With a lot of knowledge and even more confidence, I then wanted to "port" that rather simple solution to the Raspberry Pi, but boy, was I wrong! It didn't work at all. So, for the same reasons that many solutions do not work on the PICAXE, many also do not work well on the Pi.
I have to admit that I'm adamant in using Python, instead of C, and also for using the RPi.GPIO library. That didn't help me, but my assumption is that there are more like me (in a way anyway).
So, working from the same methodology, the "early detection" method, I finally was able to finish a Python program that works pretty reliably.
The code is explained the best I could, so you should have no problems following it, or modifying it for your own application.
#!/usr/bin/python
# FileName: Rotary_Encoder-1a.py
# Purpose: This program decodes a rotary encoder switch.
# Note: All dates are in European format DD-MM-YY[YY]
# Author: Paul Versteeg
# Created: 23-Nov-2015
# This program is free software: you can redistribute it and/or modify
# it under the terms of the GNU General Public License as published by
# the Free Software Foundation, either version 3 of the License, or
# (at your option) any later version.
# This program is distributed in the hope that it will be useful,
# but WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
# GNU General Public License for more details.
# You should have received a copy of the GNU General Public License
# along with this program. If not, see <http://www.gnu.org/licenses/>
import RPi.GPIO as GPIO
from time import sleep
# Global constants & variables
# Constants
__author__ = 'Paul Versteeg'
counter = 10 # starting point for the running directional counter
# GPIO Ports
Enc_A = 23 # Encoder input A: input GPIO 23 (active high)
Enc_B = 24 # Encoder input B: input GPIO 24 (active high)
def init():
Initializes a number of settings and prepares the environment
before we start the main program.
print "Rotary Encoder Test Program"
GPIO.setwarnings(True)
# Use the Raspberry Pi BCM pins
GPIO.setmode(GPIO.BCM)
# define the Encoder switch inputs
GPIO.setup(Enc_A, GPIO.IN) # pull-ups are too weak, they introduce noise
GPIO.setup(Enc_B, GPIO.IN)
# setup an event detection thread for the A encoder switch
GPIO.add_event_detect(Enc_A, GPIO.RISING, callback=rotation_decode, bouncetime=2) # bouncetime in mSec
return
def rotation_decode(Enc_A):
This function decodes the direction of a rotary encoder and in- or
decrements a counter.
The code works from the "early detection" principle that when turning the
encoder clockwise, the A-switch gets activated before the B-switch.
When the encoder is rotated anti-clockwise, the B-switch gets activated
before the A-switch. The timing is depending on the mechanical design of
the switch, and the rotational speed of the knob.
This function gets activated when the A-switch goes high. The code then
looks at the level of the B-switch. If the B switch is (still) low, then
the direction must be clockwise. If the B input is (still) high, the
direction must be anti-clockwise.
All other conditions (both high, both low or A=0 and B=1) are filtered out.
To complete the click-cycle, after the direction has been determined, the
code waits for the full cycle (from indent to indent) to finish.
global counter
sleep(0.002) # extra 2 mSec de-bounce time
# read both of the switches
Switch_A = GPIO.input(Enc_A)
Switch_B = GPIO.input(Enc_B)
if (Switch_A == 1) and (Switch_B == 0) : # A then B ->
counter += 1
print "direction -> ", counter
# at this point, B may still need to go high, wait for it
while Switch_B == 0:
# now wait for B to drop to end the click cycle
while Switch_B == 1:
return
elif (Switch_A == 1) and (Switch_B == 1): # B then A <-
counter -= 1
print "direction <- ", counter
# A is already high, wait for A to drop to end the click cycle
while Switch_A == 1:
return
else: # discard all other combinations
return
def main():
The main routine.
try:
init()
while True :
# wait for an encoder click
sleep(1)
except KeyboardInterrupt: # Ctrl-C to terminate the program
GPIO.cleanup()
if __name__ == '__main__':
main()
Enjoy!
