After that I do receive every week a error mail named and giving:
Delivery to the following recipient failed permanently:
postmaster@raspberrypi-1
Technical details of permanent failure:
DNS Error: 124760406 DNS type 'mx' lookup of raspberrypi-1 responded with code NXDOMAIN
Domain name not found: raspberrypi-1
----- Original message -----
DKIM-Signature: v=1; a=rsa-sha256; c=relaxed/relaxed;
d=gmail.com; s=20120113;
h=message-id:from:date:to:subject:mime-version
:content-transfer-encoding;
bh=4yOG03cMbyTGx1B7oNyAICwDj42G7bYEMTzfRihbet0=;
b=MJlBx9mN6q1lhJgCi+rIiylOWcxohDGznPafP8DThLh9IpsrDAWbZeV9FtxaCh7vjx
Y9XAgRcrh4JcbJgvfwQvw85iw1rIi9xcX0W4WgZ4rnqVs1BnCMwgVM0+w2tG2J0yomFM
Ue9mchUPZl1Dk4Sc2tSMNMz7Hh1BG8WiuSnqpJlwTzXYuLMRRt/o49uV2PZyIwpK6u8h
GtNNLzbOgMuwSSo9AA/cbCk1N43NG0a8+9VF5PYCxJMztZCPj1BWTKnKlWGcTmBxa1qj
BkwQnJQsFM2LJuKY8hjzu2TB4V3iNQu8tAXg30gesjxkJ8tIjHToHeYjCqz5ApBW1jrq
UUKQ==
X-Google-DKIM-Signature: v=1; a=rsa-sha256; c=relaxed/relaxed;
d=1e100.net; s=20130820;
h=x-gm-message-state:message-id:from:date:to:subject:mime-version
b=T/sX+By4DBu5vlLQJ5sDfskKGwuKmWxT5uElb8jA35Icm+Flp6Ut+Wt6OZQB1C2e/r
odMojlGK2HhGDexpd0KnZ1o9/eBhWWuIf3rXtg4qtSQdjrfVp5QXQ2V/Ky1cZZ0ZYeQi
MbUWaJbmmPJga7kdyKCIWhw4wySVVhSqDts4GusnYAdO3OXDdlw/hNfzB+v8g2cky/JK
6Mb7rZWzNkfwn2o0+RyLCuAK3Snl8N3TSj7zs4mXRPImt0F6sqq+pXJ9iSkr2+AjPgRD
fcrf9P2Ow+NFJHU1f7db/H9XoDEAz0BjULpKyBmlXPBybVrOg1cBKGYbQ2/jVQ2cI1cn
3OPA==
X-Gm-Message-State: AKaTC01BV3PSKuvkx1pIw+jkP4Y1CgOnCluQMnNPc40eHUUhImCn8PMSKbKw0F2UUFgMWg==
X-Received: by 10.28.51.141 with SMTP id z135mr11750145wmz.109.1479705915163;
Sun, 20 Nov 2016 21:25:15 -0800 (PST)
Return-Path: <edwardhogeveen@gmail.com>
Received: from raspberrypi-1 (53515E33.cm-6-2b.dynamic.ziggo.nl. [83.81.94.51])
by smtp.gmail.com with ESMTPSA id c133sm17378808wme.12.2016.11.20.21.25.13
for <postmaster@raspberrypi-1>
(version=TLS1 cipher=AES128-SHA bits=128/128);
Sun, 20 Nov 2016 21:25:14 -0800 (PST)
Message-ID: <5832853a.8b9a1c0a.acb7.9b59@mx.google.com>
X-Google-Original-From: root (Cron Daemon)
Received: by raspberrypi-1 (sSMTP sendmail emulation); Mon, 21 Nov 2016 06:25:12 +0100
Date: Mon, 21 Nov 2016 06:25:12 +0100
To: root
Subject: Cron <root@raspberrypi-1> test -x /usr/sbin/anacron || ( cd / && run-parts --report /etc/cron.daily )
MIME-Version: 1.0
Content-Type: text/plain; charset=UTF-8
Content-Transfer-Encoding: 8bit
X-Cron-Env: <SHELL=/bin/sh>
X-Cron-Env: <PATH=/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin>
X-Cron-Env: <HOME=/root>
X-Cron-Env: <LOGNAME=root>
