I have bought a 3g dongle, Huawei e3256. Actually it was working out of the box. Just plug it in and access 192.168.1.1 and then i could see the configuration files.
I could see here that earlier versions of the raspberry pi didnt support it out of the box.
viewtopic.php?f=46&t=38392
My problem is that i am trying to setup gammu, to be able of sending and receiving text. Gammu requires me to input a path to the usb dongle, but when i look in /dev/ i dont have anything called USBttyX as i should. When i look in my usb folder, I have a device called hiddev0 but that is my usb touch screen. So how do i find the path to my usb dongle so that i can setup gammu? I dont know if the usb dongle is setup wrong, as it works as an eth1. I can see that i can connected to the internet through the dongle, but i dont need that. I only needs to be able of sending and receiving SMS through gammu.
I really hope somebody can help
Re: 3g Dongle connected and working but....
Boot up without the module connected.
Plug module in and do
again and post the last 10 or so lines
dmesg
dmesg
Without
With
[ 4.848743] systemd-journald[135]: Received request to flush runtime journal from PID 1
[ 5.534546] brcmfmac: brcmf_add_if: ERROR: netdev:wlan0 already exists
[ 5.534573] brcmfmac: brcmf_add_if: ignore IF event
[ 5.540059] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 5.540112] brcmfmac: power management disabled
[ 5.639151] brcmfmac: power management disabled
[ 6.004543] cfg80211: Regulatory domain changed to country: DK
[ 6.004551] cfg80211: DFS Master region: ETSI
[ 6.004551] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 6.004558] cfg80211: (2402000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 6.004563] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 6.004568] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 6.004573] cfg80211: (5490000 KHz - 5710000 KHz @ 160000 KHz), (N/A, 2700 mBm), (0 s)
[ 6.004577] cfg80211: (57000000 KHz - 66000000 KHz @ 2160000 KHz), (N/A, 4000 mBm), (N/A)
[ 6.272037] uart-pl011 3f201000.uart: no DMA platform data
[ 6.610931] Adding 102396k swap on /var/swap. Priority:-1 extents:3 across:208896k SSFS
[ 6.668698] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 6.882521] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 6.882672] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 10.700339] Bluetooth: Core ver 2.21
[ 10.700419] NET: Registered protocol family 31
[ 10.700426] Bluetooth: HCI device and connection manager initialized
[ 10.700443] Bluetooth: HCI socket layer initialized
[ 10.700458] Bluetooth: L2CAP socket layer initialized
[ 10.700487] Bluetooth: SCO socket layer initialized
[ 10.718790] Bluetooth: HCI UART driver ver 2.3
[ 10.718806] Bluetooth: HCI UART protocol H4 registered
[ 10.718811] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 10.718947] Bluetooth: HCI UART protocol BCM registered
[ 10.914051] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 10.914065] Bluetooth: BNEP filters: protocol multicast
[ 10.914079] Bluetooth: BNEP socket layer initialized
[ 323.840096] usb 1-1.2: new high-speed USB device number 5 using dwc_otg
[ 323.971085] usb 1-1.2: New USB device found, idVendor=12d1, idProduct=1f01
[ 323.971110] usb 1-1.2: New USB device strings: Mfr=2, Product=1, SerialNumber=0
[ 323.971123] usb 1-1.2: Product: HUAWEI Mobile
[ 323.971135] usb 1-1.2: Manufacturer: HUAWEI
[ 323.981636] usb-storage 1-1.2:1.0: USB Mass Storage device detected
[ 323.982450] scsi host0: usb-storage 1-1.2:1.0
[ 324.885997] usb 1-1.2: USB disconnect, device number 5
[ 326.460130] usb 1-1.2: new high-speed USB device number 6 using dwc_otg
[ 326.562192] usb 1-1.2: New USB device found, idVendor=12d1, idProduct=14db
[ 326.562215] usb 1-1.2: New USB device strings: Mfr=2, Product=1, SerialNumber=0
[ 326.562229] usb 1-1.2: Product: HUAWEI Mobile
[ 326.562241] usb 1-1.2: Manufacturer: HUAWEI
[ 326.609101] cdc_ether 1-1.2:1.0 eth1: register 'cdc_ether' at usb-3f980000.usb-1.2, CDC Ethernet Device, 58:2c:80:13:92:63
[ 326.609389] usbcore: registered new interface driver cdc_ether
I am able of sending sms using the webpage on 192.168.1.1.
Anybody who can help?
