mattmiller
Re: Anyone tried 4xAlkaline AA batteries on PiZero?
Thu Sep 22, 2016 1:08 pm
All fine after 5.5 hours
Volts is down to 4.6
I think I'll have to rig up another Pi with an ADC on it to monitor the volts next time and see how long it actually stays about 5.25V - I suspect not much more than 1 hour
mikerr
Thu Sep 22, 2016 2:36 pm
mattmiller wrote: (I know its not legit but I have a need to use 4xAA batteries in a project - I will specify that they should be NiMH recharables but I needed to know what would happen if a user didn't follow the plan)
You have only proved your own pi survived > 5V once, not that all pi would.
On undervoltage (where there's no danger) - I've had pi zero working down to 2.9v
mattmiller
Thu Sep 22, 2016 7:40 pm
Very true - but as long as I have a lucky Pi for the project - I'm fine with that :)
I imagine a few others will give it a go now and hopefully report in :)
Today - the Pi is still going after 12 hours!
Its down to 3.9V but still sending out 30 mins MQTT messages on mosquitto.org topic pizero4aa
And still flashing a LED
And I can still VNC into it and launch LX Terminal
So either today's set of batteries (which came out of same pack as yesterdays are a lot better or the official RPI white dongle draw much lower power than yesterdays RaLink
tpylkko
Thu Sep 22, 2016 7:44 pm
in that case, what about running it on three (or maybe even two) alkaline batteries?
FlexibleSigmoid
Thu Sep 22, 2016 7:52 pm
So TLDR version of the thread:
OP: "Going to hit myself in the head with a hammer, anyone think that's a bad idea?"
General Consensus: "Very bad idea indeed."
OP: "Tricked you all, already hit myself, now you naysayers look like fools!" <- Posted from the A&E
mattmiller
Thu Sep 22, 2016 8:01 pm
No you got that wrong - the OP was
"Has anyone bashed themselves over the head?"
to which many people replied
"Don't do it- you''l get hurt"
and
"I wrapped a rubber mallet in bubble wrap and it didn't hurt"
To which the OP replied
"Please read the question before answering"
and then later said
"Ok then - I'll try it out"
and later
"I seemed to have survived- I'll try again tomorrow but wear different glasses this time"
mattmiller
Thu Sep 22, 2016 8:04 pm
Oh dear - trouble :(
The WiFi dongle I borrowed was from the bedroom Pi which is used to relay old Sky+ handset IR codes to our SkyQ (NEVER get one of them BTW) box in the living room (using MQTT of course)
My wife is NOT happy at lack of remote control facilities - and I can't find the Ralink dongle to use instead ! :(
FlexibleSigmoid
Thu Sep 22, 2016 8:12 pm
There's a very apropos quote from the movie Tommy Boy about a T-bone steak, a cow and a butcher. But I'd probably get banned for posting it.
mattmiller
Thu Sep 22, 2016 8:18 pm
mm - maybe I've come at this the wrong way then - we should be testing PiZero out on 3 x AA Alkaline and see how long they last
Maybe even 3 * AA Normal 1.5V ones as IIRC I think they do better at high current discharges than Alkalines
Need to get hold of some 3 x AA battery holders then.....
mattmiller
Thu Sep 22, 2016 10:12 pm
Well its stopped flashing the LED now and last msg posted at 22:57 volts = 2.9 so I think we'll call it a day at this point 14.5 hrs wasn't bad though :)
peterlite
Thu Sep 22, 2016 11:06 pm
If 4*AA does not last long enough and the piborg is a touch to much:
https://www.modmypi.com/raspberry-pi/br ... g-battborg
The Battborg with a cheap motorcycle battery should run your Pi for a week or two.
Plus you can ride the motorcycle to work. :D
mattmiller
Fri Sep 23, 2016 7:20 am
New thread on the 3 x AA experiement
viewtopic.php?f=63&t=160710
daveake
Fri Sep 23, 2016 8:14 am
Be aware that Lithium AAs start at about 1.84V, not the ~1.5V of an alkaline cell, so if someone does pop 4 of those in to your device then their Zero and USB device are going to see over 7.3V.
Primary Lithium cells do lose voltage pretty quickly under load, but over-voltage damage also happens quickly.
Dave
mattmiller
Fri Sep 23, 2016 1:23 pm
Ta for info.
I think I'm either going to be using 3 or 4 plain AAs. If the 3 x AA last 0.75 of the 4 x AA then its a no-brainer to go with them as not going to stress out anything and I won't get the RSPCP onto me :)
Fri Sep 23, 2016 1:28 pm
mattmiller wrote:New thread on the 3 x AA experiement
Please use new thread.
“My wife said to me `...you’re not even listening`.
I thought, that’s an odd way to start a conversation.."
