For wiring, see https://github.com/nejohnson2/rpi-i2s
For software, you can either follow the steps there, or do it the modern way here using a device tree overlay.
Firstly, get an updated kernel & matching kernel header files:
sudo apt-get update
sudo apt-get dist-upgrade
sudo apt-get install raspberrypi-kernel-headers
sudo reboot
Get the source & create a simple Makefile:
mkdir ics43432
cd ics43432
wget https://raw.githubusercontent.com/raspberrypi/linux/rpi-4.4.y/sound/soc/codecs/ics43432.c
nano Makefile
obj-m := ics43432.o
all:
make -C /lib/modules/$(shell uname -r)/build M=$(PWD) modules
clean:
make -C /lib/modules/$(shell uname -r)/build M=$(PWD) clean
install:
sudo cp ics43432.ko /lib/modules/$(shell uname -r)
sudo depmod -a
Build:
make all install
/dts-v1/;
/plugin/;
compatible = "brcm,bcm2708";
fragment@0 {
target = <&i2s>;
__overlay__ {
status = "okay";
fragment@1 {
target-path = "/";
__overlay__ {
card_codec: card-codec {
#sound-dai-cells = <0>;
compatible = "invensense,ics43432";
status = "okay";
fragment@2 {
target = <&sound>;
master_overlay: __dormant__ {
compatible = "simple-audio-card";
simple-audio-card,format = "i2s";
simple-audio-card,name = "soundcard";
simple-audio-card,bitclock-master = <&dailink0_master>;
simple-audio-card,frame-master = <&dailink0_master>;
status = "okay";
simple-audio-card,cpu {
sound-dai = <&i2s>;
dailink0_master: simple-audio-card,codec {
sound-dai = <&card_codec>;
fragment@3 {
target = <&sound>;
slave_overlay: __overlay__ {
status = "okay";
sound-dai = <&i2s>;
dailink0_slave: simple-audio-card,codec {
__overrides__ {
alsaname = <&master_overlay>,"simple-audio-card,name",
<&slave_overlay>,"simple-audio-card,name";
compatible = <&card_codec>,"compatible";
master = <0>,"=2!3";
dtc -@ -I dts -O dtb -o i2s-soundcard.dtbo i2s-soundcard-overlay.dts
sudo cp i2s-soundcard.dtbo /boot/overlays
dtoverlay=i2s-soundcard,alsaname=mems-mic
pi@raspberrypi:~arecord -l
**** List of CAPTURE Hardware Devices ****
card 1: memsmic [mems-mic], device 0: bcm2835-i2s-ics43432-hifi ics43432-hifi-0 []
Subdevices: 1/1
Subdevice #0: subdevice #0
Make a 10 second long recording with:
arecord -Dhw:1 -c2 -r48000 -fS32_LE -twav -d10 -Vstereo test.wav
The overlay is flexible enough to use other codecs by way of the compatible= override. If your preferred codec, a simple ADC or DAC, has a .compatible string defined, use that "manufacturer,chipset" string in the override. There's a switch "master" too if your codec is capable of working as clock master instead of the default slave (untested).
