murphy2
Re: [Solved] Help installing wifi dongle driver
Sun May 29, 2016 2:33 pm
I am having troubles getting the driver to work with the Archer T1U.
It would be awesome if you could take a look at the following logs:
http://pastebin.com/YNEeDcaC
I would be really thankful for all ideas on what could be the issue!
Cheers,
Martin
DirkS
Sun May 29, 2016 3:10 pm
murphy2 wrote:I would be really thankful for all ideas on what could be the issue!
Seems to be connecting / disconnecting.
Try adding
max_usb_current=1
to /boot/config.txt
murphy2
Sun May 29, 2016 3:50 pm
It works!!!
Thank you very much!
Gio79
Mon Sep 19, 2016 10:12 am
Hello.
@MrEngman; Wondering if you could compile a driver to work for ASUS USB-AC51, kernel 4.4.21-v7+ #911?
I've spent a week trying to up my wifi dongle.
Let me know if you need more info.
You are the best!!
MrEngman
Mon Sep 19, 2016 11:40 am
Gio79 wrote:Hello.
You are the best!!
With your wifi module connected to your Pi can you post the output of command lsusb to check the USB id it uses.
MrEngman
MrEngman
Mon Sep 19, 2016 12:32 pm
Gio79 wrote:Hello.
You are the best!!
From the info I have it uses the mt7610 driver that I have already compiled.
I have a script which will automatically check the kernel version and wifi you are using and automatically download and install the correct driver. You can download and install the script using commands
wget https://dl.dropboxusercontent.com/u/80256631/install-wifi.tar.gz
tar xzf install-wifi.tar.gz
Command ./install-wifi -h will show the information on how to use the script.
For you current set up to load the driver it should just be sufficient to run command ./install-wifi
MrEngman
Gio79
Mon Sep 19, 2016 1:38 pm
Thank you for you quick response!!
I will try it this night! :D
P.D: WORKS PERFECTLY!!! And in the 5G frequency as well!! THANK YOU!!!
bevermore
Fri Oct 28, 2016 11:01 am
Mr. Engman,
I have a LinkPal AC600 wi-fi dongle that uses the MediaTek 7610u driver and my kernel is 4.4.27. I have followed every instruction in this thread several times over. I've tried rebooting. I've tried everything I can think of but I cannot get this dongle to work properly at either 2.4GHz or 5GHz. It does recognize my Access Point via SSID but does not allow me to connect to the internet or to enter my local network.
lsmod shows mt7610u_sta 895458 0
ifconfig shows wlan0 inet addr:192.168.0.27 RX packets: 8710 TX packets: 2382
uname -a shows Linux raspberrypi 4.4.27-v7+ #917 SMP Tue Oct 25 16:00:29 BST 2016 armv7l GNU/Linux
Linux drivers are available at http://jmp.sh/BF2NPp5 which forwards to https://jumpshare.com/v/4FKwTRhEDKJQJ4BV8RT3 however the install routine will not run in Linux even though there are Linux drivers provided in the rar file
Do you have any suggestions?
Thanks,
Bob
willbartlett
Wed Nov 30, 2016 3:31 am
Hello Mr Engman.
I have been following your excellent support for USB wifi dongles.
I have an Archer T1u that I'm trying to get stood up under jessie lite on a raspberry Pi zero.
I have the following output
pi@raspberrypi:~ $ lsusb
Bus 001 Device 005: ID 05ac:1402 Apple, Inc. Ethernet Adapter [A1277]
Bus 001 Device 004: ID 1a2c:0002 China Resource Semico Co., Ltd
Bus 001 Device 003: ID 2357:0105
Bus 001 Device 002: ID 05e3:0608 Genesys Logic, Inc. USB-2.0 4-Port HUB
pi@raspberrypi:~ $ uname -a
Linux raspberrypi 4.4.21+ #911 Thu Sep 15 14:17:52 BST 2016 armv6l GNU/Linux
I have tried running the script at:
wget https://dl.dropboxusercontent.com/u/802 ... ifi.tar.gz
and I receive a response:
Your wifi module is unrecognised.
**** Unable to identify your wifi module ****
Wondering if I have the correct script or if there is a newer script I should try?
Many Thanks for your support. Hope things are well.
W
MrEngman
Wed Nov 30, 2016 11:19 am
willbartlett wrote:Hello Mr Engman.
W
Sorry about that. Looks like there was a problem with the script. Can you download it again and it should be OK now.
MrEngman
willbartlett
Mon Dec 05, 2016 5:42 pm
Hello again. Returning to this after a few days.
I ran the updated script again, with some success. The script detected the MT7610 device, downloaded the appropriate files, and reported success. I rebooted the Pi and lsusb still reported:
There was no device name after the ID. I rebooted the system and ifconfig did report wlan0, but after entering the ssid and passkey of my 5Ghz router in /etc/wpa_supplicant/wpa_supplicant.conf, lsusb failed to report 2357:0105 on any Bus or Device slot. repeated reboots yielded the same results.
I am wondering if the device should have shown a name through lsusb, or if the lack of a device name is an indicator of an issue with my process.
I will be starting from scratch and will report my findings, but if you have any thoughts on the lack of device name as an indicator of another issue, I would be interested in hearing so.
Thanks again so much for your support, it is greatly appreciated.
I have never
TommyRottn
Wed Jan 04, 2017 1:29 am
@MrEngman
Thank you SO much! - I've been beating my head against the wall all day trying to install wifi on my Pi. Install script worked great! I haven't tried 5Ghz yet but 2.5 is perfect so far.
Thanks again!
Wavlink AC600 (0e8d:7610) wifi on Debian/GNU 4.1.19
MrEngman
Wed Jan 04, 2017 9:19 am
TommyRottn wrote:@MrEngman
Thanks again!
Glad to be able to help.
MrEngman
tempusfugit84
Thu Jan 05, 2017 12:00 am
Hi, I have been using your excellent scripts and modules, are you still compiling the new drivers as i am having issues getting the mt7610 driver to work with the current update log as below:
pi@raspberrypi:~ $ sudo ./install.sh
sudo mkdir -p /etc/Wireless/RT2870STA/
sudo cp RT2870STA.dat /etc/Wireless/RT2870STA/
sudo install -p -m 644 mt7610u_sta.ko /lib/modules/4.4.38-v7+/kernel/drivers/net/wireless
install: cannot stat ‘mt7610u_sta.ko’: No such file or directory
sudo depmod 4.4.38-v7+
rm: cannot remove ‘mt7610u_sta.ko’: No such file or directory
many thanks for your help in advance!
Kind regards
Tempusfugit.
MrEngman
Thu Jan 05, 2017 7:34 am
tempusfugit84 wrote:Hi, I have been using your excellent scripts and modules, are you still compiling the new drivers as i am having issues getting the mt7610 driver to work with the current update log as below:
Kind regards
Tempusfugit.
Sorry about that. I've updated the driver and it needed install.sh updating. The install-wifi script has also been updated as determining the kernel version and build in certain circumstances had to be changed due to an update being made to how the kernel images are formatted.
If you download the driver again it should be OK now. My new install-wifi script can be downloaded and installed using commands
sudo wget https://dl.dropboxusercontent.com/u/80256631/install-wifi -O /usr/bin/install-wifi
sudo chmod +x /usr/bin/install-wifi
The new script requires being run with sudo. For info on how to use it use
sudo install-wifi -h
MrEngman
tempusfugit84
Thu Jan 05, 2017 2:55 pm
Sir, you are a legend! I will try the updated scripts this evening after work and let you know.
Kind Regard
Tempusfugit
tempusfugit84
Thu Jan 05, 2017 8:56 pm
Works Like a charm!!
Thanks again for all your doing for those of us starting out!
Kind regards
Tempusfugit84
dlernstrom
Sat Jan 07, 2017 4:09 pm
MrEngman,
I've been reading through this forum and observing your incredible dedication to the community. On behalf of everybody here, a big hearty thank you.
I'm looking for a stable WiFi dongle that supports 5G and other forums suggested that the TP-Link AC450 Archer T1U is one of the rare RPi supported dongles that support 5G. Alas, when I got it, I have been unable to track down drivers. I think that I'm very close having stumbled into your 'install-wifi' script, but you don't have a driver that supports the kernal revision / build of my device.
Would it be too incredibly inconvenient to ask how to assemble this driver or get you to build one for me? Here's the output from your script. Please let me know if I can provide anything else.
Cheers,
David
 *** Raspberry Pi wifi driver installer by MrEngman.
Your current kernel revision = 4.4.9-v7+
Your current kernel build    = #3
Checking for a wifi module to determine the driver to install.
Your wifi module is Bus 001 Device 004: ID 2357:0105
And it uses the mt7610 driver.
Checking for a new mt7610 wifi driver module for your current kernel.
A driver does not yet exist for this update.
dlernstrom
Sat Jan 07, 2017 7:02 pm
My previous post was using a recent Raspbian Jessie Lite image (can't remember Sep or Nov).
I just attempted again using the full Raspbian image (2016-11-25-raspbian-jessie.img). This time it looked like your script was about to be successful, however I got errors in the install.
rm: cannot remove âmt7610*â: No such file or directory
modprobe: FATAL: Module mt7610 not found.
After reboots and reinstalls, it appears to work, however 5GHz networks do not show up in the UI SSID dropdown scan list.
Ideas?
MrEngman
Sat Jan 07, 2017 8:48 pm
dlernstrom wrote:MrEngman,
Cheers,
David
The kernel version and build you show doesn't look like a normal Raspbian. I have not seen a build #3 for kernel 4.4.9-v7+ and so there is no driver. I would expect builds #883 or #884. Tried on a Pi here with Raspbian 4.4.9-v7+ #884 and installs the driver OK.
dlernstrom wrote:My previous post was using a recent Raspbian Jessie Lite image (can't remember Sep or Nov).
Ideas?
The driver should be installed OK. For whatever reason the format of the mt7610 driver keeps being changed and keeping this up to date is a bit of a pain so errors can appear occasionally.
I don't have a TP-Link Archer T1U but do have an Archer T2U using the MT7610 driver. That sees 5GHz APs using command sudo iwscan wlan0 scan and is currently connected to a 5GHz AP.
There is a new script which shouldn't give the errors you see and if it gets updated it will automatically update itself. You can download and install it using commands
You will need to run the script using sudo install-wifi ..... Command sudo install-wifi -h will show help info.
MrEngman
dlernstrom
Sat Jan 07, 2017 10:16 pm
MrEngman
I appreciate your speedy reply. That is bizzare that the build number I had was different than what you were expecting. I just downloaded a fresh Raspbian Jessie Lite (2016-11-25) and it came up with build 4.4.34-v7+ #930.
I ran the script as you had suggested and it still compiled with errors. Here's the output:
Your current kernel revision = 4.4.34-v7+
Your current kernel build    = #930
There is a driver module available for this kernel revision.
Downloading the mt7610 driver.
Installing the mt7610 driver.
Installing driver module mt7610u_sta.ko.
install: cannot create regular file â/lib/modules/4.4.34-v7+/kernel/drivers/net/wirelessâ: No such file or directory
depmod: ERROR: could not open directory /lib/modules/4.4.34-v7+: No such file or directory
depmod: FATAL: could not search modules: No such file or directory
Loading and running the new mt7610 driver, mt7610u_sta.ko.
modprobe: ERROR: ../libkmod/libkmod.c:557 kmod_search_moddep() could not open moddep file '/lib/modules/4.4.34-v7+/modules.dep.bin'
I just ordered on Amazon an Archer T2U (TP-Link AC600 Wireless Dual Band USB Adapter (Archer T2U)) as you have recommended and am going to toss my TP-LINK AC450 Archer T1U out the window.
I'll post back what my findings are.
Again, thank you for your help. It is frustrating how 5GHz networks are proliferating around us yet it is difficult to deploy a device that can sit on those networks. Your efforts are greatly appreciated!
Cheers,
David
MrEngman
Sun Jan 08, 2017 1:25 am
Cheers,
David
I really don't understand why you are getting the errors you have if you have in fact installed Raspbian Jessie lite 2016-11-25. As it is kernel version 4.4.37-v7+ #930 the file /lib/modules/4.4.34-v7+/kernel/drivers/net/wireless does exist, or should, so why the error? I am really confused.
Just to test things out I created a new SD card using Raspbian Jessie lite 2016-11-25 and copied files ssh and wpa_supplicant.conf to the boot partition to enable SSH and configure the wifi when the Pi first booted. I inserted the card into my Pi 2B, connected my wifi module to the Pi and powered on the Pi. After it had booted up I then SSHed into the Pi which was connected to my network using a wired connection and first changed the password as recommended here
SSH is enabled and the default password for the 'pi' user has not been changed.
This is a security risk - please login as the 'pi' user and type 'passwd' to set a new password.
and and then downloaded and installed the file install-wifi using commands
I then ran the command sudo install-wifi and it installed the wifi driver with no errors.
pi@raspberrypi:~ $ sudo install-wifi
 *** Performing self-update
 *** Relaunching after update
Your wifi module is Bus 001 Device 004: ID 148f:761a Ralink Technology, Corp.
After a short delay the wifi started up and connected to my network without problems.
Just a thought. Which directory are you in when running the install-wifi script. You should be in your default home directory, /home/pi. Or have you changed user name and it may not be correctly set up? Or are you logging in as root? Whether any of these will cause a problem I don't know but I guess it could be a possibility.
MrEngman
wince321
Mon Jan 09, 2017 12:14 am
Thank you @MrEngman. you post 3238 worked for me after re-installing raspbian on my Raspberry PI 2B.
Vince
MattLate
Fri Jan 13, 2017 7:00 pm
A few quick notes... I am working with a TP-Link Archer T1U on a Raspberry Pi 3B, using Kernel 4.4.34-v7+. And it is working!
First off, thank you very much MrEngman for all your help and contributions to this community!
Second, in the
command provided above, make sure you use a uppercase letter "O". I was using a lowercase letter "o" at first, and those two have a very different outcome. Look at
wget --help
for clarification.
Third, after getting the driver loaded following MrEngman's directions above, my new 5GHz WiFi dongle was named "rename4". Reading through MrEngman's and epoch1970's comments in this post viewtopic.php?f=29&t=55527 led me to the fact that this new driver had created a new device rule, located at /etc/udev/rules.d/95-ralink.rules . There is only one line in this file, which was specifying that my new 5GHz WiFi dongle be named "wlan0". That of course conflicted with the onboard 2.4GHz WiFi device on the RPi 3B, so the 5GHz dongle was being named "rename4" instead.
All I had to do was edit the one line in the /etc/udev/rules.d/95-ralink.rules file from
ACTION=="add", SUBSYSTEM=="net", ATTR{type}=="1", KERNEL=="ra*", NAME="wlan0"
to
ACTION=="add", SUBSYSTEM=="net", ATTR{type}=="1", KERNEL=="ra*", NAME="wlan1"
Reboot and it worked!
StyletX
Sat Jan 14, 2017 11:49 am
Somebody could set the adapter in monitor mode?
