When I try to connect to my Raspberry Pi via PuTTy I get "access denied" after entering the password. I know the Pi is connected to the network because I can ping its IP address from the PC with no issues. Even tried connecting SSH through the Pi's terminal and get "Permission denied" after inputting the password. Double checked that I'm using the correct password. I have two Pi's with the same Raspbian image and I'm unable to connect to either via SSH. Restarted the router just to check that possible issue off.
Any suggestions on what to look for would be greatly appreciated.
Thank you
