?
Wed Apr 05, 2017 9:19 pm
i just installed one of these bonnets today (great product!)... i know what you mean about the 'plop' - i get that too when using a little amp with my other RPi3 music server through its headphone output...
i seem to recall a hardware solution somewhere (the mind drifts, too much 'net info, overload and overflow of the mental buffer)...will do research on this as well
meanwhile, i just live with the 'plop'...
willie
on the 'plopping' Gulf of Mexico
p.s. here's my configuration (which works well with the Raspbian system, VLC and Audacious):
/etc/asound.conf:
pcm.hifiberry {
    type softvol
    slave.pcm "plughw:0"
    control.name "Master"
    control.card 0
pcm.!default {
	type plug
	slave.pcm "softvol"
pcm.softvol {
	slave {
		pcm "sysdefault"
	control {
		name "softvol"
		card 0
$HOME/.asoundrc:
pcm.!default {
	type plug
	slave.pcm "softvol"
pcm.softvol {
	slave {
		pcm "sysdefault"
	control {
		name "softvol"
		card 0
(i select 'hifiberry ((null))' and default mixer type in Audacious; the Raspbian Audio Prefs show 'snd_rpi_hifiberry_dac (Alsa mixer) (Default)')
linux_author
Fri Apr 07, 2017 4:23 pm
doing my first bit of research i found this:
https://01.org/linuxgraphics/gfx-docs/d ... licks.html
more research and experimentation to be done!
willie
on the plopping Gulf of Mexico
FM81
Sun Apr 16, 2017 4:03 pm
This has solved the problem for me: viewtopic.php?p=1147994#p1147994
Thanks, FM_81
