teachescompsci
Cables for lapdock
Fri Jul 18, 2014 12:56 pm
Hi Everybody
I've got myself a lapdock and I'm trying to sort out the cables to connect to my B+.
I've read loads of posts, especially some by Dave about Y-shaped cables, but I really just want to use the same ones we had at Picademy.
Did we use the following:
USB - a USB male to micro USB female cable (with a switch on it??)?
HDMI - A HDMI male to micro HDMI male cable with a micro HDMI female-female adaptor/coupler?
I can't find the USB cable we used and most of the posts I've read just use an adapter, but I want a cable - so the pi sits away from my lapdock.
For the HDMI the only micro HDMI female to female adapter I can find is in China!!!
Can you let us know where you got the cables for Picademy from?
Many thanks
Christine
Christine Harvey
@teachescompsci
becsalana
Raspberry Pi Certified Educator
Re: Cables for lapdock
Sat Jul 19, 2014 9:47 am
Hi Christine
I have bought the following which I researched and seem to be the correct ones we used. I don't have my lapdock yet - takes a while to arrive from Tel Aviv!
Ex-Pro® USB 2.0 Cable Type A Male to A Female Extension cable - 1m [100cm]
http://www.amazon.co.uk/gp/product/B007 ... UTF8&psc=1
Ex-Pro® Micro USB Type B Female to USB Type A Male
http://www.amazon.co.uk/gp/product/B008 ... UTF8&psc=1
Quality HDMI Extension Cable Lead, Male to Female - Black
http://www.amazon.co.uk/gp/product/B006 ... UTF8&psc=1
Micro Hdmi Female HDMI Adapter Type A Male to Type D
http://www.amazon.co.uk/gp/product/B00G ... UTF8&psc=1
Cheers
Matthew
Matthew Parry
@becsalana
Raspberry Pi Certified Educator 2014
CAS Master Teacher
teachescompsci
Sat Jul 19, 2014 9:56 am
Thanks Matthew they look great, although you may need to shave a bit off the HDMI adapter to fit them both side by side on the lapdock. I've seen lots of blogs/posts where people have had to do it!
I'd still like to know where Picademy got theirs from!
Christine Harvey
@teachescompsci
bantammenace2012
Sat Sep 06, 2014 9:16 am
teachescompsci wrote:Thanks Matthew they look great, although you may need to shave a bit off the HDMI adapter to fit them both side by side on the lapdock. I've seen lots of blogs/posts where people have had to do it!
Hi there,
I just came across this supplier in the UK. perhaps a touch on the expensive side but from experience I know it can be very fiddly to DIY these cables.
4D : Product info for USB/Power & HDMI cable Set Atrix Lapdock to Raspberry Pi B+ etc. plus Real Time Clock with SuperCaps
http://www.cjemicros.co.uk/micros/indiv ... RTCSCBPLUS
kind regards
retknow
Wed Sep 10, 2014 6:56 pm
You can get this much cheaper cable here £5.99:
http://www.ebay.co.uk/itm/Raspberry-Pi- ... 3ce76145e8
Specially made for the Raspberry Pi - Lapdock.
Just add on a Hdmi adapter , shave the right side and squeeze in!.
http://www.ebay.co.uk/itm/Standard-HDMI ... 232ef17258
Tuk
Tue Aug 25, 2015 8:56 pm
Hello, I just ordered my Astrix, any idea where can I get those cables (B+ Pi) for a cheap price? That one from ebay is no longer available :oops:
Thank you.
Return to “Picademy”
