stevelloyd88
Install Mysql 5.7 on raspbian jesse - pi 3
Sun Oct 16, 2016 5:27 pm
I am trying to install Mysql 5.7 on my raspberri pi 3 running raspbian jesse. Has anyone does this before? Can you give me some pointers?
Re: Install Mysql 5.7 on raspbian jesse - pi 3
Sun Oct 16, 2016 6:48 pm
sudo apt-get -y mariadb-server mariadb-client
That gets you Maria DB which is the more modern version of MySQL.
This is a doctor free zone.
stevelloyd88
Mon Oct 17, 2016 2:04 am
DougieLawson wrote:sudo apt-get -y mariadb-server mariadb-client
Thanks, I was able to install it. however it seems that 10.0.27-MariaDB-0+deb8u1 (Raspbian) does not support "json" datatypes. I want mysql 5.7 for the json data type support.
peterlite
Mon Oct 17, 2016 5:02 am
MySQL downloads, http://dev.mysql.com/downloads/mysql/#downloads, does not have an ARM version. There is the source code.
There is a change to the compile at 5.7.5. https://dev.mysql.com/doc/relnotes/mysq ... 5-7-5.html
stevelloyd88
Mon Oct 17, 2016 1:20 pm
I finally got it! It took me several hours and about 8 attempts but I got it. Here are the steps I took.
Thanks to https://solarianprogrammer.com/2016/06/ ... -programs/ and a lot of trial and error.
lucaspouchot
Wed Oct 19, 2016 8:48 am
Thank you stevelloyd88 for your answer, today the version 5.7.13-1~exp1_armhf is no more on the debian pool
you should replace it by 5.7.15-1_armhf
Moreover, you should have to install liblz4-1 r127+
so, start with a
wget http://ftp.debian.org/debian/pool/main/l/lz4/liblz4-1_0.0~r131-2_armhf.deb
dpkg -i liblz4-1_0.0~r131-2_armhf.deb
ps : the package libevent-core-2.0-5 is needed now for mysql-server
fumblingWithIT
Sat Mar 04, 2017 4:44 pm
You can get several versions of MySQL here: https://dev.mysql.com/downloads/repo/apt/ - Though I have not found any for arm yet...
I've boiled the above download list down to a fewer less command and update to current version 5.7.17-1:
wget http://ftp.debian.org/debian/pool/main/ ... _armhf.deb
wget http://ftp.debian.org/debian/pool/main/ ... .2_all.deb
sudo apt install libaio1 libaio-dev libhtml-template-perl libevent-core-2.0-5
sudo dpkg -i libmecab2_0.996-3_armhf.deb
sudo dpkg -i liblz4-1_0.0~r131-2+b1_armhf.deb
sudo dpkg -i mysql-common_5.8+1.0.2_all.deb
sudo dpkg -i mysql-client-core-5.7_5.7.17-1_armhf.deb
sudo dpkg -i mysql-client-5.7_5.7.17-1_armhf.deb
sudo dpkg -i mysql-server-core-5.7_5.7.17-1_armhf.deb
sudo dpkg -i mysql-server-5.7_5.7.17-1_armhf.deb
heronrob
Fri Sep 15, 2017 3:10 pm
The links about don't work, I've browsed the 5.7 directorys and grabbed the armhf.debs doing the following;
wget http://ftp.debian.org/debian/pool/main/m/mysql-5.7/libmysqlclient-dev_5.7.18-1+b1_armhf.deb
wget http://ftp.debian.org/debian/pool/main/m/mysql-5.7/libmysqlclient20_5.7.18-1+b1_armhf.deb
wget http://ftp.debian.org/debian/pool/main/m/mysql-5.7/libmysqld-dev_5.7.18-1+b1_armhf.deb
wget http://ftp.debian.org/debian/pool/main/m/mysql-5.7/mysql-client-5.7_5.7.18-1+b1_armhf.deb
wget http://ftp.debian.org/debian/pool/main/m/mysql-5.7/mysql-client-core-5.7_5.7.18-1+b1_armhf.deb
wget http://ftp.debian.org/debian/pool/main/m/mysql-5.7/mysql-server-5.7_5.7.18-1+b1_armhf.deb
wget http://ftp.debian.org/debian/pool/main/m/mysql-5.7/mysql-server-core-5.7_5.7.18-1+b1_armhf.deb
sudo dpkg -i libmysqlclient-dev_5.7.18-1+b1_armhf.deb
sudo dpkg -i libmysqlclient20_5.7.18-1+b1_armhf.deb
sudo dpkg -i libmysqld-dev_5.7.18-1+b1_armhf.deb
sudo dpkg -i mysql-client-5.7_5.7.18-1+b1_armhf.deb
sudo dpkg -i mysql-client-core-5.7_5.7.18-1+b1_armhf.deb
sudo dpkg -i mysql-server-5.7_5.7.18-1+b1_armhf.deb
sudo dpkg -i mysql-server-core-5.7_5.7.18-1+b1_armhf.deb
However, I received the following errors;
dpkg: dependency problems prevent configuration of mysql-client-core-5.7:
 mysql-client-core-5.7 depends on liblz4-1 (>= 0.0~r130); however:
  Version of liblz4-1:armhf on system is 0.0~r122-2.
 mysql-client-core-5.7 depends on libstdc++6 (>= 5.2); however:
  Version of libstdc++6:armhf on system is 4.9.2-10.
I'm slightly burnt out today, so hopefully someone here can give me a nudge in the right direction?
(Originally I was trying to do master - master replication between rpi & ubuntu machines, only to realise after a week of configuring that 5.5 on the pi is not compatible, and the 5.5 install guide for ubuntu lead to dead ends, so now i'm trying to upgrade the pi)
Fri Sep 15, 2017 4:12 pm
Raspbian Stretch includes MariaDB 10.1 which has everything in MySQL 5.7 plus a bunch more.
c0ff3e
Sun Mar 04, 2018 5:28 pm
No there is no data type json support in that version of mariaDB, so there are things missing.
10.2.7 is the first release with it.
Sun Mar 04, 2018 7:12 pm
That's because of DebIan's insane package policy. You won't get MariaDB 10.2 or later until DebIan Buster. If you need a more agile, more current package you'll have to switch to Mint, Ubuntu or Arch (which aren't as conservative as DebIan).
scito
MySQL 5.7 Docker Container for Raspberry Pi using Debian Sid
Mon Jul 16, 2018 8:14 am
I successfully installed MySQL 5.7 into a Docker container and run it on Raspberry Pi 3. Details are in my blog post, see https://scito.ch/content/mysql-57-docke ... debian-sid
Return to “Advanced users”
