bekos
Rpi password
Sat Feb 18, 2017 5:29 pm
I forgot Rpi password (Menu->Preferences-Raspberry PI Configuration)
Is there a process (sostware) to access it? or to reset ?
k-pi
Re: Rpi password
Sat Feb 18, 2017 6:49 pm
Passwords can be set by using the passwd command in Linux, you need to use sudo or be the root user. :)
Re: Rpi password
Sat Feb 18, 2017 7:13 pm
It's not easy.
You have to edit /boot/cmdline.txt and add
init=/bin/bash
boot the machine use the bash shell that appears on the console to reset the password for pi, then undo the changes to /boot/cmdline.txt.
You can use the NOOBS config editor accessed by holding or tapping [SHIFT] during boot to add that parameter.
If the card has plain Raspbian do the edit with notepad++ on a Windows machine.
bekos
Re: Rpi password
Sun Feb 19, 2017 7:21 pm
DougieLawson wrote:It's not easy.
init=/bin/bash
thanks the password changed :P
tobyewhite
Re: Rpi password
Sun Feb 19, 2017 7:42 pm
A good idea is to use github for all your projects- That way if anything bad happens you can always restore from your last git repo instead of losing everything!
Return to “Weather station”
