texy
Re: Automatic setup for RTL8188CUS based wifi adapters
Mon Jun 18, 2012 6:50 pm
Can I just check - working ok for squeeze (various kernels), NOT curently working for wheezy.
Texy
MrEngman
Mon Jun 18, 2012 7:23 pm
texy wrote:Can I just check - working ok for squeeze (various kernels), NOT curently working for wheezy.
Texy
For me that's correct.
gjs
Mon Jun 18, 2012 10:38 pm
To get a Micronet SP907NS adaptor working with a WEP (not WPA) enabled wireless network, I had to run the script as per the instructions, then, when the adaptor would not get a DHCP address (because it was not connected to the access point) Ctrl-C to quit the script and edit /etc/network/interfaces and replace:
wpa-ssid "YourSSID"
wpa-psk "YourPassword"
with:
wireless-essid YourSSID
wireless-key YourPassword
Note there are no quotation marks used in the WEP version. The adaptor will not connect to the AP with the quotes in place.
'Hope that helps others.
MrEngman
Tue Jun 19, 2012 1:12 am
gjs wrote:To get a Micronet SP907NS adaptor working with a WEP (not WPA) enabled wireless network, I had to run the script as per the instructions, then, when the adaptor would not get a DHCP address (because it was not connected to the access point) Ctrl-C to quit the script and edit /etc/network/interfaces and replace:
wpa-ssid "YourSSID"
with:
Hi gjs,
Very useful bit of info, thanks very much for posting it.
MrEngman
MrEngman
Tue Jun 19, 2012 11:32 am
Texy
Hi Texy,
I now have the rtl8188cus wifi running on wheezy. The setup is the same as for squeeze. There is just one problem with wheezy - wpa_supplicant is not installed. Installing that and all is now running.
I have made a script that runs on the base wheezy image and is here.
If you have no wired internet connection to the Pi you will need to download 5 files to some other system, the driver and 4 files needed to install wpa_supplicant and then copy all the files and the script to the /boot directory when you make the SD card image. The files needed are
http://dl.dropbox.com/u/80256631/8192cu-20120611.tar.gz
http://ftp.uk.debian.org/debian/pool/main/w/wpa/wpasupplicant_1.0-2_armel.deb
http://ftp.uk.debian.org/debian/pool/main/p/pcsc-lite/libpcsclite1_1.8.3-3_armel.deb
http://ftp.uk.debian.org/debian/pool/main/libn/libnl3/libnl-genl-3-200_3.2.7-2_armel.deb
http://ftp.uk.debian.org/debian/pool/main/libn/libnl3/libnl-3-200_3.2.7-2_armel.deb
So make the SD card image and copy all the files and the script to the /boot partition. Put the card in the Pi, boot up,login and run through the initialisation and then reboot to allow the main partition to be re-sized. Login and then run the script
sudo /boot/install-wheezy-rtl8188cus-20120619.sh
When the script finishes insert the wifi adapter and the Pi will reboot. The wifi should be running and you can then run
sudo apt-get update
sudo apt-get upgrade
to update the firmware and wheezy code.
If you have a wired connection to the Pi the install is pretty much the same except you only need to copy the installation script to the SD card. Let the Pi run and initialise then reboot and re-size the main partition. Restart the Pi and run the script
When the installation is finished it will ask you to plug in the wifi adapter and unplug the wired connection and will then reboot. The wifi should run and you can then run the update as above to upgrade the firmware and software.
Hope this is useful. Would be a good idea to include wpa_supplicant in the wheezy image. Would save a bit of head scratching. :)
Montala
Tue Jun 19, 2012 11:41 am
OK, so the question has to be asked... has anyone tried the latest (install-wheezy-rtl8188cus-20120619.sh) script with the new 'beta' release of 'wheezy' which has just been released, and if so, does it work OK?
(Debian Wheezy 'beta' download can be found on the front page of http://www.raspberrypi.org/ )
MrEngman
Tue Jun 19, 2012 11:47 am
Seems like the beta version has just been put up on the web site so I'm downloading it and will try it as well shortly.
asb
Tue Jun 19, 2012 11:50 am
MrEngman wrote:Seems like the beta version has just been put up on the web site so I'm downloading it and will try it as well shortly.
It has wpasupplicant and wireless-tools as well.
texy
Tue Jun 19, 2012 12:19 pm
You da man ;)
I look forward to trying it tonight - perhaps with an even later script if needed, in lieu of todays beta wheezy release.
Once again, many many thanks for your hard work - I am in great awe of your skills ;)
Texy
MrEngman
alpha or beta?
MrEngman
Tue Jun 19, 2012 12:20 pm
You da man ;)
Texy
Skill :?: More trial and error I think :lol:
asb
Tue Jun 19, 2012 12:25 pm
alpha or beta?
Beta.
fbutler
Tue Jun 19, 2012 1:43 pm
I've just tried the install-wheezy-rtl8188cus-20120619.sh script with the latest beta Wheezy image after doing an "apt-get update" and an "apt-get install" and I'm seeing the following types of error messages related to the driver on reboot:
Jun 19 13:34:14 raspberrypi kernel: [ 2124.621092] 8192cu: disagrees about version of symbol alloc_etherdev_mqs
Jun 19 13:34:14 raspberrypi kernel: [ 2124.621139] 8192cu: Unknown symbol alloc_etherdev_mqs (err -22)
Jun 19 13:34:14 raspberrypi kernel: [ 2124.621288] 8192cu: disagrees about version of symbol skb_copy_bits
Jun 19 13:34:14 raspberrypi kernel: [ 2124.621313] 8192cu: Unknown symbol skb_copy_bits (err -22)
Jun 19 13:34:14 raspberrypi kernel: [ 2124.621373] 8192cu: disagrees about version of symbol skb_put
Jun 19 13:34:14 raspberrypi kernel: [ 2124.621392] 8192cu: Unknown symbol skb_put (err -22)
Jun 19 13:34:14 raspberrypi kernel: [ 2124.621479] 8192cu: disagrees about version of symbol __netif_schedule
Jun 19 13:34:14 raspberrypi kernel: [ 2124.621501] 8192cu: Unknown symbol __netif_schedule (err -22)
Jun 19 13:34:14 raspberrypi kernel: [ 2124.621575] 8192cu: disagrees about version of symbol unregister_netdev
Jun 19 13:34:14 raspberrypi kernel: [ 2124.621597] 8192cu: Unknown symbol unregister_netdev (err -22)
Jun 19 13:34:14 raspberrypi kernel: [ 2124.621623] 8192cu: disagrees about version of symbol skb_dequeue
Jun 19 13:34:14 raspberrypi kernel: [ 2124.621642] 8192cu: Unknown symbol skb_dequeue (err -22)
MrEngman
Tue Jun 19, 2012 1:47 pm
OK, I've tried the beta version of wheezy and well - I have the rtl8188cus wifi working. :D No problems with wpa_supplicant this time.
It uses the same driver version used with the latest version of squeeze.
8192cu-20120617.tar.gz
The files needing modification are the normal ones used with the same content as is used with squeeze.
/etc/modprobe.d/blacklist.conf
/etc/modules
and the standard command to install the driver modules is used
install -p -m 644 8192cu.ko /lib/modules/3.1.9+/kernel/drivers/net/wireless/
alexeames
Tue Jun 19, 2012 2:22 pm
so we don't need the script with wheezy then? Sorry, I'm a bit confused :? But downloading wheezy as I type. 8-)
(Edit: Ah I read back a few posts and see there is a new script - gonna try that out)
Alex Eames RasPi.TV, RasP.iO
fbutler
Tue Jun 19, 2012 2:26 pm
After manually installing the 8192cu-20120617.tar.gz version of the driver with "install -p -m 644 8192cu.ko /lib/modules/3.1.9+/kernel/drivers/net/wireless/" the error messages went away and it is all working.
MrEngman
Tue Jun 19, 2012 2:56 pm
For those of you with tired fingers, sorry the filename is a little long, here is a script to add the rtl8188cus driver to the wheezy beta.
If you have a wired internet connection you can just download the script to the /boot directory
sudo wget -O /boot/install-wheezy-beta-rtl8188cus-20120619.sh http://dl.dropbox.com/u/80256631/install-wheezy-beta-rtl8188cus-20120619.sh
or download to the current directory, using the link above, and move it to the /boot directory, as the script expects to be run from the /boot directory,
sudo mv install-wheezy-beta-rtl8188cus-20120619.sh /boot
and then run it.
sudo /boot/install-wheezy-beta-rtl8188cus-20120619.sh
If you don't have an internet connection to your Pi download the script and driver, which is here, onto another machine and then copy both to the /boot directory of the SD card image and run the script. When done the Pi will reboot and the wifi should be up and running.
MrEngman
MrEngman
Tue Jun 19, 2012 3:18 pm
alexeames wrote:so we don't need the script with wheezy then? Sorry, I'm a bit confused :? But downloading wheezy as I type. 8-)
That's for the alpha. Look here for the script for the beta. Previous post as it happens.
MrEngman
MrEngman
Tue Jun 19, 2012 3:21 pm
Yes, that was for wheezy alpha.
fbutler
Tue Jun 19, 2012 4:06 pm
That explains it.
Thanks for your work on the script.
alexeames
Tue Jun 19, 2012 4:08 pm
MrEngman wrote:For those of you with tired fingers, sorry the filename is a little long, here is a script to add the rtl8188cus driver to the wheezy beta.
and then run it.
MrEngman
That worked an absolute treat. The only deviation from your excellent instructions was that I needed to
sudo chmod 755 install-wheezy-beta-rtl8188cus-20120619.sh
before the script would execute for the pi user (even with sodu)
MrEngman
Tue Jun 19, 2012 5:38 pm
alexeames wrote: That worked an absolute treat. The only deviation from your excellent instructions was that I needed to
Good to hear it's working.
Strange about the permissions though. No matter how I get the file to the /boot directory it always seems to end up with permissions set to 755 like all the other files there.
How are you moving the file to your /boot directory? I'm curious. Yet another Linux oddity.
alexeames
Tue Jun 19, 2012 7:43 pm
I think I did the wget straight from the /boot directory - that might explain it. To me, it was easier to go to the right place first and then use a shorter command - well it would've been shorter if I hadn't had to chmod. :lol:
MrEngman
Tue Jun 19, 2012 9:06 pm
Tried that, cd'ed into /boot, and then I had to use sudo wget otherwise it wouldn't save the file. Gave an error "Cannot write to ...... (permission denied) if I didn't use sudo. And again it ends up with permissions 775. Oh well. :?:
alexeames
Tue Jun 19, 2012 9:17 pm
MrEngman wrote: Tried that, cd'ed into /boot, and then I had to use sudo wget otherwise it wouldn't save the file. Gave an error "Cannot write to ...... (permission denied) if I didn't use sudo. And again it ends up with permissions 775. Oh well. :?:
Pretty sure I did sudo it too. But hey - these things called computers don't always do the same as each other - and humans are worse. :lol:
Return to “Beginners”
