Eisdieler
Re: TinyTOSLINK (digital audio output) now for B+, too
Fri Jul 01, 2016 8:22 am
Hey Benjamin,
As many before I'd love to get one of your Toslink Sets, the project sounds great. Shipping would be to Germany.
Hope to hear from you.
Best wishes and have a nice week-end,
fabian
Crockernr
Sun Jul 03, 2016 10:15 am
Hi Ben
I am also interested in getting a couple of these. Do you do then for raspberry pi 3
And how much to send to new Zealand ?
nasty007
Mon Jul 11, 2016 11:20 am
Hey Benjamin
im really interested for TinyToslink for PI2.
How much will shipping cost be to Croatia.
If you don't have any left, i would like to build one for myself, im skilled in that area.
Best regards
BenjaminKe
Wed Jul 20, 2016 10:18 am
Hi all,
sorry for the late reply (seems like my email notification isn't workind anymore).
You all got a PM now.
To give some more details also here about prices and how to order:
fully assembled board: 20€
parts as DIY kit: 15€
PCB or parts only are available on request - just tell me what you want :)
Shipping:
Austria: 3€
Europe: 5€
Worldwide: 8€
Just write me a PM or post here and I will come back to you.
Best Regards
Benjamin
Bedgear
Fri Aug 05, 2016 1:32 am
Has anyone tried one of these on the Pi Zero? I assume it wouldnt be an issue, but i havent seen anything about it in this thread.
BenjaminKe
Fri Aug 05, 2016 2:31 pm
I didn't try it yet, but the 40 pin header should be the same so it should be no problem.
Best Regards
Benjamin
Crockernr
Thu Aug 18, 2016 5:29 am
Anyone know any info on setting this up on RPi3 and openelec ?
BenjaminKe
Thu Aug 18, 2016 7:26 am
You just need to add 1 line to the config.txt:
dtoverlay=hifiberry-digi
Then you can select the device in the Kodi settings.
Manew
Mon Aug 29, 2016 11:27 pm
Hi BenjaminKe,
me as well is interested to buy an already assembled TinyTOSLINK board. It should be shipped to Germany.
Best regards,
Dirk
PS: As I'm new to the board I'm not yet able to write a PM to you.
BenjaminKe
Tue Aug 30, 2016 8:08 am
Hi Dirk!
You got a PM :)
BenjaminKe
Tue Sep 06, 2016 7:46 am
RPi3 Update
Finally I also got a RPi3 and the newest version of OpenElec supports the RPi3!
So I can confirm: the board also works on the Pi3 and Kodi is running really fast :)
Also LibreElec works just perfect!
The only problem with RPi3 and the currently newest OpenElec revision (6.0.3) is that it does not yet contain the newest kernel and there is a bug with the bluetooth driver which prevents the hifiberry driver from working correctly (the board will output only noise).
As most people won't need bluetooth the problem can be fixed by deactivating it:
Simply add 1 more line to the config.txt (just before the "dtoverlay=hifiberry-digi"):
dtoverlay=pi3-disable-bt
The overlay "pi3-disable-bt" is not included in OpenElec so you need to download it and copy it into the "overlays" folder on the boot partition of the SD card.
I have uploaded the file here:
http://www.share-online.biz/dl/SG38O2DORAM
On the latest LibreElec version (7.0.2) this bug is already fixed and everything is working perfect!
Best Regards
Benjamin
foresto
Tue Sep 06, 2016 8:01 am
Benjamin, is the bluetooth bug present in the current LibreELEC release as well?
In case you're not aware, LibreELEC is a recent fork of OpenELEC, and nearly all the developers seem to have moved to it.
BenjaminKe
Tue Sep 06, 2016 9:48 am
I can't say for sure - need to try it out
I'm still stuck to OpenElec because it works so perfect that I don't want to update :)
BenjaminKe
Wed Sep 07, 2016 7:52 am
Just tried LibreElec:
The current LibreElec version (7.0.2) already has a newer Kernel and the HifiBerry Bluetooth bug on the Pi3 is fixed here!
Midask
Wed Sep 07, 2016 3:27 pm
Midask wrote:
perryferryjny wrote:Hi All,
Did anyone try to use BenjaminKe's or [IDC]Dragon's board on Raspberry Pi 2 B with Raspbian Jessie? I'm having trouble with getting it to work. I don't want to use OpenELEC nor any other distro - I prefer to make it working on clean Raspbian.
I added HiFi Berry to device tree and disabled default audio card in /boot/config.txt:
#dtparam=audio=on
I see HiFi Berry in aplay:
pi@raspberrypi:~ $ aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: sndrpihifiberry [snd_rpi_hifiberry_digi], device 0: HifiBerry Digi HiFi wm8804-spdif-0 []
Subdevices: 1/1
Subdevice #0: subdevice #0
When I play flac file with mplayer over hdmi it is ok. But when I disable on-board sound and load HiFi Berry mplayer plays file but my AMP does not see digital signal on input. I don't have oscilloscope at home to check if anything is transmitted. But anyway I think it migth be raspbian configuration issue. dmesg show this output:
[ 4.839301] systemd-udevd[108]: starting version 215
[ 5.350307] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[ 5.558976] snd-hifiberry-digi sound: ASoC: CPU DAI (null) not registered
[ 5.559058] snd-hifiberry-digi sound: snd_soc_register_card() failed: -517
[ 5.692065] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 6.195203] bcm2835-rng 3f104000.rng: hwrng registered
[ 6.195658] snd-hifiberry-digi sound: ASoC: CPU DAI (null) not registered
[ 6.195689] snd-hifiberry-digi sound: snd_soc_register_card() failed: -517
[ 6.199150] snd-hifiberry-digi sound: ASoC: CODEC DAI wm8804-spdif not registered
[ 6.199190] snd-hifiberry-digi sound: snd_soc_register_card() failed: -517
[ 6.203286] bcm2708_i2c 3f804000.i2c: BSC1 Controller at 0x3f804000 (irq 79) (baudrate 100000)
[ 6.203657] snd-hifiberry-digi sound: ASoC: CODEC DAI wm8804-spdif not registered
[ 6.203690] snd-hifiberry-digi sound: snd_soc_register_card() failed: -517
[ 6.433326] wm8804 1-003b: revision E
[ 6.440736] snd-hifiberry-digi sound: wm8804-spdif <-> 3f203000.i2s mapping ok
I'm not sure if there are issues here. Does last line mean that wm8804 is operational?
Anyone have an idea how to debug it further?
Hi ! I've just received the device and I have the same issue. The device is working on OpenELEC but not on Raspbian, same problem !
Hi everyone ! It's been a while but now, everything is working, I had to choose AIF in alsamixer to have sound on Raspbian
Let me know if it's OK for you perryferryjny
TJH
Mon Sep 19, 2016 7:07 pm
I'd love to order a TinyTOS from you for my new Pi 3 please..........
Spank
Sun Sep 25, 2016 11:21 am
Hi Benjamin,
I would like to order a board for my Pi3. Please let me know how to proceed.
xelon
Tue Oct 11, 2016 1:00 pm
Just to get this straight: I buy myself a RPi 3, your little wonderadapter, put them together and have an optical output? Thats amazing! :shock: Can I have one? (Germany)
zgtc
Wed Oct 26, 2016 10:33 pm
Hi there,
New in the forum so please let me first thank Jörg, Benjamin and the rest for all the hard work with these cards. I have a Pi2 + IQaudIO DAC+, wonderful combo i use with Volumio and NAS.
I would also like to get digital sound from my laptop and/or TV go through the DAC+, but it lacks toslink input. Quite sure I'd be able to get the proper combination of interfaces buying stuff at audiophonics or similar, maybe having to buy another DAC, but searching google I got here. Two questions:
1. Do you still have cards left? I live in Barcelona... :D
2. Would it (even theoretically) be possible to have a toslink input to the Pi2, and through a rotary encoder send a signal to alsa to change to audio source from the USB/NAS to use the audio coming from the toslink? This way I would use the current setup for volumio, but by selecting a different hardware source send digital sound to the DAC+ as well.
Thank you so much
BenjaminKe
Thu Oct 27, 2016 8:26 am
Hi!
So you only need a Toslink input and no output is this correct?
Or do you want to have both?
Theoretically you could solder a Toslink Input instead of an output and do a little modification and you have a input hardware instead of an output.
Or you could also solder a wire with an extra Toslink input and you get an input AND an output at the same time (but with this way your second input connector is extra and not directly fixed on the board.
The hardware itself (the soundcard ID) has an input and an output channel.
But there is one thing I don't know: I have no idea how far the HifiBerry drivers (software) support a optical input (the have it available on the official PCB, but it is not assembled - so I guess the can support it somehow but you need to try around with this on your own.
And yes I still have board left :)
Best Regards
Benjamin
zgtc
Thu Oct 27, 2016 12:12 pm
Hi Benjamin,
Yes, I only need Toslink INput. My approach is to try to send that audio to the DAC+ (which is connected to the Pi GPIOs) by switching a rotary encoder (and this changes the alsa settings, pressumably). This way I would not need extra cards nor a new DAC.
How do you see it? Would I need your card for this (and modify it for input) or should I simply get a toslink base and soldier that to some different pins in the Pi (would that need a controller)?
Thank you again!
