Got the two replacement boards now...
Both look the same when plugging in....not enumerated when plugging them in....
Now trying with an RPi as host...but I assume it won't succeed....
Re: Compute module not talking
Weird....though it also complained about read errors when plugging in the compute module on RPi the "dd" went fine this time:
root@raspberrypi:/home/pi# time dd if=2014-06-20-wheezy-raspbian.img of=/dev/sda bs=4MiB
706+1 records in
706+1 records out
2962227200 bytes (3.0 GB) copied, 504.884 s, 5.9 MB/s
real 8m24.926s
user 0m0.050s
sys 1m3.290s
First one passed the test
Quite impressed about low current consumption with plugged in ethernet adapter and playing back a h264 movie via NFS...
not much difference between playing with omxplayer and being idle...
The current consumption was measured with GPIB from a 6632B, which also powers the dev kit...
- Attachments
- rpidevkit_cpu.png (22.03 KiB) Viewed 978 times
- rpidevkit_traffic.png (19.93 KiB) Viewed 978 times
- rpidevkit_current.png (13.36 KiB) Viewed 979 times
