miburge
VNC not working when disconnected from hdmi.
Thu Oct 13, 2016 9:13 pm
Hi I'm a complete newcomer to the Pi i'm using a type B and having problems with VNC. I can run the pi fine connected to the tv and access the pi via VNC. When I disconnect the pi from the TV and try to access I get a refused access message. Can anybody cast any light as to what i'm doing wrong.
Thanks in Advance.
klricks
Re: VNC not working when disconnected from hdmi.
Fri Oct 14, 2016 12:32 am
miburge wrote:Hi I'm a complete newcomer to the Pi i'm using a type B and having problems with VNC. I can run the pi fine connected to the tv and access the pi via VNC. When I disconnect the pi from the TV and try to access I get a refused access message. Can anybody cast any light as to what i'm doing wrong.
Thanks in Advance.
Have you done an update recently?
There was an update to VNC:
sudo apt-get update
sudo apt-get upgrade
You may need to force HDMI to stay on when unplugged.
Edit /boot/config.txt and remove the # from the line that has hdmi_force_hotplug=1
sudo nano /boot/config.txt
You may also need to enable and adjust these settings:
#hdmi_group=1
#hdmi_mode=1
See this for details: viewtopic.php?f=28&t=5851
miburge
Fri Oct 14, 2016 8:32 pm
Hi, Thanks for that worked a treat.
#hdmi_force_hotplug=1
edited to
Now to play with output settings to try and get a better screen thanks for that. :D
