Page 1 of 2
How to get a 2nd Camera Adapter Board?
Posted: Thu Aug 21, 2014 6:58 am
by gordon@drogon.net
I want to run 2 cameras on a CMIO board.
The board comes with one camera and one display adapter board.
However neither Farnell nor RS stock the adapter boards as separate items and buying a 2nd CMIO board just to get a 2nd camera adapter board is somewhat extreme...
So how do I get a 2nd camera adapter?
Cheers,
-Gordon
Re: How to get a 2nd Camera Adapter Board?
Posted: Fri Aug 22, 2014 3:24 pm
by AndrewS
I'd like to know too... http://www.raspberrypi.org/forums/viewt ... 57#p599457
I emailed both Farnell and RS, and Farnell said "Our product manager for these isn't back until the week after next, so I've no way of finding out until then", and RS have yet to reply :(
Which I guess means it'll be hard for anyone to test http://www.raspberrypi.org/forums/viewt ... 43&t=85012 before 6by9 loses his access to the development tools? :?
Posted: Mon Aug 25, 2014 11:59 pm
by AndrewS
I received the following (slightly confusing) email from RS today (Monday), so I've emailed them back asking for clarification.
Please note the Raspberry Pi and accessories can no longer be purchased through the Pi store; however you may find an answer to your question using the link below.
http://www.raspberrypi.org/phpBB3/
We apologise for any inconvenience this may cause.
(From http://uk.rs-online.com/web/generalDisp ... aspberrypi it's obvious that they are still selling Raspberry Pis and accessories :? )
Bit frustrating to have a Compute Module IO board, and two Raspi Cameras, and software that now supports stereoscopic mode, but no way to actually use (or even test) two cameras at once :(
Posted: Tue Aug 26, 2014 6:27 am
I did tweet to both RS & CPC - CPC came back with a brief reply along the lines of "we'll see what we can do" ..
-Gordon
Posted: Tue Aug 26, 2014 7:47 am
by jamesh
I'll ping the Foundation and see what the plan is here - clearly they need to be available!
Posted: Tue Aug 26, 2014 7:58 am
jamesh wrote:I'll ping the Foundation and see what the plan is here - clearly they need to be available!
Thanks.
Probably not huge quantities, but it would be nice to have!
-Gordon
Posted: Tue Aug 26, 2014 11:09 am
by arm2
Gordon & AndrewS: I've an adaptor board I don't expect to use for a couple of months, if either of you are doing some development work, I could loan it to one of you! Can I suggest you talk to each other about your planned use, and hopefully agree which use will benefit the community most? please email me chris@cjemicros.co.uk n.b. I'm in the Sussex, I think both of you are in the UK.
Posted: Tue Aug 26, 2014 11:12 am
by AndrewS
Gordon would undoubtedly benefit from it more than I.
Posted: Tue Aug 26, 2014 11:16 am
arm2 wrote:Gordon & AndrewS: I've an adaptor board I don't expect to use for a couple of months, if either of you are doing some development work, I could loan it to one of you! Can I suggest you talk to each other about your planned use, and hopefully agree which use will benefit the community most? please email me chris@cjemicros.co.uk n.b. I'm in the Sussex, I think both of you are in the UK.
Thanks for the offer, but I'm not doing dev. work on the CM. I got a CM+IO board simply to test wiringPi, but I now have plans to use it for a daytime/nighttime garden camera with both a normal and noir camera on-board (and a ring of IR and visible white LEDs which I can control) Ultimately I'll do a write-up on it, but I don't think it's anything spectacular - its more a mechanical problem for me - making a relatively rain proof box for it all and possibly even a pan/tilt mechanism.
I'm in no real rush though.
-Gordon
Posted: Fri Aug 29, 2014 2:37 pm
by AndrewS
My email to RS finally filtered through to the right person, and I got this reply:
RS are not listing the camera adaptor boards I would suggest going directly to the Raspberry pi Foundation
Posted: Fri Aug 29, 2014 2:44 pm
by DougieLawson
AndrewS wrote:My email to RS finally filtered through to the right person, and I got this reply:
There's a word (starting with "W") to describe that, but I can't use it in a family forum.
Posted: Sun Aug 31, 2014 9:18 am
by mimi123
It's W00t? :lol: .
Posted: Sun Aug 31, 2014 10:30 am
by DougieLawson
mimi123 wrote:It's W00t? :lol: .
No. It rhymes with "bankers" (and curiously describes those money grabbing scum in great detail).
Posted: Sun Aug 31, 2014 10:42 am
I suspect it's just an oversight - no point name calling - the CMIO board is really intended as a "proof of concept" or "reference design" for others to use as their final product board - so one display and one camera module was probably all that people thought they'd need.
However I suspect that there are only a small number of us interested in 2 cameras, so all it would take is either RS or Farnell to "man up" and produce a small number - probably less than a couple of hundred and the first to do so will get fame and glory and praise from the community...
-Gordon
Posted: Sun Aug 31, 2014 11:42 am
by Cancelor
Yeyaaaa! ..... The daylight + PiNoir combo sounds especially interesting.
Posted: Mon Sep 01, 2014 10:11 pm
by AndrewS
gordon@drogon.net wrote:However I suspect that there are only a small number of us interested in 2 cameras, so all it would take is either RS or Farnell to "man up" and produce a small number - probably less than a couple of hundred and the first to do so will get fame and glory and praise from the community...
Yeah, since they had to do an additional manufacturing run of camera and display adaptors anyway (since the initial ones shipped with the DevKit were incorrect), I'd been assuming they'd make a few more than needed, and then make them available for sale separately... Seems that was a false assumption! :|
Posted: Fri Sep 12, 2014 8:57 am
by hayderOICO
I need this too!
any update on if and when this is available... I don't want to send back the devkit just due to this oversight (providing 2 ports, and then only one adaptor!?).
Posted: Fri Sep 12, 2014 9:01 am
Chatting to Eben at the CamJam last weekend, I think there is hope... All we need to do in hang in there for a little longer and with a bit of luck a small number of boards may be available via the swag shop... (or something like that)
-Gordon
Posted: Fri Sep 12, 2014 10:13 am
by aysar1980
Hi
Since it seems buying a 2nd camera board is too difficult I was thinking of making one, or at least an alternative source of connecting the picam to the compute IO board.
Does anyone have more detailed information on the CSI ribbon used on the adaptor since I can't seem to be able to source one.
I was wondering if a simple single custom CSI cable that has different widths but the same number of connectors at either end will work or does the adapter board does anything more than just shrink the connection size.
Aysar
Posted: Fri Sep 12, 2014 1:16 pm
by AndrewS
aysar1980 wrote:I was wondering if a simple single custom CSI cable that has different widths but the same number of connectors at either end will work or does the adapter board does anything more than just shrink the connection size.
https://github.com/raspberrypi/documentation/issues/113
Posted: Fri Sep 12, 2014 1:29 pm
by aysar1980
Thanks for that
I will look into finding a company to make a simple adapter.
Will keep you posted
Posted: Sun Sep 14, 2014 9:46 am
by Kozuch
I am interested in getting an additional camera adapter board too... Hopefully someone will bring it to market for a reasonable price soon! ;)
Posted: Mon Sep 15, 2014 8:43 am
by gregeric
Posted: Mon Sep 15, 2014 12:29 pm
gregeric wrote:Listed on the Farnell website: http://uk.farnell.com/raspberry-pi/rpi- ... 2-acce-sto
No stock )-:
-Gordon
Posted: Thu Oct 16, 2014 11:22 am
by CJE-4D
Farnell are now saying: "465 will be available for delivery on 19 Oct, 2014" :-)
http://uk.farnell.com/raspberry-pi/rpi- ... dp/2433318
