funstuff
best torrent cliant for zero torrent only
Sat Feb 04, 2017 1:49 am
Helo I'm prety much a newby.
I was thainking about transmission, Delug or rtorent. But ween I was reading a tutorial on instaling transmission sead it culd not manaeg more than 5 at a time. Made me question transmission.
Odd thaing is after instaling transmission I culd not fig out how to acses it. I tryed 3 dif http from 3 dif tutorial and culd not get a web site to show up.
my aplication is for always on torrent cliant no other use.
Re: best torrent cliant for zero torrent only
Sat Feb 04, 2017 7:52 am
sudo apt-get install transmission-daemon
sudo /etc/init.d/transmission-daemon start
Then point your web browser at http://raspberrypi.local:9091/
This is a doctor free zone.
atvpn
Sat Feb 04, 2017 3:06 pm
DougieLawson wrote:sudo apt-get install transmission-daemon
Thank you for your instruction. Unfortunately I run into a 404/403/401 situation. http-ing to raspberrypi.local results in "Page not found". Using localhost.local or the actual hostname lets pop up a login window and neither the default pi/raspberry nor the actual user/password combination give access. So 401 unauthorized.
Please elucidate further
Thank you
Update:
Reading the settings.json file helps a lot. Username is transmission pw - you would never geuss - is transmission.
Sat Feb 04, 2017 3:26 pm
Use the IP address for your RPi rather than raspberry.local
funstuff
Sun Feb 05, 2017 1:09 am
well ty It turns out the tutorials I went thru wer rong on the seting's wightlist ip. I saw multipul times that I can edit the file to have "*.*.*.*" for all ip adress's. But it dos not work for local pc I had to add the local pc's ip adress.
Also thay had the rong cmd for starting and stoping the serves. >_<
EDIT: I see the transmission tl gui on my pi deasctop toll bar. will this lag down my PI zero ?
Sun Feb 05, 2017 1:11 pm
funstuff wrote: I saw multipul times that I can edit the file to have "*.*.*.*" for all ip adress's.
The usual thing is to have 0.0.0.0 (IN_ADDR_ANY) for a listener address as that means it listens on all interfaces and isn't restricted to any specific address block.
funstuff
Mon Feb 06, 2017 4:39 am
ok I have ben trying for 2 days to get transmission + PIA set up. I get error user permistion on all torents after a few minits of downloading. I have an external hdd with ntsf/fat32.
I tryed this one .. "http://raspberrypi.stackexchange.com/qu ... n-usb-disk"
And now its emediatly error.
also what is the line in the transmision json file
"umask": 2,
After lots of reading and frustration. First of all, make sure the normal user has read and write acces to the USB drive. The correct 'non-root' fix for having write acces to the USB drive is:
Step 1: Stop transmission daemon
sudo service transmission-daemon stop
Step 2: Add pi to debian-transmission group
sudo usermod -a -G debian-transmission pi
Step 3: changing the daemon-user
sudo nano /etc/init.d/transmission-daemon
Change USER to pi.
Step 4 Change the rights of the configuration files folder
sudo chown -R pi /var/lib/transmission-daemon/info/
sudo chmod 755 /var/lib/transmission-daemon/info/settings.json
Step 5: Set the correct permissions for the download / incomplete folders
sudo chown -R pi /somewhere/downloads
sudo chown -R pi /somewhere/incomplete
Step 5: Start transmission daemon
sudo service transmission-daemon start
EDDIT: well dame now wen I try to conect to transmission web I get a pop up saying connection Failed and wen I click on details nuthing hapens
EDDIT: I reinstaled transmission daemon and left it at defalt setings and it works fine. But I want to use a external hdd.
Mon Feb 06, 2017 9:50 pm
The transmission daemon ALWAYS overwrites the config file when it closes down. So you MUST close it before you edit your configuration or you WILL lose your changes.
Yes it's insane, yes it's carp programming, yes it's an incredibly bad design, but you can't avoid that.
funstuff
Tue Feb 07, 2017 7:43 pm
ty so much for your time.
I have been all over the place loking for answers on how to hae transmission use an external hdd. I statid in last post it cripeld my system and had to remove programs.
Any sorces or sujestions on how to get transmission to use external hdd ?
Tue Feb 07, 2017 7:56 pm
Mount the harddrive on a mount point in /etc/fstab (in my case it's mounted on /shared). Update your transmission settings.json file with
    "download-dir": "/shared/transmission-daemon/Downloads",
    "incomplete-dir": "/shared/transmission-daemon/incomplete",
funstuff
Fri Feb 10, 2017 12:44 am
so I did eveary thaing you sujested and it works for about 1 minit than I get this error on the web gui "Error:Permission denied(/shared/downloads/xxxx)"
The only thaing I can thaink of is I did chang the umask line in the transission json file. I dont remimber what the defalt value was but I have my file ate "umask": 2,
My hdd has 2 partishionsis fat32 and ntsf.
will it help if I format it to ext4 ?
Fri Feb 10, 2017 8:42 am
Change the mount command (or fstab line) so that you give the mounted filesystem the right uid=xxx and gid=xxx for transmission.
On my system that would need mount -t ntfs-3g -o uid=117,gid=124 /dev/sda1 /shared
The alternative is to format the hard drive as ext4 then the normal Linux owner, group and permissions stuff will "just work".
funstuff
Fri Feb 10, 2017 8:58 am
ok well I went with ext4.
only problem I'm having is wen start up I get emergency mode!
If I remove the fstab editing I put in it sems to help it boot past the emergency mode! I have to remove my edit every time I unplug/power off the zero.
I'm prety sher its becaus motorola lapdock usb ports dont power up untel after the pi starts.
at botum left it says [email protected]
Fri Feb 10, 2017 9:04 am
Add these options ",noatime,x-systemd.automount" to the fstab line.
funstuff
Fri Feb 10, 2017 9:42 am
ok so the line shuld loke like this :
/dev/sdb1 / etx4 noatime,x-systemd.automount 0 0
my hdd folder is back in the /media/pi/xxxx lol
I'm geting Error: Permission after a minit of runing and Error: No data found. I have over half the data for torrents and wen I tell it to verafy local data it git's an Error: No data found.
funstuff
Fri Feb 10, 2017 9:13 pm
I tryed puting :
/dev/sdb1 /shared etx4 noatime,x-systemd.automount 0 0
and now I cant acses "/" directery. Terminal never give me a respons and user desctop folder just has egg timer spining.
Sat Feb 11, 2017 12:05 am
It's "ext4" not "etx4".
funstuff
Sat Feb 11, 2017 12:40 am
ya thats just a typo in the forum.
The only thaing I can get to work is is transmistion using the sd card :(
Sat Feb 11, 2017 12:54 am
/etc/fstab
/dev/sda1 /shared ext4 -o defaults,noatime,x-systemd.automount 0 0
Or
sudo mount -t ext4 /dev/sda1 /shared
funstuff
Sat Feb 11, 2017 1:44 am
well ty so much it turns out sume how I was using the rong partition id O_o
the -o stops raspbery from boting .. is it zero or ow ?
geting Error: Permistions denied on restarting partal files.
geting Error: No data found on new torrents.
EDIT: I had to do this :
chmod -R 777 xxxx
Is this a masive sucerity risk ?
Sat Feb 11, 2017 8:34 am
You should never need to set rwxrwxrwx == 0777 permission bits - it is a security risk, the scale of the risk depends how open you make your system.
Change the ownership with chown to the uid.gid that needs to access the directories and files on that part of your filesystem.
