kramer65
How to get motor running with this H-bridge?
Fri Mar 03, 2017 2:29 pm
A couple years back I bought a simple H-bridge to run and reverse a small DC motor from my Raspi. That worked fine but since the motor was not powerful enough to run what I wanted, I recently bought a stronger motor and the following H-bridge which can actually handle 24V and up to 43A:
Unfortunately there aren't really tutorials to get this thing running with the Raspi. So I got to work myself.
I started by testing if the motor works if I hook it up directly to the battery. That works fine.
Then I had a good look at the H-bridge. There are 4 big wire inputs, marked with B-, B+, M+ and M-
From this tutorial I understand that the B and the M stand for Battery and Motor. So I hooked them up to my battery and motor.
Furthermore, there are 8 small pins on the H-bridge, which are
VCC    R_IS    R_EN    RPWM
GND    L_IS    L_EN    LPWM
From this diagram I found that the left two (VCC and GND) are 5V power supply and ground. So I hooked them up to a 5V and ground pin on my Raspi.
And from this point on it gets tricky. I guess that:
- R_EN and L_EN are used to ENable the motor to turn Right or Left (correct?)
- RPWM and LPWM are used to determine the motor speed using Pulse-width modulation (correct?)
- I have no idea what R_IS and L_IS are for. Does it have something to do with measuring current flowing through?
So if the above is true. I suppose that I can hook up R_EN to a normal GPIO pin and write HIGH to it and at the same time send a 100% pulse width to RPWM to get it to turn right.
Following this logic I hooked up the wires as follows:
and then wrote the following code:
import RPi.GPIO as GPIO
GPIO.setmode(GPIO.BOARD)
R_EN = 11
RPWM = 12
GPIO.setup(R_EN, GPIO.OUT)
GPIO.setup(RPWM, GPIO.OUT)
GPIO.output(R_EN, True)
p = GPIO.PWM(RPWM, 100)  # inspired by https://sourceforge.net/p/raspberry-gpio-python/wiki/PWM/
try:
    while True:
        p.start(100)  # duty cycle of 100%
except KeyboardInterrupt:
    pass
p.stop()
GPIO.cleanup()
Unfortunately, nothing happens, at all. No errors, no movement, nothing.
So I've been trying about a zillion combinations with code and wires, including using WiringPi with Python bindings. And I saw it moving once, for just a fraction of a second. But despite the effort I put into reproducing what I did, it never moved again. I checked the battery directly on the motor again, and that still works, so my battery is still alive.
So from here I'm kinda lost. Since I'm more of a software man I don't really know how to debug hardware.
Can any brighter mind than me give me some tips and hints on what I'm doing wrong or how I can debug this? All tips are welcome!
6by9
Re: How to get motor running with this H-bridge?
Fri Mar 03, 2017 4:36 pm
http://www.hessmer.org/blog/2013/12/28/ ... h-arduino/
http://forum.arduino.cc/index.php?topic=148482.0
1. I think you need to set both ENL and ENR HIGH.
I'd be a little cautious too as to whether you should be feeding 3.3V or 5V to Vcc. With 5V the H-bridge will be expecting 5V logic signals when the Pi only generates 3.3V. You may get away with it, but it may behave erratically.
kramer65
Sat Mar 04, 2017 1:27 pm
Thanks for your tip! In the end I got it to work with only regular GPIO pins and the following code:
import RPi.GPIO as GPIO  # sudo apt-get install python-rpi.gpio
class Driver:
    def __init__(self):
        self.R_EN = 21
        self.L_EN = 22
        self.RPWM = 23
        self.LPWM = 24
        GPIO.setup(self.R_EN, GPIO.OUT)
        GPIO.setup(self.RPWM, GPIO.OUT)
        GPIO.setup(self.L_EN, GPIO.OUT)
        GPIO.setup(self.LPWM, GPIO.OUT)
        GPIO.output(self.R_EN, True)
        GPIO.output(self.L_EN, True)
    def neutral(self):
        GPIO.output(self.RPWM, False)  # Stop turning right
        GPIO.output(self.LPWM, False)  # stop turning left
    def right(self):
        GPIO.output(self.RPWM, True)  # start turning right
    def left(self):
        GPIO.output(self.LPWM, True)  # start turning left
    def cleanup(self):
        GPIO.cleanup()
And in an interactive command line I can then simply do this:
>>> from motorlib import Driver
>>> driver = Driver()
>>> driver.right()  # turns right
>>> driver.left()  # turns left
>>> driver.neutral()  # stops turning
>>> driver.cleanup()
Another step in building my world domination robot :D
EscoR
Sat Mar 03, 2018 9:50 pm
Hi, I know the thread is a bit older, but it's quite difficult to get information about the Raspberry pi in connection with the BTS7960 43A.
I plan to drive a wiper motor (Bosch 9169321) as soon as the Ir-sensor LM393 detects something.
Unfortunately I'm still waiting for the delivery of my power supply, so I can't check if my schematic works like this.
As far as I understood kramer65's comment, the following wiring has been done.
BTS7960 | Raspberry pi
Vcc | +5V
GND | GND
R_EN | GPIO21 (pin 40)
L_EN | GPIO 22 (pin 15)
RPWM | GPIO 23 (pin 16)
LPWN | GPIO 24 (pin 18)
It would be very nice of you to help me out.
Maybe you can post your circuitplan.
A simple "hey that looks very good" is also enough for me:).
http://www.bilder-upload.eu/show.php?fi ... 113760.jpg
