New problem i have a perl script that is not workin on the raspberry PI B+ with debian jessie
#!/usr/bin/perl
require 5.000;
# FBB Word filter & 7PLUS capture
# Author: Stewart Wilkinson G0LGS
# Nothing below here should need changing (unless its broken)
$Vers="0.60";
$VDate="20-Mar-2005";
$VData="M_Filter & 7PLUS capture for XFBB 7.01+ (c) 2005 by G0LGS V${Vers} ${VDate}.";
# Read Settings from FBBCONFIG
&ReadFBB_CFG;
# M_FILTER Config File.
$MYCFG="/usr/local/lib/fbb/filter/m_filter.cfg";
# $MYCFG="${CONF}/usr/local/lib/fbb/filter/m_filter.cfg";
$CONF="/usr/local/var/ax25/fbb";
# Wrong number of Parameters ?
if( $#ARGV < 4 ){
printf STDERR "%s\n", ${VData};
if( ! -f ${MYCFG} ){
printf STDERR "WARNING: The Config File %s required by m_filter is missing or unreadable.\n", ${MYCFG};
printf STDERR "Please correct the problem, as Message Filtering will not work without it.\n";
exit 0;
# The Parameters
$Mesg=$ARGV[0];
$Type=$ARGV[1];
$From=$ARGV[2];
$To=$ARGV[3];
$RecNo=$ARGV[4]; # Seems to Always be 0 in XFBB.
# Date / Time
($sec,$min,$hour,$mday,$mon,$year,$wday,$yday) = localtime(time);
$SEC=("00".."59")[$sec];
$MIN=("00".."59")[$min];
$HOUR=("00".."23")[$hour];
$MDAY=("00".."31")[$mday];
$MON=("01".."12")[$mon];
$YEAR=("00".."99")[$year % 100];
# Weekly Log File Name
$week=int((${yday}+1) / 7);
$WK=("00".."53")[$week];
$LOGF="${DATA}/log/mftlog.${WK}";
# Some Default Values / Settings
$Subject="(no subject)";
$AUTO7PLUS=1;
$KMAIL=1;
$HMAIL=1;
$LOG=1;
$CAPT="/usr/local/lib/fbb/filter/m_filter.fwd";
# Read our Config file & build our list of search words.
&ReadMY_CFG;
# Don't try to trap our own Messages, as that will cause an endless loop
if( (${From} =~ /^${WHOAMI}$/) && (${To} =~ /^${SYSCALL}$/ ) ){
exit 0;
# Do we Check Private Messages ?
if( ($Type =~ /p/i) && (!defined($CHECKPRIVATE) || (! $CHECKPRIVATE) ) ){
exit 0;
$Hold=0;
$Kill=0;
$Found="";
# Check To:
foreach $A (@ToFl) {
if( ${To} =~ /(${A})/i) {
$Found="$1";
$line=${To};
$Hold=1;
last;
if( ${Hold} ){
&DoMsg("Held","To");
exit 3;
# Check From:
foreach $A (@FmFl) {
if( ${From} =~ /(${A})/i) {
$Found="$1";
$line=${From};
$Hold=1;
last;
if( ${Hold} ){
&DoMsg("Held","From");
exit 3;
# Subject / Message ID Checking
# Open dirmes.sys
if( open(DIRMES, '<', ${DIRMES} ) ) {
# Move to the appropriate Record
# (Always seems = 0 in XFBB).
seek(DIRMES, ${RecNo} * 194, 0);
# Read the Record
if( read( DIRMES, $Rec, 194 ) == 194 ) {
# Extract Data from Record.
($type,$Stat,$Num,$Size,$Date,$Adjbbs,$Route,$Destn,$to,$MID,$Subject,$Resv,$Crdate,$Stdate,$Bbs1,$Bbs2) =
unpack("Z Z L L L Z7 Z41 Z7 Z7 Z13 Z61 Z16 L L A10 A10", $Rec);
# Check Message ID
foreach $M (@Mid) {
if( ${MID} =~ /(${M})/i) {
$Found="$1";
$Hold=1;
last;
if( ${Hold} ){
&DoMsg("Held", "MID");
exit 3;
# Check Subject
foreach $A (@Subj) {
if( ${Subject} =~ /(${A})/i) {
$Found="$1";
$Hold=1;
last;
#Check for Kill Words
foreach $KILL (@Kill) {
if( ${Subject} =~ /(${KILL})/i) {
$Found="$1";
$Kill=1;
last;
if(${Kill}){
&DoMsg("Killed", "Subject");
exit 1;
# Check for Hold Words
foreach $HOLD (@Hold) {
if( ${Subject} =~ /(${HOLD})/i) {
$Found="$1";
$Hold=1;
last;
if( ${Hold} ){
&DoMsg("Held", "Subject");
exit 3;
close(DIRMES);
# Open the Message.
if( ! open( MESG, '<', ${Mesg} ) ){
printf STDERR "Unable to open Message '%s'\n", ${Mesg};
exit 0;
# Check R: Lines
$Pos = tell(MESG);
while(($line = <MESG>) ){
chomp($line);
# Is this an R-Line ?
if( $line =~ /^R\:\d{6,}\/\d{4}[zZ]{0,1}\s+\d*\@[\:]{0,1}(\S+)/i ) {
if( !defined(${Via}) ) {
$Via = $1;
$Via =~ /^(\w*)\.(.*)$/;
$via = $1;
foreach $RL (@Rlin) {
if( $line =~ /(${RL})/i) {
$Found="$1";
$Hold=1;
last;
if( $Found ){
last;
if( $line =~ /(${KILL})/i) {
$Found="$1";
$Kill=1;
last;
if( $Found ){
last;
if( $line =~ /(${HOLD})/i) {
$Found="$1";
$Hold=1;
last;
if( $Found ){
last;
# No more R:Lines
}else{
seek(MESG, $Pos, 0);
last;
}continue{
$Pos = tell(MESG);
if( ${Kill} ){
&DoMsg("Killed", "R-line");
close(MESG);
exit 1;
if( ${Hold} ){
&DoMsg("Held", "R-line");
close(MESG);
exit 3;
$Is7plus=0;
# Check for 7PLUS
if( defined(${AUTO7PLUS}) && ${AUTO7PLUS} ) {
# Check if this the Message has any 7plus
$Pos = tell(MESG);
while($line = <MESG>){
chomp($line);
# Translate 'non-printable' characters to '.'
$line =~ s/[\x01-\x1f]/\./g;
$line =~ s/[\x80-\xff]/\./g;
# Ignore blank lines
if( $line =~ /^\s*$/ ){
next;
}elsif( $line =~ /\_7\+/ ){
${Is7plus} = 1;
last;
seek(MESG, ${Pos}, 0);
# Append to 'mfilter.fwd' file
if( ${Is7plus} ){
if( open( CAPT, '>>', ${CAPT} ) ){
# Message Header
printf CAPT "SP %s \< %s\n", ${To}, ${From};
printf CAPT "%s\n", ${Subject};
# Start at top Of Message
seek(MESG, 0, 0);
# Append to file
print CAPT <MESG>;
# Reset MESG pointer for rest of checks.
printf CAPT "/EX\n";
close(CAPT);
# Check the Message Text
$Pos = tell(MESG);
chomp($line);
next;
# Check for Kill Words
$Found="$1";
$Kill=1;
last;
if($Found){
last;
$Found="$1";
$Hold=1;
last;
if($Found){
last;
}continue{
$Pos = tell(MESG);
if(${Kill}){
&DoMsg("Killed", "Message");
close(MESG);
exit 1;
if(${Hold}){
&DoMsg("Held", "Message");
close(MESG);
exit 3;
close(MESG);
# Message Check complete / Tell XFBB to accept message
exit 0;
# Functions used above
# Generate LOG Entry / SYSOP Message
sub DoMsg
local( $Action ) = $_[0];
local( $Where ) = $_[1];
if( defined(${LOG}) && ${LOG} ){
if( open(LOG, '>>', ${LOGF} ) ) {
if( defined($via) ) {
printf LOG "%02d/%02d/%02d %02d:%02d:%02d %s Fm:%s To:%s Via:%s Fnd:%s in %s\n", ${MDAY}, ${MON},${YEAR},${HOUR},${MIN},${SEC}, ${Action}, ${From}, ${To}, ${via}, ${Found}, ${Where};
}else{
printf LOG "%02d/%02d/%02d %02d:%02d:%02d %s Fm:%s To:%s Fnd:%s in %s\n", ${MDAY}, ${MON},${YEAR},${HOUR},${MIN},${SEC}, ${Action}, ${From}, ${To}, ${Found}, ${Where};
close(LOG);
# Generate SYSOP Message ?
if( ( (${Action} =~ /^killed/i) && (defined(${KMAIL}) && ${KMAIL}) )
|| ( (${Action} =~ /^held/i ) && (defined(${HMAIL}) && ${HMAIL}) ) ) {
if( open(LOCK, '>', ${LOCK} ) ) {
printf LOCK "$$";
if( open(MAIL, '>>', ${MAIL} ) ){
printf MAIL "SP %s < %s\n", ${SYSCALL}, ${WHOAMI};
printf MAIL "Message from: %s ${Action}\n\n", ${From};
printf MAIL "%s\n\n", ${VData};
if( $Where =~ /^Message/i ){
printf MAIL "Message From: %s To: Q%sQ - %s because %s contained:\n", ${From}, ${To}, ${Action}, ${Where};
printf MAIL "the word or phrase 'Q%sQ' in the following line from the message:-\n\n", ${Found};
printf MAIL "%s\n\n", ${line};
}elsif( $Where =~ /^Subject/i ){
printf MAIL "Message From: %s To: Q%sQ - %s because %s contained\n", ${From}, ${To}, ${Action}, ${Where};
printf MAIL "the word or phrase 'Q%sQ' (Subect: 'Q%sQ')\n\n", ${Found}, ${Subject};
}else{
printf MAIL "Message From: %s To: %s - %s because %s contained\n", ${From}, ${To}, ${Action}, ${Where};
printf MAIL "the word or phrase 'Q%sQ'\n\n", ${Found};
if( defined(${Via}) ) {
printf MAIL "\nThe message was forwarded from 'Q%sQ'\n\n", ${Via};
printf MAIL "/EX\n";
close(MAIL);
close(LOCK);
unlink(${LOCK});
sub IsEnabled
local($Ret) = 0;
local($P) = $_[0];
if( ($P =~ /^0/) || ($P =~ /^n\S*/i) || ($P =~ /^off/i) || ($P =~ /^di\S*/i) ){
${Ret}=0;
}elsif( ($P =~ /^1/) || ($P =~ /^y\S*/i) || ($P =~ /^ok/i) || ($P =~/^on/i) || ($P =~ /^en\S*/i) ){
${Ret}=1;
return ${Ret};
sub ReadFBB_CFG
# Where is FBB Config File
$FBBCONF="/usr/local/etc/ax25/fbb/fbb.conf";
if( defined( $ENV{FBBCONF} ) && "$ENV{FBBCONF}" != "" ){
$FBBCONF = $ENV{FBBCONF}
# Read things we need from FBB Config file
if(! open( FBBCONF, '<', $FBBCONF) ) {
printf STDERR "Unable to open '%s'\n", ${FBBCONF};
exit 1;
while($line = <FBBCONF>) {
chomp($line);
if( $line =~ /^\s*\#/) {
next;
}elsif( $line =~ /^\s*$/) {
next;
}else{
$line =~ /^\s*(\S*)\s*\=\s*(.*)$/;
$item = $1;
$value = $2;
if( $item =~ /^callsign/ ){
$value =~ /^(\w*)\.(.*)$/;
$BBSCALL = $1;
$BBSHR = $2;
$WHOAMI = $BBSCALL;
}elsif( $item =~ /^data/ ){
$value =~ /^(\S*)$/;
$DATA = $1;
$DIRMES="${DATA}/dirmes.sys";
}elsif( $item =~ /^conf/ ){
$CONF = $1;
}elsif( $item =~ /^name/ ){
$NAME = $1;
}elsif( $item =~ /^syso/ ){
$SYSCALL = $1;
}elsif( $item =~ /^impo/ ){
$value =~ /^([^\.]\S*)\.(\S*)$/;
$MAIL = "$1.$2";
$LOCK = "$1.lck";
close(FBBCONF);
sub ReadMY_CFG
if( ! open( MYCFG, '<', ${MYCFG} ) ) {
if( ! -f "${CONF}/m_filter.warn" ){
printf LOCK "$$";
printf MAIL "WARNING: M_Filter Config Error\n\n";
printf MAIL "The Config File %s required by m_filter is missing or unreadable.\n", ${MYCFG};
printf MAIL "Please correct the problem, as Message Filtering will not work without it.\n";
close(MAIL);
close(LOCK);
unlink(${LOCK});
if( open(WRN, '>', "${CONF}/m_filter.warn" ) ){
print WRN "m_filter is not correctly configured !";
close WRN;
exit 0;
if( -f "${CONF}/m_filter.warn" ){
unlink( "${CONF}/m_filter.warn" );
$Subj=0;
$Rlin=0;
$ToFl=0;
$FmFl=0;
$Hold=0;
$Kill=0;
$Mid=0;
while(<MYCFG>) {
chomp;
# Comments
if( /^\s*\;/ ) {
next;
}elsif( /^\s*\#\S*/ ){
next;
# Blank Lines
}elsif( /^\s*$/ ) {
next;
# Generate Filter message for Held Messages ?
}elsif( /^\s*\!\s*MAIL\s*\=\s*(\S*)/ ){
$HMAIL = &IsEnabled($1);
next;
# Generate Filter message for Killed Messages ?
}elsif( /^\s*\!\s*KMAIL\s*\=\s*(\S*)/ ){
$KMAIL = &IsEnabled($1);
next;
# 7PLUS Capture ?
}elsif( /^\s*\!\s*AUTO7PLUS\s*\=\s*(\S*)/ ){
$AUTO7PLUS = &IsEnabled($1);
next;
# CHECK PRIVATE Messages ?
}elsif( /^\s*\!\s*CHECKPRIVATE\s*\=\s*(\S*)/ ){
$CHECKPRIVATE = &IsEnabled($1);
next;
# FBB m_filter.fwd (for 7plus AutoCapture)
}elsif( /^\s*\!\s*7PLUS\s*\=\s*(\S*)/ ){
$CAPT="$1";
# FILTER Messages From:
}elsif( /^\s*\!\s*WHOAMI\s*\=\s*(\S*)/ ){
$WHOAMI = $1;
# Logging ?
}elsif( /^\s*\!\s*LOG\s*\=\s*(\S*)/ ){
$LOG = &IsEnabled($1);
next;
# Kill Words / Phrases
}elsif( /^\s*\!\sKILL/i ) {
$Subj=0;
$Rlin=0;
$ToFl=0;
$FmFl=0;
$Hold=0;
$Kill=1;
$Mid=0;
# Hold Words / Phrases
}elsif( /^\s*\!\sHOLD/i ) {
$Subj=0;
$Rlin=0;
$ToFl=0;
$FmFl=0;
$Hold=1;
$Kill=0;
$Mid=0;
# R:Line Words / Phrases
}elsif( /^\s*\!\sRLINE/i ) {
$Subj=0;
$Rlin=1;
$ToFl=0;
$FmFl=0;
$Hold=0;
$Kill=0;
$Mid=0;
# To Calls to Check
}elsif( /^\s*\!\sTO/i ) {
$Subj=0;
$Rlin=0;
$ToFl=1;
$FmFl=0;
$Hold=0;
$Kill=0;
$Mid=0;
# From Calls to Check
}elsif( /^\s*\!\sFROM/i ) {
$Subj=0;
$Rlin=0;
$ToFl=0;
$FmFl=1;
$Hold=0;
$Kill=0;
$Mid=0;
# Additional Subject Words
}elsif( /^\s*\!\sSUBJECT/i ) {
$Subj=1;
$Rlin=0;
$ToFl=0;
$FmFl=0;
$Hold=0;
$Kill=0;
$Mid=0;
# Message ID's
}elsif( /^\s*\!\sMID/i ) {
$Subj=0;
$Rlin=0;
$ToFl=0;
$FmFl=0;
$Hold=0;
$Kill=0;
$Mid=1;
# Ignore unknown config lines.
}elsif( /^\s*\!\S*/i ) {
next;
}else{
# Format Word / Phrase for PERL Regular Expression Handling.
# Add '\' escapes to some special characters
s/([\#\!\@\:\[\]\\\/\.\*\?])/\\$1/g;
# Change any ' ' to '\s{1}' (match exactly 1 space)
s/\ /\\s{1}/g;
# Insert Temporary Leading Space (so that some of the remaining
# checks work at the begining of the line)
$_ = " " . $_;
# Change '+', but not '%+' to '\b' (word boundary)
s/([^%])\+/$1\\b/gx;
# Change '%+' to '\+'
s/%\+/\\+/g;
# Change '_', but not '%_' to '\s+' (one or more spaces)
s/([^%])_/$1\\s+/gx;
# Change '%_' to '_'
s/%_/_/g;
# Change '%d' to '\d' (decimal number)
s/%d/\\d/gi;
# Change '%s' to '\S' (non-space char)
s/%s/\\S/gi;
# Remove Leading Space
s/^\ //;
if($Subj){
push( @Subj, $_ );
}elsif($Rlin){
push( @Rlin, $_ );
}elsif($ToFl){
push( @ToFl, $_ );
}elsif($FmFl){
push( @FmFl, $_ );
}elsif($Hold){
push( @Hold, $_ );
}elsif($Kill){
push( @Kill, $_ );
}elsif($Mid){
push( @Mid, $_ );
close(MYCFG);
; This is the config file for G0LGS's M_FILTER for Linux XFBB.
; Blank lines are ignored as are lines starting with a ';' or '#'
; Config Options (yes/ok/on/1/en = Enable, no/off/0/di = Disable);
! MAIL = no ; Tell Sysop about Held Mail (Default = yes)
! KMAIL = no ; Tell Sysop about Killed Mail (Default = yes)
! CHECKPRIVATE = yes ; Do we Check Private Messages ?
! AUTO7PLUS = yes ; Do we Auto Collect 7plus (default = yes)
! 7PLUS = /usr/local/lib/fbb/filter/m_filter.fwd
; Where to place 7plus Extracts.
; Default = /usr/local/lib/fbb/filter/m_filter.fwd
! WHOAMI = NL4PRC ; From 'Callsign' for FILTER Messages
; Default = FILTER (V0.5x)
; BBSCall (from V0.60)
! LOG = yes ; Enable Logging (default = yes)
; Lines beyond this point which start with '!' are important
; and MUST NOT be removed or changed.
; Each line should be a word (or partial word) or even a phrase to
; look for (Not case sensitive).
; Use '_' to match one or more spaces in middle of a word or phrase.
; ( use '%_' to match a real '_' )
; Use a space (' ') where you want to match exactly one space.
; you can also use:
; +word match at begining of word
; word+ match at end of word
; +word+ match whole word only
; (use '%+' to match a real '+')
; These should also work:
; ^word match ONLY at start of a line.
; word$ match ONLY at end of a line.
; These are available from V0.52 :
; %d decimal number
; %d{m} decimal number exactly m digits long
; %d{m,} decimal number m or more digits long
; %d{m,n} decimal number between m & n digits long
; %s any string (except space)
; %s{m} any string exactly m chars long
; %s{m,} any string m or more chars long
; %s{m,n} any string between m & n chars long
; Kill These on sight !!
! KILL
; Hold These for review
! HOLD
ABUSE+
abuse+
abuse!+
ABUSE!+
+Doorgestuurd bericht+
+login password+
; Additional Hold Words for Subject
; The Subject are checked for HOLD/KILL words plus anything listed here:
! SUBJECT
Filer's_Files
; Hold on From: Field
! FROM
; Examples:
; Any Italian Callsign
;I%s{0,1}%d{1,2}%s{1,3}
; Any German Callsign
;D%s{0,1}%d{1,2}%s{1,3}
; UK Calligns
;G%s{0,1}%d{1}%s{1-3}
;M%s{0,1}%d{1}%s{1-3}
;2%s{1}%d{1}%s{1-3}
; Hold on To: Field
! TO
; Hold on R: line
; (R: Lines gets checked for HOLD/KILL words plus anything listed here).
! RLINE
; Old messages
^R:99%d{4}/%d{4}%s{0,1}[email protected]:%s{1,}
^R:00%d{4}/%d{4}%s{0,1}[email protected]:%s{1,}
^R:01%d{4}/%d{4}%s{0,1}[email protected]:%s{1,}
^R:02%d{4}/%d{4}%s{0,1}[email protected]:%s{1,}
^R:03%d{4}/%d{4}%s{0,1}[email protected]:%s{1,}
; non-Y2K R-lines
^R:101%d{4}/%d{4}%s{0,1}[email protected]:%s{1,}
^R:102%d{4}/%d{4}%s{0,1}[email protected]:%s{1,}
^R:103%d{4}/%d{4}%s{0,1}[email protected]:%s{1,}
^R:104%d{4}/%d{4}%s{0,1}[email protected]:%s{1,}
^R:105%d{4}/%d{4}%s{0,1}[email protected]:%s{1,}
; CB Systems:
; NL3DHR.NH.NLD.EU
; EA8EE has been sending Internet newsgroups, so check all messages
; passing through his system.
EA8EE
; Hold on Message ID - Requires V0.60
! MID
%d{1,6}%_XXXXXX
%d{1,6}-XXXXXX
