walt
[Fixed][Compute module] cannot boot up - USB Warning
Tue Sep 16, 2014 2:14 pm
HW: computer module + SMSC LAN9514
SW:
Official RASPBIAN
Debian Wheezy
Version:September 2014
Release date:2014-09-09
Default login:pi / raspberry
URL:raspbian.org
Kernel version:3.12
from http://www.raspberrypi.org/downloads/
I captured UART during booting:
USB Error
[ 1.950354] dwc_otg bcm2708_usb: irq 32, io mem 0x00000000
[ 1.957544] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.965694] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.974295] usb usb1: Product: DWC OTG Controller
[ 1.980360] usb usb1: Manufacturer: Linux 3.12.28+ dwc_otg_hcd
[ 1.987544] usb usb1: SerialNumber: bcm2708_usb
[ 1.994219] hub 1-0:1.0: USB hub found
[ 1.999455] hub 1-0:1.0: 1 port detected
[ 2.005091] WARN::dwc_otg_handle_mode_mismatch_intr:68: Mode Mismatch Interrupt: currently in Device mode
[ 2.005091]
[ 2.019944] WARN::dwc_otg_handle_mode_mismatch_intr:68: Mode Mismatch Interrupt: currently in Device mode
Briarios
Re: [Compute module] cannot boot up - USB Warning
Tue Sep 16, 2014 10:23 pm
Is the OTG pin grounded?, I think the OTG pin needs to be set in order to boot up as a host controller ( im just looking at the rpi documentation)
http://rpi.pmfg.me -- Test board Eagle Cad Files.
walt
Wed Sep 17, 2014 2:31 am
Great, I double check our IO board about USB_OTG_ID, which is float, while it is pulled low in RPI-CMIO-V1_2-SCHEMATIC.pdf.
Then I short it by GND.
The error is fixed!! Now, I could log in.
Thanks.
Briarios
Re: [Fixed][Compute module] cannot boot up - USB Warning
Wed Sep 17, 2014 3:07 am
Oh that is good :D
MDMoore313
Wed Sep 17, 2014 3:54 pm
walt wrote:Great, I double check our IO board about USB_OTG_ID, which is float, while it is pulled low in RPI-CMIO-V1_2-SCHEMATIC.pdf.
Thanks.
This worked for me as well, I have board rev. 1.2(c) for reference.
Return to “Compute Module”
