blaablaaguy
Use app to connect to pi via bluetooth.
Wed Apr 06, 2016 4:53 pm
Theres this app I found and id like to use it with my pi and python. Basically i want to be able to make python stuff happen when a specific button is pressed in the app. Ive got a bluetooth dongle but dont know what version it uses since ive had it for years and its pretty much ancient.
EDIT: Oops forgot to post app... :oops:
https://play.google.com/store/apps/deta ... Controller
This signature intentionally left blank.
Douglas6
Re: Use app to connect to pi via bluetooth.
Wed Apr 06, 2016 6:35 pm
You'll need to add the SP profile to the Pi. Edit this file:
sudo nano /etc/systemd/system/dbus-org.bluez.service
Add the compatibility flag, ' -C', at the end of the 'ExecStart=' line. Add a new line after that to add the SP profile. The two lines should look like this:
ExecStart=/usr/lib/bluetooth/bluetoothd -C
ExecStartPost=/usr/bin/sdptool add SP
Save the file and reboot. Pair and trust your Pi and phone with bluetoothctl.
Now, in a terminal on the Pi, enter the following:
sudo rfcomm watch hci0
Now you can connect from the app and send text or macros. You can read it on the Pi with minicom, or in Python with PySerial or whatever serial comm software you prefer.
blaablaaguy
Wed Apr 06, 2016 7:23 pm
Thanks, ill try it out when im next at my pi.
blaablaaguy
Fri Apr 08, 2016 4:18 pm
Thanks, ive connected to my pi, but how do i use pyserial to read the button presses? Google revealed nothing...
Douglas6
Fri Apr 08, 2016 4:46 pm
blaablaaguy wrote:Google revealed nothing...
Wow, seriously? A search for 'pyserial' returns this (and hundreds of thousands others) : https://pythonhosted.org/pyserial/. PySerial comes installed in Raspbian, for Python 2, anyways.
I used to have some code that read from /dev/rfcomm0. If I can find it or recreate it, I'll post it here.
[EDIT: You can perform a simple test with 'cat /dev/rfcomm0']
blaablaaguy
Fri Apr 08, 2016 5:22 pm
Thanks, got pyserial working!
mukut_mukherjee
Sun Oct 02, 2016 4:02 am
I certainly managed to get a CSR v4.0 bluetooth module which claims itself to be compatible with the pi. So once again will the steps mentioned above work for me?
Douglas, you said to edit that blues bluesman package but is that package included in the is by default or we need to get it. If so then can tell me the command?
Douglas6
Sun Oct 02, 2016 4:54 am
I don't recall ever suggesting to 'edit that blues bluesman package'. Using a dongle versus the Pi3 onboard Bluetooth is identical, although on the Pi3 you'll need to disable the onboard Bluetooth first.
mukut_mukherjee
Sun Oct 02, 2016 6:24 am
Oops sorry it seems I have forgot to tell that I have a pi 2 and not pi3 and I had confused this post with another. I am very sorry and apologise for the inconvenience Douglas.
baruchli
Sat Dec 17, 2016 8:01 pm
Douglas6 wrote:You'll need to add the SP profile to the Pi. Edit this file:
I had followed your suggestions.
Good news: I was able to connect Android (Bluetooth Terminal application) to Pi (when sudo rfcomm watch hci0 is running).
Now I would like to send serial data back and forth. So, the questions:
1. Should I keep Pi Serial interface enabled in this configuration?
2. What port I should config on Pi minicom to observe and send serial data? Is it /dev/rfcomm0? Are there any serial port parameters I should set on minicom for successful data exchange?
3. What is connection between /dev/rfcomm0 and hci0
Douglas6
Sat Dec 17, 2016 8:34 pm
baruchli wrote: 1. Should I keep Pi Serial interface enabled in this configuration?
1. Not sure what you mean. Yes, you will want to keep the rfcomm watch command running.
2. Yes, tell minicom to use the /dev/rfcomm0 port.
minicom -D /dev/rfcomm0
You may need to set the baud rate with the -b flag.
3. hci0 is the Bluetooth adapter. /dev/rfcomm0 is the virtual serial device you told rfcomm to create using that adapter. Since it is the first one, it got named with a zero.
baruchli
Sat Dec 17, 2016 8:55 pm
I speak about this GUI option:
So I should add command
to startup script?
Thank you! Meantime I managed to send bytes back and forward :!:
Douglas6
Sat Dec 17, 2016 9:05 pm
Ah, that 'serial interface' refers to the tty serial, no connection with rfcomm0. Yes, it will probably be convenient to add the rfcomm watch command to start at boot time. Glad you got it working!
