nl3prc wrote:
as you kan see the sda6 partition is in the range of the sda2 so here you can see that the sda6 is in the sda2 partition here is the problem that you can't make sda6 bigger than 6.2gig no matter what your sdcard size
Believe-it-or-not, re-reading this, while looking at your [enlarged] graphic, makes sense.
However, this does not completely erase my "uncertainties", regarding my own scenario.
I do want to thank you for your input here; once the term "partition" was mentioned, things seem to be making (slightly) "better" sense to me (though STILL a bit blurry).
Correct me here-and-now, please, if I do not have THIS correct:
Each of the 3 OS's that are installed-and-functioning (for me) can only see THAT "partition" to which they are installed.
Assuming that the above statement is "axiomatic", my question can now be more clearly "framed" (I think).
My desire REMAINS to understand whether-or-not there is ANY chance of making the "unused portion" of these 32GB cards "usable/accessible-to" the OpenElec(Kobi) part of the "Triple-boot-System".
W. H. Heydt wrote (above):
"If you use the expand option, the root filesystem is extended to use the otherwise unused space..."
I am NOW "fully-lost" as to the fundamental vision of "root", when discussing this scenario. Do I, or do I not have 4 distinct / different "roots"? 1)Berryboot("primary"), 2)Raspian-boot, 3)OpenElec-boot, 4)UbuntuMate-boot...?
In order to try to more clearly understand what my "Pi" can see on the card, I tried what you had suggested:
fdisk /dev/mmcblk0
{{and I got}}
Welcome to fdisk (util-linux 2.25.2).
Changes will remain in memory only, until you decide to write them.
Be careful before using the write command.
fdisk: cannot open /dev/mmcblk0: Permission denied
So : I re-booted [having a "vague_image" of that "sector_designation" in my mind from booting (and re-booting) so many times]
and , saw THIS:
- booting_1.jpg (24.72 KiB) Viewed 2063 times
So I tried the ^above^ command again, using "mmcblk0p2" and,
got the same "error msg":
fdisk: cannot open /dev/mmcblk0p2: Permission denied
To anybody who now understands my confusion, I ask:
What command(s) might I use, in order to find out EXACTLY how much "usable_space" IS available to each of the 3 OS's on my cards...?
AND - (again, in "Layman's terms", if possible): is there any way whatsoever that the "unused" portion of these 32GB cards might be made "usable" by the Pi's...?
Thanks to all for sharing...(!)
