s-a-m
Re: Raspberry Pi 3 no wifi
Mon Oct 10, 2016 3:09 pm
It's not just Raspberry Pi 3, I have a Raspberry Pi Mobel B. The USB dongle that was working with it stops working after installing the new Raspbian distro. The one with the PIXEL desktop. The kernel module is said to be loaded. I have no clue what's going on.
texy
Mon Oct 10, 2016 4:58 pm
Ok - so you can also give the output of dmesg as advised above?
Texy
s-a-m
Mon Oct 10, 2016 5:50 pm
I managed to connect to the WiFi. The GUI interface on PIXEL doesn't seem to pick up the networks but the USB WiFi dongle was functional.
lsusb
Bus 001 Device 007: ID 046d:c040 Logitech, Inc. Corded Tilt-Wheel Mouse
Bus 001 Device 006: ID 1a2c:2124 China Resource Semico Co., Ltd
Bus 001 Device 005: ID 05e3:0608 Genesys Logic, Inc. USB-2.0 4-Port HUB
Bus 001 Device 004: ID 0b05:1786 ASUSTek Computer, Inc. USB-N10 802.11n Network Adapter [Realtek RTL8188SU]
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9512 Standard Microsystems Corp. LAN9500 Ethernet 10/100 Adapter / SMSC9512/9514 Hub
lsmod
Module                  Size  Used by
bnep                   11853  2
bluetooth             365780  5 bnep
cfg80211              499234  0
rfkill                 21397  4 cfg80211,bluetooth
r8712u                177928  0
evdev                  11650  3
joydev                  9194  0
snd_bcm2835            23131  0
snd_pcm                95473  1 snd_bcm2835
snd_timer              22556  1 snd_pcm
snd                    68368  3 snd_bcm2835,snd_timer,snd_pcm
bcm2835_gpiomem         3823  0
bcm2835_wdt             4133  0
uio_pdrv_genirq         3718  0
uio                    10230  1 uio_pdrv_genirq
i2c_dev                 6578  0
fuse                   90216  1
ipv6                  367607  34
dmesg | grep r87
[   13.548087] r8712u: module is from the staging directory, the quality is unknown, you have been warned.
[   13.757502] r8712u: register rtl8712_netdev_ops to netdev_ops
[   13.757565] usb 1-1.2: r8712u: USB_SPEED_HIGH with 4 endpoints
[   13.974556] usb 1-1.2: r8712u: Boot from EFUSE: Autoload OK
[   17.047082] usb 1-1.2: r8712u: CustomerID = 0x0010
[   17.047130] usb 1-1.2: r8712u: MAC Address from efuse = 30:85:a9:6e:94:49
[   17.047158] usb 1-1.2: r8712u: Loading firmware from "rtlwifi/rtl8712u.bin"
[   17.059398] usbcore: registered new interface driver r8712u
[   19.013282] r8712u 1-1.2:1.0 wlan0: 1 RCR=0x153f00e
[   19.014109] r8712u 1-1.2:1.0 wlan0: 2 RCR=0x553f00e
/etc/network/interfaces
# interfaces(5) file used by ifup(8) and ifdown(8)
# Please note that this file is written to be used with dhcpcd
# For static IP, consult /etc/dhcpcd.conf and 'man dhcpcd.conf'
# Include files from /etc/network/interfaces.d:
source-directory /etc/network/interfaces.d
auto lo
iface lo inet loopback
iface eth0 inet manual
allow-hotplug wlan0
iface wlan0 inet manual
    wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
allow-hotplug wlan1
iface wlan1 inet manual
To get the network to connect I had to manually edit /etc/wpa_supplicant/wpa_supplicant.conf and add my network to it. Then after rebooting everything connected. The GUI doesn't do it like it used to before PIXEL.
country=CA
update_config=1
network={
	ssid="MyNetwork"
	psk="MyPassword"
MegaGumbo
Wed Oct 19, 2016 10:20 am
s-a-m wrote:It's not just Raspberry Pi 3, I have a Raspberry Pi Mobel B. The USB dongle that was working with it stops working after installing the new Raspbian distro. The one with the PIXEL desktop. The kernel module is said to be loaded. I have no clue what's going on.
Same thing here. I'm using a Pi 1 Model B+ and installed Raspbian via NOOBS. On the console, "ifconfig -a" shows the wlan0 interface is present and in the dmesg log I can see that the wifi device (realtek based usb-stick) is properly detected and the firmware is loaded without errors.
I guess it wouldn't be much of a problem for me doing the manual configuration in /etc/network/interfaces, but I plan to give this device to my 12-year-old cousin who's just not a Linux crack at all (he's more into Minecraft, you see).
However, one last thing I will try tonight is to disable wifi power management (@Squash: thanks for the hint).
EDIT: configuring wifi through /etc/network/interfaces and /etc/wpa_supplicant/wpa_supplicant.conf does do the trick. So technically, wifi is working but the GUI tools of the current Raspbian / Raspbian via NOOBS images seem to be unable to detect the wlan0 interface (at least in some cases).
adammklemm
Thu Jan 05, 2017 7:59 pm
@ jjsanderson
I have also experienced issues w/ the pi 3 not recognizing any wlan interfaces. when I scan for networks I can see all of the networks so Im pretty certain that the hardware is working correctly. I just don't know how to configure the wlan correctly after trying many things from various user posts. In your post, you seemed to be having similar issues. Have you resolved your issues or are you still having problems. If you have any suggestions, advice or resources that you could point me, much appreciated.
Thank You
Adam
rexlee
Fri Jan 06, 2017 12:19 am
Hi Adam,
I have had this problem in the last 48 hours too. It took 36 hours to solve and I made this post regarding the solution in my case. viewtopic.php?f=91&t=170245
rexlee
Fri Jan 06, 2017 12:23 am
I have WIFI working well for months now with these files in place:
auto lo
allow-hotplug wlan0
allow-hotplug wlan1
update_config=1
country=FI
network={
        ssid="zipit"
        psk="secretstuffhere"
        key_mgmt=WPA-PSK
network={
        ssid="nomansland"
        key_mgmt=WPA-PSK
network={
        ssid="AndroidAP"
        key_mgmt=WPA-PSK
With this I can move from home to office and have the Pi connect to the WIFI there. Or plug in ethernet and use that.
I have no idea what Pixel does. I have KDE installed here but my Pi run headless most of the time.
SteveHodge
Sat Jan 07, 2017 12:30 pm
Thanks G7icd, this worked a treat, after hours of thrashing about
Question: was wlan0 in the second block of instructions a mistype for wlan1?
Would there by any issue in not using dhcp and setting a static address with your system?
I'll try it anyway
Steve
Budmo
Mon Jan 09, 2017 6:30 pm
Try it:
echo "anybadstring" > /etc/modprobe.d/brcmfmac.conf
reboot
Tue Jan 10, 2017 10:23 am
Budmo wrote:Try it:
reboot
sudo rm /etc/modprobe.d/brcmfmac.conf would be easier.
This is a hippy & doctor free zone.
evadeflow
Sat Jan 28, 2017 1:01 pm
Just wanted to say that I was having the exact same issue, and the solution posted by @g7icd worked for me. I made the suggested edits to `etc/dhcpcd.conf` and `/etc/network/interfaces` (following them verbatim, no 'extra' tweaks or anything like that), and then rebooted. When my Pi came back up, my wireless AP/router had assigned it an IP address and I was able to access the Internet.
One oddity, though: when I click the WiFi icon in the panel, it still says No wireless interfaces found. It hardly matters for my purposes, so long as WiFi actually works. Just figured I should mention: I would have solved this problem sooner if I hadn't been using that status icon as my primary indication of whether WiFi was 'working'. Don't be fooled like I was, it's possible for WiFi to be functional even when you're getting the No network interfaces found message in the UI. (YMMV and all that, just passing along my experience...)
jairos2016
Thu Mar 23, 2017 3:33 pm
I tried all the solutions proposed to solve the problem of lack of wifi in raspberry pi 3.
Sudo nano / etc / network / interfaces
Sudo nano /etc/wpa_supplicant/wpa_supplicant.conf
The iw commands and nothing worked until you upgrade firmware
The command
Sudo rpi-update did not do anything.
I found this previous instruction:
Sudo aptitude show raspberry-bootloader
To apply
Sudo rpi-update and now if the wifi card is configured.
Firmware 4.4.50 v7 +
Happened to 4..9.16 v7 +
Everything worked well with the raspberries until I update raspbian from March 2nd.
Now everything is ok.
rstolfa
Fri Jun 16, 2017 7:01 pm
I have the same general problem. Additionally, if I run "iwlist wlan0 scan", I get all of the expected WiFi networks in the area, but still none register in the GUI.
Thoughts?
JoeJia1207
Sun Sep 10, 2017 12:50 pm
Guys I found first get a raspberry pi 2 plug the raspberry pi 3 sd card into the 2 then boot it shutdown then go on the 3 and boot then wifi appears! :D :D :D :D :D ;) ;) ;) ;)
lracek
Wed Dec 27, 2017 5:44 pm
Hello, can be the "No wireless interface found" problem caused by absence of this capacitor? I've lost it somehow.. :cry:
Thank you!
Regards
cort2
Wed Jan 03, 2018 11:56 am
I have the same problem Pi3 has lost on board wifi and bluetooth.
I have tried all new installs but nothing helps.
fine works only usb wifi dongle.
cort2
Wed Jan 03, 2018 12:13 pm
Thank you!
Regards
something not , I have him , and the lost wifi ( wlan0) have too.
schack
Fri Jan 19, 2018 10:23 pm
I have the same problem and I tried all fixes in this thread. Nothing and really nothing helps.
I have a second raspi3 with working wlan! I switched the sd cards and I have exact the same problem with this raspi 3. The other one has wlan with both sd cards.
The same with bluetooth.
So its a hardware problem!
But the firmware upgrade didn't fix it for me. So I think on one raspi my wlan and bluetooth chip is broken!
NatronMc
Thu Mar 22, 2018 2:40 am
In Raspberry Pi configuration, under the Localisation tab set the wifi Country to your Country. I picked US and my Wifi started to work. Maybe this could work for you.
umbra
Sun May 27, 2018 6:30 pm
jjsanderson wrote:
Fri Oct 07, 2016 10:14 am
I think I've read all the threads on this, but the majority of messages are about failure to find or join a network. This is a failure to find the interface, and while it doesn't seem to be widespread generally, it's completely endemic for us.
^^^ this.
joergn
Sat Jun 09, 2018 6:19 pm
This happened to me after installing and enabling ufw. sudo ufw disable fixed it.
Does anyone know this issue and a fix to it to have both ufw and WLAN?
Thanks!
J.
CurzonDax
Sun Dec 02, 2018 5:05 am
In my case a configuration in /etc/network/interfaces prevented the dhcp client from starting. So removing the configuration and
systemctl start dhcpcd
did the trick.
Ken_C
Sat Feb 09, 2019 3:15 pm
I suspect I had this problem in stretch, because I followed the instructions for headless wifi setup for jessie. if you put wpa_supplicant.conf formatted(copied from) for a jessie install in the boot directory of a stretch install, it breaks wifi. So I pulled the sd card and reflashed, I also updated the firmware of the pi but I dont think thats what fixed it. so reinstalled with only ssh enabled. then since I only know how to set it up this way I just ssh into the pi and enabled vnc then did the rest of my setup with vnc and was able to connect the wifi.
GeraldR63
Sun Feb 17, 2019 10:05 pm
Had same issue.
Made update as described above plus firmware update.
sudo apt-get update
sudo apt-get upgrade
sudo rpi-update
It's than required to configure W-LAN as usual.
Since that it works.
regards
Gerald
