BarryK
Quirky Linux 8.1 for Pi2 and Pi3
Mon Oct 24, 2016 12:15 am
I am happy to announce version 8.1, the first official release of Quirky for the Raspberry Pi2 and Pi3.
The announcement and download links are posted to my blog:
http://barryk.org/news/?viewDetailed=00441
A more detailed announcement is here:
http://distro.ibiblio.org/quirky/quirky ... s-8.1+.htm
Please report experiences either in this forum thread, that I will monitor, or this thread in the Puppy Linux Forum:
http://murga-linux.com/puppy/viewtopic. ... 684#929684
Regards,
Barry Kauler
cjan
Re: Quirky Linux 8.1 for Pi2 and Pi3
Mon Oct 24, 2016 1:18 am
tried .25 & .89 wifi seems broken, module loaded & SSID on list but can not connect wpa(2).
does 81 fix ?
DavidS
Mon Oct 24, 2016 4:57 am
cjan wrote:tried .25 & .89 wifi seems broken, module loaded & SSID on list but can not connect wpa(2).
does 81 fix ?
I would say give it a try.
RPi = The best ARM based RISC OS computer around
More than 95% of posts made from RISC OS on RPi 1B/1B+ computers. Most of the rest from RISC OS on RPi 2B/3B/3B+ computers
BarryK
Mon Oct 24, 2016 11:36 am
does 81 fix ?
I need more information. Are you using the Pi3 and its inbuilt wifi? Or if the Pi2, what wifi adaptor?
cjan
Mon Oct 24, 2016 12:24 pm
does 81 fix ?
Pi2 and 8192cu module.
btw, in puppy's forum there user@step had same issue, but you just ignore page-9 #8 .
BarryK
Wed Oct 26, 2016 9:08 am
cjan wrote:
does 81 fix ?
Ah, yes, a problem. I also have a wifi adaptor that uses this module, and I couldn't get it to work. Fortunately, I have another that does.
There is quite a lot of discussion on the Pi forum about this module. '8192cu.ko' is an out-of-tree driver provided by the RPi kernel developers, in other words, it is not in the official kernel source. The official source has 'rtl8192cu.ko', which has been disabled in the RPi kernel build.
Does it work for you with Raspbian?
Here is some discussion:
https://github.com/raspberrypi/linux/issues/755
cjan
Wed Oct 26, 2016 9:53 am
bought EW-7811Un (8192cu) about 2 years, never had issue with raspbian.
your link is old story.
thinking you better follow raspbian's kernel not ubuntu, we play Pi after all and they fixed Dirty Cow issue.
geev03
Wed Oct 26, 2016 10:39 am
:D
hitsware
Fri Oct 28, 2016 1:32 am
:D :o 8-) :) ........ posting the test
issue(1) ......... using Seamonkey utubes too slow to show
issue(2) ......... some websites give some kind of 'security issue' again Seamonkey
http://www.hitswares.com/
hitsware
Fri Oct 28, 2016 2:17 am
issue(3)..............................can't install 'sonic-pi'
DavidS
Fri Oct 28, 2016 4:41 am
hitsware wrote::D :o 8-) :) ........ posting the test
1: Yes it is slow on any system in any Mozilla based browser. Use a Webkit browser, OR use youtube downloader and play the video with SimpleVLC.
2: Is your time set correctly? If not any mozilla based browser, and most WebKit browsers will give security errors.
What is sonic-pi? Some kind of audio procesing library or application?
hitsware
Fri Oct 28, 2016 10:58 am
Thanks ......... I'll try setting the time ............
Sonic Pi comes with with Rasbian :
http://sonic-pi.net/
I got a 'missing dependencies'
hitsware
Fri Oct 28, 2016 11:33 am
Just on one website (kdvs)
Secure Connection Failed
An error occurred during a connection to kdvs.org.
The OCSP response is not yet valid (contains a date in the future).
(Error code: sec_error_ocsp_future_response)
The page you are trying to view cannot be shown because the authenticity of the received data could not be verified.
Please contact the website owners to inform them of this problem.
DavidS
Fri Oct 28, 2016 2:21 pm
hitsware wrote:Thanks ......... I'll try setting the time ............
Ok just took a look. What trouble are you having installing Sonic Pi?
I assume you downloaded the deb and double clicked on that, what is the error given to run from the console?
DavidS
Fri Oct 28, 2016 2:23 pm
hitsware wrote:Just on one website (kdvs)
That is a time setting error. Which version of Quirky are you running?
Also make sure that your date is set correct, your time is set correct, and the correct time zone is selected.
hitsware
Fri Oct 28, 2016 5:43 pm
Quirky Xerus 8.1
Seems a problem with the clock ?
It's off plus the times don't match the timezones :)
I'm not goin to worry about it now.
I want to get the x_86 (8.0?)version going on my other
system (via usb) but no luck so far ....
DavidS
Sat Oct 29, 2016 3:23 am
hitsware wrote:Quirky Xerus 8.1
And you did setup the automatic sync for the time?
I ask as I had the issue with Quirky Xerus 8.0.98, though not with 8.1.
hitsware
Sat Oct 29, 2016 2:42 pm
Not sure .... I'll look at it again today .....
FWIW ............. Got Quirky on x_86 machine
NONE of the issues as RPi
Utubes even stream :)
I think I may have read that the Pi hardware
itself can't quite do video ?
DavidS
Sat Oct 29, 2016 4:15 pm
hitsware wrote:> And you did setup the automatic sync for the time?
The RPi can do the video no problem. Unfortunately Seamonkey uses a software only renderer, so it does not work as well as many other browsers (that use the hardware rendering). If you use a good browser that supports HW rendering then problem solved, or download the video and use SimpleVLC to play it.
It is a matter of setting things up correctly, nothing more.
As to the time issues:
Yes the x86 has a hardware RTC to hold the time, so it does not need to sync from a time server. You will find once you setup the Quirky on the RPi to automaticaly sync the time with a time server the problem will be solved, unfortunately the RPi does not have an RTC (the battery used to power one on the x86 would be almost enough to run the entire RPi).
hitsware
Sat Oct 29, 2016 7:32 pm
Oh so right.
Rasbian streams utubes,
keeps time, and comes with
Sonic-Pi ..... :)
DavidS
Sat Oct 29, 2016 9:25 pm
hitsware wrote:> The RPi can do the video no problem.
Oh so right.
Sonic-Pi ..... :)
Yes, and Puppy streams youtube, keeps time, and can have whatever you want, without forcing a bunch of extras down your download.
hitsware
Sun Oct 30, 2016 6:33 pm
Got the time set.....
(had to use the terminal(not my forte))
I cannot get the 'setup' to work for time.
That did, in fact, enable the websites I was
not getting ......
BarryK
Wed Nov 02, 2016 2:44 pm
Note that my website http://barryk.org/ is down, including my blog.
My host hostgator.com has told me too much traffic to my blog.
I am trying to figure out a solution with them.
Yes, I have an "unlimited" account, what they call their "Baby Croc" account, or what they used to call it any way.
hitsware
Wed Nov 02, 2016 8:54 pm
It's working with both Raspbian and Win10 .....
cjan
Mon Nov 07, 2016 12:44 pm
does xserver-xorg-video-fbturbo need?
Return to “Puppy”
