jozicka
PI as wakeUP server, alternative way-without router access
Fri Oct 28, 2016 9:11 pm
I would like to use my PI as wake-up server in my network, however I do not have access to router, and also my IP is not public.
So I have a idea to have a alternative way, using of possibility to map of Gdrive or other cloud storage.
The idea is simple - schedule job on PI that will every minute run script for if file present on Gdrive ( something like: if exist /mnt/..../WAKEUP/PC1.txt then send wake up command to PC1 etc).
So if I from my mobile put a file named PC1 under folder WAKEUP to a Gdrive, my PI will within one minute wakeup a PC1.
Do you thing this way is possible? I'm not good with setting up anything on PI - It takes me ages to find out proper guidelines, and then get lost in the middle, so I'm asking before I start, If there is not a bug in my plan.
What do you think? (and sorry for my bad english)
J.
lmarmisa
Re: PI as wakeUP server, alternative way
Sat Oct 29, 2016 4:35 am
Your project seems feasible.
If you need a wol client, install the package wakeonlan:
sudo apt-get install wakeonlan
wakeonlan 00:11:22:33:44:55
jozicka
Sat Oct 29, 2016 2:27 pm
Thank you for tip. I'm out of the city now, but when I get back, I will try to set it up and update the result ☺
thagrol
Sat Oct 29, 2016 4:03 pm
If you're going to be working in python and don't want to use an external tool, have a look at my code here: https://github.com/thagrol/fakewake
Specifically the functions make_packet and pack_mac in fakewake.py
This space unintentionally left blank.
jozicka
Sun Oct 30, 2016 7:23 pm
SUPERB!! IT works :)
I have attached google drive using GDriveFS
I have Installed WAKEONLAN tool
I have created a simple script WAKE.BAT (sorry, bad habit from NT commands):
if ls /mnt/gdrivefs/PI/PC1.txt 1> /dev/null 2>&1; then
wakeonlan aa:bb:cc:dd:ee:ff
mv /mnt/gdrivefs/PI/PC1.txt /mnt/gdrivefs/PI/WPC1.txt
else
echo "files do not exist"
fi
and I set in crontab job to execute it every minute (may be I can swith to every 5 minutes)
*/1 * * * * /home/pi/Desktop/WAKE.bat
So if I put under G drive in PI folder file named PC1.txt, it will wake my local network pc, and rename the file to WPC1.txt
I know it is very simple, but working :) As I do not have access to router and my IP is not public one, I guess this is the only way to go ..
(In fact it would be no problem to use this way as a terminal communication - if exist /PI/RUN.bat, execute it , output put to RESULT.txt and rename RUN.bat to DONE.bat... but wakeup is just enough for me )
depauw
Re: PI as wakeUP server, alternative way-without router acce
Mon Oct 31, 2016 8:10 am
Very clever workaround!!!!
Well done!
jozicka
Sun Dec 04, 2016 2:27 pm
Small update - I have found the gdrivefs very unstable and taking too much memory.
Due to that I switched to fetchmail solution. Pi every 5 minutes checks emails and if subject is wakeup then it sends signal to wake pc... Now it works properly ☺
