YouTube videos use native H.264 hardware acceleration, not Flash. But Flash video playback is used for e.g. videos on BBC News, and they will indeed work on Chromium with Flash player.Martin Frezman wrote:I, too, was surprised to see Flash player listed there. I thought all these years we had been told that there was and never would be Flash on ARM. Did Adobe have a change of heart?
Does this mean YouTube vids should "just work" in the browser, like they do on X86?
Re: New Raspbian release "2016-11-25"
using HW acceleration with flash player?spl23 wrote: YouTube videos use native H.264 hardware acceleration, not Flash. But Flash video playback is used for e.g. videos on BBC News, and they will indeed work on Chromium with Flash player.
Minimal Kiosk Browser (kweb)
No, just software rendering.gkreidl wrote:using HW acceleration with flash player?spl23 wrote: YouTube videos use native H.264 hardware acceleration, not Flash. But Flash video playback is used for e.g. videos on BBC News, and they will indeed work on Chromium with Flash player.
My 2cents
Adding need to copy/create one file on the boot partition before taking it out of my Win10 machine was trivial
Truely trivial compared to the rest of the setup I normally setup my Pi up with (vnc and samba)
And once PiBakery catches up (Foundation really need to send it out to him a few days before gen release) it'll be even trivialler
It was just a mistake in communication now that the blog entry is up - that explains it much better than one line in the release notes.
Yes the blog is great. Well written and explains the reasoning behind the change.mattmiller wrote:It was just a mistake in communication now that the blog entry is up - that explains it much better than one line in the release notes.
But the first line of the release notes:
does actually say all you need to know to get going in one sentence. What else do you need?* SSH disabled by default; can be enabled by creating a file with name "ssh" in boot partition
- pi-anazazi
"A webcam/CCTV system that a user wants to view while out might well use UPNP to tell the broadband router to punch a hole to allow access"
If you use UPNP you don't need a router/firewall at all...
Kind regards
anazazi
anazazi
- Paul Webster
- Contact: Twitter
What does that mean? I am talking about UPNP on the inside not out over the Internet.pi-anazazi wrote:"A webcam/CCTV system that a user wants to view while out might well use UPNP to tell the broadband router to punch a hole to allow access"
Grumble grumble - might have been better to have the dummy file called ssh.txt
as its not so easy for newbies to create files with no extension in GUI like Windows & Mac
NOOBS has a bigger problem in relation to this:
Windows can't access the /boot partition at all to make the ssh file on a NOOBS setup,
then you really do need a keyboard & monitor attached to the pi to setup ssh...
I was thinking about that too....
It is possible to use a NOOBSCONFIG script with NOOBS or PINN to create an ssh file on /boot during installation of Raspbian. Or a simple mod to partition_setup.sh should also do it. But these are both for offline installations and won't work when installing from the download server over the internet (unless these were incorporated into the download server files).
Maybe we need an option in NOOBS to enable ssh by creating this file?
I just installed the new OS from the web and run straight into this.
While it's the first line in the release notes, the change is very important for everyone expecting to fire up a fresh OS headless and expect the SSH server to be waiting for them.
Also it should also be noted that creating new ssh file in the new running system in /boot was not possible. Had to use raspi-config for this.
Is /boot not the FAT32 partition which Windows can see ? If not then there is a problem there.mikerr wrote:Windows can't access the /boot partition at all to make the ssh file on a NOOBS setup, then you really do need a keyboard & monitor attached to the pi to setup ssh...
On a NOOBS Installer SD card the FAT32 partition visible to a Windows system is related only to the NOOBS Installer itself. The /boot partition for an installed Operating System such as Raspbian is embedded within an extended partition elsewhere on the card. It is that partition that needs to be modified to contain the ssh signal file. But without 3rd-party tools Windows can't make that modification.hippy wrote:Is /boot not the FAT32 partition which Windows can see ? If not then there is a problem there.mikerr wrote:Windows can't access the /boot partition at all to make the ssh file on a NOOBS setup, then you really do need a keyboard & monitor attached to the pi to setup ssh...
I am not able to try this myself yet, but for NOOBS users who want to enable SSH in a default installation, I think this small modification should work...
- Prepare the SD card in the usual way by formatting to FAT32 with SD formatter with format size adjustment on.
- Download the full NOOBS version from http://downloads.raspberrypi.org/NOOBS/ ... v2_1_0.zip
- Unzip the noobs file to the SD card (preferably using 7-zip)
- On the SD card, modify the /os/Raspbian/partition_setup.sh file
- After the 3 lines of sed commands, add the following line:
echo "ssh" >/tmp/1/ssh
- Save the file, safely remove the SD card, put it in your RPi, boot into NOOBS and install Raspbian from the SD card
If you are using NOOBS, you must have a keyboard and monitor connected to the Pi anyway (in order to interact with NOOBS itself), so the /boot/ssh option shouldn't be required; you can just boot the resulting Raspbian install and enable SSH via raspi-config or the GUI config application.
Maybe you have overlooked the silent install and vncinstall options?spl23 wrote:If you are using NOOBS, you must have a keyboard and monitor connected to the Pi anyway (in order to interact with NOOBS itself.)
I agree that the NOOBS Installer does not make much sense without a local keyboard mouse and display, but it isn't true that you must have them.
99% of people who use NOOBS will have a local keyboard and display.B.Goode wrote:Maybe you have overlooked the silent install and vncinstall options?spl23 wrote:If you are using NOOBS, you must have a keyboard and monitor connected to the Pi anyway (in order to interact with NOOBS itself.)
By the time you are getting down to the subset of people who are using NOOBS, without local keyboard and display, who do need to enable SSH, who have no other way of doing it, you are talking about a vanishingly small number of users...
It may be a small number, but such users don't 'vanish': they turn to the forums in confusion and frustration. And historically your free resource of volunteers has tried to help them...you are talking about a vanishingly small number of users...
If there is no SSH why is there no RealVNC?DougieLawson wrote:What collections of morons decided that was a good idea? How brain dead is that?
one or the other.
This is not like any other bulletin boards that I have been on. Been flamed on other BB's so bad I was afraid to ask.
All my Raspberry Pi's are like the Hessian artilleryman of Sleepy Hollow.
I think it's a good decision for the Pi ecostructure. Hope the gaggle IoT device manufacturers out there follow your lead.
PhilE wrote:I was one of the collection, and I stand behind the decision. We have a responsibility to protect our users, and the combination of a known password and an open SSH port is an accident waiting to happen. The majority of Pi users won't even know what SSH is, so disabling it by default is reasonable - can you think of another OS for non-Power Users which enables SSH by default? With a fixed password?DougieLawson wrote:What collections of morons decided that was a good idea? How brain dead is that?
Self-education is, I firmly believe, the only kind of education there is - Isaac Asimov
- HawaiianPi
The warning prompt mechanism is broken.
I updated my September Jessie Pixel install as indicated in the blog,and upon reboot I got the warning, but the default "pi" user password has most definitely been changed. To confirm it I opened a terminal and tried su - pi, and after entering raspberry it gave me an authentication failure. I also restarted and tried logging into pi/raspberry and was told I had an incorrect password, so something is definitely wrong with the code that checks to see if the prompt needs to be displayed.
I am not logged in as "pi" because I created my own user account. The "pi" user account was secured by setting a long random password, then locked (sudo passwd -l pi), but every time I restart I get the warning.
Removing pprompt...
EDIT: Even after removing ppromt and rebooting I still get the warning when I log in as my user via SSH.
While I can appreciate why you did this, and fully agree that Raspbian needs to be more secure, it seems it needs a bit more testing.
I'm guessing the problem is due to me changing the pi account password from my own user account. So now I'll have to undo everything I already did to secure the pi account in the first place just so I can login as pi and re-secure it.
sudo apt-get update
sudo apt-get dist-upgrade
sudo apt-get install -y pprompt
Removing pprompt...
That's surprising - I would expect pprompt to fail by giving a false negative rather than a false positive. I'll try and recreate the situation you describe tomorrow.HawaiianPi wrote:The warning prompt mechanism is broken.
I updated my September Jessie Pixel install as indicated in the blog,and upon reboot I got the warning, but the default "pi" user password has most definitely been changed. To confirm it I opened a terminal and tried su - pi, and after entering raspberry it gave me an authentication failure. I also restarted and tried logging into pi/raspberry and was told I had an incorrect password, so something is definitely wrong with the code that checks to see if the prompt needs to be displayed.Code: Select all
sudo apt-get update sudo apt-get dist-upgrade sudo apt-get install -y pprompt
Removing pprompt...
Out of interest, can you please check to see if you have the whois package installed? It installs mkpasswd, which is required for the password check, and should install as a result of the dist-upgrade, but it may be that the install failed on your system. The output of "apt-cache policy whois" would be interesting - also what does "mkpasswd aaa" return?
- HawaiianPi
The whois package is installed (has been for a while), but I'll go over to my Pi3 and edit the output into this post in a sec...spl23 wrote:That's surprising - I would expect pprompt to fail by giving a false negative rather than a false positive. I'll try and recreate the situation you describe tomorrow.
Out of interest, can you please check to see if the whois package has installed? It is required for the password check, and should install as a result of the dist-upgrade, but it may be that the install failed on your system. The output of "apt-cache policy whois" would be interesting.
In the meantime, I edited my post above after you quoted it.
[EDIT] output of apt-cache policy whois...
~ $ apt-cache policy whois
whois:
Installed: 5.2.7
Candidate: 5.2.7
Version table:
*** 5.2.7 0
500 http://mirrordirector.raspbian.org/raspbian/ jessie/main armhf Packages
100 /var/lib/dpkg/status
pprompt is the GUI warning - the warning in the CLI is in raspberrypi-sys-mods. Given that doesn't require acknowledgement, it hopefully shouldn't be a show-stopper if you have to live with it for a while!HawaiianPi wrote:EDIT: Even after removing ppromt and rebooting I still get the warning when I log in as my user via SSH.![]()
- HawaiianPi
Thanks for the quick replies. See edit above for requested output and my guess at what the problem might be.
If you have whois installed - which it seems you do - I wonder if it is the case that locking the pi user's password causes something to change in its entry in the shadow file which means grep can't find anything. I'll have a look at that tomorrow.
Just to be 100% sure - can you please tell me what "mkpasswd aaa" returns on your system?
Apologies for the inconvenience - as with all such changes, there's no way we can test every single configuration that users will have before release, so there will always be a few cases where a system is in a state we hadn't anticipated. We'll try and get a fix out for this asap.
