Connected a known working Pi but the screen doesn't turn on even after pressing the power button for 5 seconds.
Tried it with a PlayStation3 too and no joy with that either.
Did you try to switch it on when connected to the charger?scotty101 wrote:I haven't had any luck.![]()
Yes. Tried turning it on with and without the charger connected. I've raised a ticket and they are suggesting I change the Pi's resolution settings to 1366x768 and to try again. Did you have to do that? I thought HDMI devices could request a resolution from the connected device.Aydan wrote: Did you try to switch it on when connected to the charger?
If that works and you can't switch it on without the charger, then you have a defective one. You should open a ticket with nexdock support.
They can as long as there is an EEPROM correctly programmed with the EDID information on the LCD's driver board. Some are temperamental and need to be forced.scotty101 wrote: I thought HDMI devices could request a resolution from the connected device.
I didn't have to force resolution, right now I have a Pi3 conneced to it and it boots without problems into the correct resolution.scotty101 wrote:Yes. Tried turning it on with and without the charger connected. I've raised a ticket and they are suggesting I change the Pi's resolution settings to 1366x768 and to try again. Did you have to do that? I thought HDMI devices could request a resolution from the connected device.Aydan wrote: Did you try to switch it on when connected to the charger?
Same for me. Fedex notified me before I received the notification from NexDock.Koeshi wrote:I haven't received any e-mail notification. But I have received a text from Fedex regarding a delivery, I don't remember ordering anything that could be coming by courier recently so I assume it is the NexDock. Has this been the same experience for anyone else?
XD LOL ROFL and all that stuffscotty101 wrote:![]()
NexDock have just asked me to take the cover off the unit to look for any loose connections. Wish they'd just accept it is broken.
Can post the photos if anyone is interested.
That's pi specific - there's a fix here to add a line into crontab:Aydan wrote:I'm having a problem with the Keybard/Touchpad not autoconnection after boot/reboot![]()
crontab -e
@reboot echo “connect MACADDRESSOFNEXDOCK” | bluetoothctl
No wonder! Have a look at the images I posted of inside the NexDock, the speakers are tiny and underneath the dock.mikerr wrote:Sound is a bit quiet, and the touchpad varies from ok to jumpy - but overall a great device.
Go with the larger part. There is no excuse even for a new, small company to deliver broken kit. At the very least they need to learn to package their product better (if it was damaged in transit). If it was damaged before dispatch, they may need better QA. With luck they have planned for some level of problems and will accept responsibility and put things right ASAP. If they "get away" with it, they won't learn, and there will be more disappointed customers down the line.Koeshi wrote: Part of me says to leave it as it doesn't affect main functionality and they are a new company that had a bit of a struggle getting this off the ground. A larger part of me is pissed off because my new item that I paid for is broken.
I've had success contacting the team through their "Helpdesk" page on their website. They usually got back to me within 4 hours.Koeshi wrote: Anyone else had something similar and if so have you had any luck contacting the NexDock team?
This seriously sucks.
Very funny, with what am I supposed to click if i only have the Pi and the Nexdock?robin48gx wrote:Click the Bluetooth icon at the top and connect to the nexdock
echo "connect <MACADDRESS>" | bluetoothctl
This is probably due to low battery. I've had it happen as well. Charging fixes it.robin48gx wrote:Turned it back on and it was all shakey. The HDMI sometimes came on sometimes did not.
Not sure if PI HDMI buring out/HDMI cable/or Nexdock screen dropping out.
Will try a different pi3 tonight and post back ....
