If I try to run a program in python3 I do get an import error for rrdtool:
ImportError: No module named 'rrdtool'
sudo apt-get install rrdtool
I checked the internet but didn't find a solution for python3
Edit:
I did found this on internet:
Unfortunately python-rrdtool package from Ubuntu/Debian is a python 2.x package only. So it will work in python 2.7 and not in python 3.4.
If you must use rrdtool in python 3.x then you will have to use some alternative python to rrdtool binding. There are several to choose from if you look at pypi.python.org (which you can then install with pip). I have not used them as they all seem to have low version count and am weary of possible bugs. If someone did try those perhaps they could share their experience...
Somebody experience doing this with a different solution as mentioned?
by the way I recognize a lot of import problems with python3!!
Beside this MySQL is also not importable. It looks like python 3 is not yet accepted as the new standard
Thanks.
