Rive
Re: Howto: Disable Screen Saver In Raspbian
Tue May 10, 2016 3:00 pm
lol
I myself have misquoted a few times... :?
DNPNWO
timmoore46
Fri May 13, 2016 12:22 pm
Huge apologies about the wrong accreditation ! its was really Rive wot dun it !*LOL*
Delighted it was all taken in good humour ! I spotted it when I read through the listing this morning !
So I realised I needed to do a bit of serious grovelling ! *LOL*
Grovel Grovel......
:o :o :o
Tim
snowwalker
Location: Behind the wheel, or at my bench melting solder.
Thu Jun 02, 2016 8:25 pm
Am I going to have this screen blan king problem when I use ANDROID on my PI 3 B model? :?:
I will be using it to stream and watch movies and TV show across the Web. Everything I want to watch can be watched on my Tablet so Android seem to be the best option so far. I don't like flash player because of the security risk, so I don't plan to use Linux ( Although I love it.).
klricks
Fri Jun 03, 2016 3:28 am
snowwalker wrote:Am I going to have this screen blan king problem when I use ANDROID on my PI 3 B model? :?:
I don't think there is any Andriod that works well enough on the RPi to be useful?
Follow the links here and you may find a forum to ask your question: viewtopic.php?f=73&t=71658
You don't have to worry about flash player as that is not supported in any RPI OS.
snowwalker
Fri Jun 03, 2016 3:55 pm
klricks wrote:I don't think there is any Andriod that works well enough on the RPi to be useful?
Well I guess that solves my problem.. if no OS on the PI supports it then Linux it is...
topcompanies
Fri Sep 02, 2016 9:31 am
Thanks jwzumwalt for solution. I am also facing this problem.
keessap
Tue Oct 11, 2016 8:29 pm
To Disable the Screen Saver I have found out that it is very easy now in Rasbain-Jessie. CLI commands are not necessary anymore. You can set it in the LXSession configuration in Preferences. If you can't find the entry, you can add it with the Main Menu Editor.
Go to Preferences, LXsession configuration,
Choose: Autostart
Add a new command under Manual Autotarted Applications: @set s off -dpms
Your screen will go out again.posting.php?mode=reply&f=91&t=57552&con ... KHT80B53UD#
EMJB
Wed Nov 16, 2016 1:01 pm
Was hoping that adding:
@set s off -dpms
to "/home/pi/.config/lxsession/LXDE-pi/autostart" would work, but no such luck. Is this the wrong place or the wrong command, or both?
EMJB
nl3prc
Wed Nov 16, 2016 3:37 pm
mmm
You should be in /root/.config/lxsession/LXDE-pi
EMJB
Thu Nov 17, 2016 8:25 am
@nl3prc
Thanks, but I don't seem to have any file like that. When I try looking for similar files:
 ~ $ sudo ls /root/.config/lxsession/LXDE-pi
ls: cannot access /root/.config/lxsession/LXDE-pi: No such file or directory
ls: cannot access /root/.config: No such file or directory
Also a command to autostart an application works when put in "/home/pi/.config/lxsession/LXDE-pi/autostart".
I'm confused!
EMJB
nl3prc
Thu Nov 17, 2016 9:14 am
my autostart looks like below
@lxpanel --profile LXDE-pi
@pcmanfm --desktop --profile LXDE-pi
@xscreensaver -no-splash
@xset s 0 0
@xset s noblank
@xset s noexpose
@xset dpms 0 0 0
Bosse_B
Thu Nov 17, 2016 11:24 am
I think that if noone has logged on as root on the specific Pi then there will be no files inside /root/.
I do not have any (/root is completely empty) on any of my RPi:s.
So fixing things in root's home dir might not be the proper thing to do.
Bo Berglund
Sweden
RaTTuS
Contact: Twitter YouTube
Thu Nov 17, 2016 11:59 am
you never want to run x as root anyway
Covfefe
EMJB
Mon Nov 21, 2016 9:02 am
nl3prc wrote:my autostart looks like below
@xset s 0 0
@xset s noblank
@xset s noexpose
@xset dpms 0 0 0
Thanks nl3prc - I copied the last 4 lines into my autostart folder which seems to have done the trick.
EMJB
Lomax
Fri Dec 16, 2016 2:49 pm
This is driving me nuts. Despite setting BLANK_TIME=0 and POWERDOWN_TIME=0 in /etc/kbd/config the screen still switches off after a few minutes. I am not running LXDE, or even X, so those instructions are unlikely to help. Considering how many people are struggling with this behaviour, may I suggest the Raspbian team change the default to not turn off the screen? Modern LCDs are all LED backlit anyway so there should be little need to "save" the screen - if you want to turn it off, press the power button! ;)
RaTTuS
Fri Dec 16, 2016 3:24 pm
there are ways to to do it via systemd but meh!
add
consoleblank=0
to the end of /boot/config.txt
IIRC
Covfefe
bkjaya1952
Re: How2 Disable Screen Saver In Raspbian
Sat Dec 17, 2016 1:48 pm
klricks wrote:The easiest way to disable screen blanking in the Raspbian GUI is to install xscreensaver then configure it to disabled.
sudo apt-get update
sudo apt-get install xscreensaver
In the [Display Mode] tab, set like this - Mode: [Disable Screen Saver]
Thank you :)
Lomax
Fri Jan 06, 2017 10:42 pm
RaTTuS wrote:there are ways to to do it via systemd but meh!
add
consoleblank=0
IIRC
Thanks, but I'm still seeing blanking - looks like DPMS off. I have set
BLANK_TIME=0
POWERDOWN_TIME=0
in /etc/kbd/config, and
consoleblank=0
in /boot/config.txt. I've got a Python/Kivy app running in public and really need the screen to remain on for as long as the Pi itself is on. Any other ideas?
AlecGalloway
Thu Mar 16, 2017 10:20 pm
I have installed xscreensaver and edited lightdm.conf with xserver-command=X -s 0 -dpms, but the screensaver is still on. Is there something that I'm missing?
bettersweeps
Mon Jun 26, 2017 2:09 am
After days of also dealing with this problem i have finally figured it out, so far the commands listed here will only disable it if you remember to use the bash command you design, or just put it into a loop. Here´s a 1 step fix and explanation as to why the first part has failed to work, first the code.
the reason this hasn´t always worked is because the command has 2 parts to it, the first 1 you see in the lightdm.conf file is merely a trigger, moving further down you will find a second part same print smaller description. The first one is located under Seat Defaults, the second is located under [seatdefalts] both xserver-command=X commands need to written exactly as
for it to work. This doesn´t matter what you run your pi as, this will guarentee to disable the screen saver aka blanking aka idle mode, your screen will never blank, blink, pause, its not a loop hole. this is the real deal fix to the screen saver without needing any apps, and or mods.
adeel88
Thu Jun 29, 2017 1:44 pm
hi,
I want to add screen saver in Raspberry-pi when screen goes to sleep and when user tap on that it shows the original state of raspberry-pi. Can someone please help me in this problem that how can I do this? I am using raspbian-jessy.
Thu Jun 29, 2017 1:46 pm
adeel88 wrote:hi,
sudo apt-get update
https://www.jwz.org/xscreensaver/
Retired disgracefully.....
adeel88
Thu Jun 29, 2017 2:30 pm
fruitoftheloom wrote:
adeel88 wrote:hi,
sudo apt-get update
Thanks for your prompt reply. Yes. It worked. Can I add my custom screensaver using 'xscreensaver'?
klricks
Thu Jun 29, 2017 5:08 pm
adeel88 wrote:...Thanks for your prompt reply. Yes. It worked. Can I add my custom screensaver using 'xscreensaver'?
Yes but you have to install some more addons to xscreenaver.
See this thread: viewtopic.php?f=63&t=185313
adeel88
Thu Jun 29, 2017 9:32 pm
Thanks. Sorry, one last thing can I add a simple black screen when user don't use the raspberry-pi or after specific idle time and when user tap on that it will show the last/original state of raspberry-pi?
