- Make sure you're up-to-date with everything (aptitude update; aptitude upgrade)
- Download the Quake 3 source code .tar.gz from here.
- As root, aptitude install gcc build-essential
- Also as root, aptitude install libsdl1.2debian libsdl-image1.2 libsdl-image1.2-dev libsdl-mixer1.2 libsdl-mixer1.2-dev libsdl-net1.2 libsdl-net1.2-dev (this possibly includes unnecessary stuff and the occasional typo, but it worked...)
- Decompress your source .tar.gz and replace build.sh with the following:
#!/bin/bash # this script builds q3 with SDL # invoke with ./build.sh # or ./build.sh clean to clean before build # directory containing the ARM shared libraries (rootfs, lib/ of SD card) # specifically libEGL.so and libGLESv2.so ARM_LIBS=/opt/vc/lib SDL_LIB=lib # directory containing baseq3/ containing .pk3 files - baseq3 on CD BASEQ3_DIR="/home/${USER}/" # directory to find khronos linux make files (with include/ containing # headers! Make needs them.) INCLUDE_DIR="/opt/vc/include" # prefix of arm cross compiler installed # CROSS_COMPILE=bcm2708- CROSS_COMPILE= # clean if [ $# -ge 1 ] && [ $1 = clean ]; then echo "clean build" rm -rf build/* fi # sdl not disabled make -j4 -f Makefile COPYDIR="$BASEQ3_DIR" ARCH=arm \ CC=""$CROSS_COMPILE"gcc" USE_SVN=0 USE_CURL=0 USE_OPENAL=0 \ CFLAGS="-DVCMODS_MISC -DVCMODS_OPENGLES -DVCMODS_DEPTH -DVCMODS_REPLACETRIG -I$INCLUDE_DIR" \ LDFLAGS="-L"$ARM_LIBS" -L$SDL_LIB -lSDL -lvchostif -lvmcs_rpc_client -lvcfiled_check -lbcm_host -lkhrn_static -lvchiq_arm -lopenmaxil -lEGL -lGLESv2 -lvcos -lrt -lbcm_host -mfloat-abi=hard -mfpu=vfp" # copy the required pak3 files over # cp "$BASEQ3_DIR"/baseq3/*.pk3 "build/release-linux-arm/baseq3/"
- Do a ./build.sh
- Wait.
- Wait a bit more. This is assuming I haven't made any mistakes in the guide.
- Find copies of the following somewhere (other guides will show you) and place in build/release-linux-arm/baseq3: pak0.pk3 pak1.pk3 pak2.pk3 pak3.pk3 pak4.pk3 pak5.pk3 pak6.pk3 pak7.pk3 pak8.pk3
- As root, run ioquake3.arm. Shoot things. (It should work as a non-root user when I figure out the necessary DirectFB incantations.)
