jwitch
PXE OTP/GPIO testing
Fri Jul 01, 2016 10:44 am
I understand that USB/PXE boot is still being tested. Apparently these features are enabled by writing an OTP bit and pulling a GPIO pin.
Therefore, presumably we will need an SD card with a boot.txt config something along the lines of "program_enable_pxe=1" to initially enable PXE booting? Could someone enlighten me what that config is and which GPIO to pull so that I can see DHCP/PXE packets with wireshark?
Many thanks
Re: PXE OTP/GPIO testing
Fri Jul 01, 2016 11:10 am
jwitch wrote:I understand that USB/PXE boot is still being tested. Apparently these features are enabled by writing an OTP bit and pulling a GPIO pin.
Many thanks
Please be aware that is is only for the RPi 3B at present and has already been discussed:
viewtopic.php?f=63&t=138071
viewtopic.php?f=91&t=138786&start=50
search.php?keywords=pxe&t=137932&sf=msgonly
etcetera etcetera etcetera
Asus ChromeBox 3 Celeron is my other computer.
gregeric
Fri Jul 01, 2016 11:17 am
Hi jwitch & welcome to the forums :roll:
See https://github.com/raspberrypi/document ... /Readme.md
Fri Jul 01, 2016 11:29 am
gregeric wrote:Hi jwitch & welcome to the forums :roll:
This is preliminary information used by the beta testers for the development of the bootcode for mass storage and ethernet boot, but it is currently incorrect and not working.
0xFF
Fri Jul 15, 2016 12:31 pm
Is
program_usb_boot_mode=1
option reversible ?
Can I disable usb boot option back, with?
program_usb_boot_mode=0
AFAIK OTP means one-time programming read-only memory ;-)
Aydan
Fri Jul 15, 2016 2:53 pm
0xFF wrote:Is
option reversible ?
AFAIK it's not reversible, but why would you need to. USB boot is the last boot option, so as long as an SD card is inserted with valid boot files, you won't even get to USB.
Regards
Aydan
Return to “Advanced users”
